Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Mower sputtering and getting hot
When I engage my blades on my riding mower it starts sputtering really bad and gets hot and then shuts off
  • 52 Answers
Clean the carburetor. Be sure to pay special attention to the main jet.
Posted on May 07, 2012
  • 41 Answers
To help stop the sputtering you will need to tune up your mower. As for it getting hot check the air filter, and the top air draw area to ensure that they are clean. During your tune up be sure to replace the oil, spark plug, and fuel filter. If your air filter is dirty replace it too.
Posted on Jul 12, 2009
I mowed half way through, the mower sputtered like it was out of gas. It picked back up but when I engaged the blades the power bogged down, and would only pull at a crawl, what do I need
Stop the engine, disconnect the spark plug wire(s).
Try moving the blades by hand.
Without being engaged, the blades should have a little resistance because they are still connected to each other. But shouldn't be hard to turn.
This will start you in the direction of finding out what's wrong.
A belt that's not in place, a bearing for one of the blades going bad, ect.
Sep 09, 2016 | Garden
I have a 17.5 Murray riding lawn mower engine runs well when I engage the blades it spits and sputters and starts backfiring what could be the problem
Sounds like bad fuel....runs fine when not under stress but poops out under pressure. Drain fuel and refill with new mix if it's a 50/50 gas-oil blend.
Apr 26, 2016 | Murray Garden
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
Cub Cadet Wont Start.
Is the blade engage off? On my riding mower, I shut if off and the blade was still engaged. Drove me nuts for 3 days and all of a sudden, I got lucky.
Oct 03, 2012 | Garden
White z-200 pto switch wont engage mower blades, sputters and shuts motor off.
Electric clutch is going bad and mower doesn't have enough power to run the clutch. Clutch is running tight new clutch is around 270.00 dollars
Apr 11, 2012 | Oregon Scientific Electric PTO Clutch for...
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
My 48 inch riding mower shuts off when I try to engage the blade. It runs until I try to engage
mine has a reverse cut out when blades are running....maybe the switch is bad and thinks mower is in reverse therefore shutting down the mower when the blades are engaged....
Aug 21, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna yth 1746 mower deck won't re-engage once shut off
the safty swich is getting hot & wont alow it to engage again untill cool
Jul 03, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Lawm mower back fires and kills when blade is engaged
Check your spark plug. Or maybe your choke is stuck
Jun 19, 2009 | Craftsman Garden
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
592 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
