Question about Samsung DVD-VR375 DVD Recorder/VCR
I have same problem. i am unable to unlock mine from region 1. when I press menu it gives me set up menu. Please help
  • maalouf98 Jul 12, 2009
    Sergeant:
  • 227 Answers
How to unlock a Toshiba blue-ray DVD player bdx2150 to all regions Please help Thanks
If the current firmware in your blu-ray player supports multi region then try this.
1. Power on the blu-ray player.
2. Press "Setup" on the remote to enter Setup Menu.
3. Using the remote, enter "8520". A new submenu will appear.
4. Set DVD region code to "0" for DVD Multi Region.
5. Set BD region code as required using the remote buttons.
"1" = Region A, "2" = Region B, "4" = Region C
6. Press "Setup" button to exit the menu.
If this does not work then try upgrading the bluray firmware.
Search for Toshiba BDX2150 firmware and see if there is a newer firmware than the one you have installed.
Nov 05, 2017 | Toshiba Televison & Video
Unlock my dvd player
try this
Power Up the unit with NO Disc in the tray.
Open the tray
Press the SETUP Button on the remote control
Navigate to the PREFERENCES page using the Right Arrow Key
Press the DOWN ARROW one time to select
Press the 1 button on your remote control
Press the 3 button on your remote control
Press the 8 button on your remote control
Press the 9 button on your remote control
The current Region Code Setting will display
Use the UP/DOWN Arrow Keys to select the region required or '0' for All Regions
Press the PLAY Button on the remote control
I bought mine tonight. The above procedure works perfectly. It is now set to 0, and I confirmed via firmware version page.
Cheers!
Sep 06, 2008 | Philips Magnavox DVD/VCR Dual Player
Crack code
here u go rate me Fix ya
1/press setup
2/go to the prefernces page.
3/type 9 6 5 3
4/select region
solved 100% by Fix_You
Aug 18, 2008 | Philips DCP855/37 Portable DVD Player
Need to unlock tf-dvd7008
Step 1- open the DVD tray
Step 2- Press the "MENU" button on the remote control
Step 3- Press" 8888"
Step 4- Press the " DISPLAY" button
Step 5- Select your region. I would suggest enter " 0", this will make it a all region player.
Step 6- Press the " SETUP button to exit.
Mar 31, 2009 | Coby TF-DVD7006
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Wrong region.on screenhelp please
try to make it region free by using the steps below
1 Press power on
2 Press set-up
3 Select preferences menu
4 Press play
5 Input 251131
6 Press "Left" then "Down" button
Should show region code
7 Select region
8 Press set-up to confirm and exit.
or
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
or
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
3 Press set-up
5 Press play
6 Input 251131
Nov 27, 2008 | Mintek MDP-1770 Portable DVD Player
Make my dvd multi region
1. Press the 'Set-up' button on the remote control
2. Select the 'System Info' mode from the on-screen menu
3. Using the remote control 10-key type in '1101'
4. 'Region code' should appear as an option on the 'System Info' menu. Initially the region code will be set to 4 (depending on your country). Press '0' on your remote control to set to multi-region.
5. Press 'OK/Enter' on the remote control.
6. Finish by pressing the 'Set-up' button once more.
Sep 14, 2008 | Sanyo Televison & Video
Philips DVD Player DVP 3026 set for Region 5 - Unlock code
1) Open the tray
2) Press SETUP on the remote.
3) Navigate to PREFERENCE menu
4) Go to PBC
5) Get in inside PBC menu so that ON is highlighted with yellow color
6) Key in 138931 and a menu will appear asking you to select region code.
7) Select REGION 0.
Jun 17, 2008 | Televison & Video
7" LG Portable DVD Player DP271
Hi
I have tried to unlock the DVD DP271 player using following methods, But it is not unlocking. If any body knows any other code. Please help me to un lock my DVD DP271 player.
Thanks
Sekahr
1. Power up and press setup
2 Scroll down to LOCK
3 Press '0' (zero) seven times
4. A message may now appear with saying that the player is region free.
5. Power down then power up.
or
1. Remove any discs and power up the DVD
2. Press PAUSE
3. Enter 314159
4. The hidden region code menu may now appear.
5. Set code you want- 0 for multiregion, 1 for region 1 and so on
6. Press PAUSE
7. Power down then power up
Nov 02, 2007 | Insignia NS-PDVD8 Portable DVD Player
Can get to region unlock menu but refuses to change.
hi try this one there are 2 versions they both have different chips.
  1. Power Up the unit with NO Disc in the tray.
  2. Press the Setup button on your remote control
  3. Press the 1 button on your remote control
  4. Press the 6 button on your remote control
  5. Press the 9 button on your remote control
  6. Press the 5 button on your remote control
  7. Press the 1 button on your remote control
  8. Press the 8 button on your remote control
  9. Select the region code with the Number buttons or the Navigation Buttons on your remote control. 0 (Zero) for Multiregion.
  10. Exit the menu
  11. Press the Power Off button on your remote control
  12. Press the Power On button on your remote control
it worked for me.
Sep 24, 2007 | Cyberhome DVR 1600 DVD Recorder
Samsung DVD-VR375 DVD Recorder/VCR Logo
229 people viewed this question
Jerry Greenberg
Jerry Greenberg
