Question about Car Audio & Video
Mechanical problem I have a merc c220 1996 with a dead battery do u know wher to conect the jump leads under the bonet as i cant get into the boot for the battery. Regards Ray
    New Friend:
  • 28 Answers
There is a ground and a postive pole under the hood should be on the right front the pole should be there
Posted on Dec 04, 2008
My merc 709 won't start
Sounds like dead battery... Is the same thing happening when you jump start the car?
Jan 11, 2015 | Cars & Trucks
Jumpimg door lock
if they are like the old mercs they run off air from a small pump either under the back seat or behind a pannel in the boot unlikley that its the door mecanisem as it a push pull lever only way it wouldent do that is if the pipe conected to the lock had come off but this is unlikley
Jan 23, 2014 | Mercedes-Benz A Cars & Trucks
It wont crank like not getting power
ok sounds like you have a dead battery
1) if turns but slowly:
posible causes:
1.1) old dead batery/
or underchaged battery >check altenator in this case
did you leave your headlights turnt on and drained the battery of its charge?if so get a jump start and then run the car for 30-45 mins to rechagre the battery
if you have at your disposal anothere batery that you know has a good charge
try starting your car with that batery(not using jumper cables) hook it up!
if the slugish turn over is still there
1.2) check your wire conections for corision this means completly disconecting 1 lead at a time (only on one end of that lead)and cleaning them with a wire brush or some sand paper.
(on the battery and the starter also the ground strap conection to the frame.)
posible causes:
2.0) dead battery >try charging it>get a jump start
2.1) blown turnkey igntion fuse
2.2) blow fuse for main har nes wires
2.3) bad starter
2.4) corosion on wire conection (most often the batery terminals)
2.5) starter replaced and hooked up incorectly.
2.6) alram system preventing the turnkey igntion system from getting power
Feb 24, 2010 | 1994 Mazda 626
Peugeot 406 HDI 2001. O/S rear door dead locked.
Deep joy. This can be a royal pain. The only way I have successfully done this is to put a battery charger on the car overnight, locked, and then when the battery is sitting at about 15v unlock it with the remote - when the lazy deadlock is stirred into action. It can take a couple of attempts. It really is incredibly difficult to get to. Otherwise, its most easily a case of breaking the unit...though you could try taking the leads off and applying 18v to the solonoid directly. That was my next move, but never needed to get there. You can however stop the deadlock from locking, by cutting one of the wires, test using a multimeter which one is live when you arm the alarm/deadlock the car. Thats also the one to apply 18v to if you want to.
Jul 05, 2009 | 2006 Peugeot 604
Flat battery, cant open boot of merc s320
The positive terminal on what?, on the battery it is marked with a big + and the one with the - goes down to the car bodywork
Why not get a buddy to connect a set of jump leads onto your battery which will give you enough power to open the boot ?
Jul 01, 2009 | 2000 Mercedes-Benz S-Class
My battery is dead and i don't know how to get at it Ferrai f430
Battery is under passenger seat footwell, you will need allen keys.. I used jump leads, bit of a squeeze but gets it started, use the little torch in glove box, it helps light the way!
Apr 05, 2009 | 2008 Ferrari F430
Mercedes e class cannot open the boot
I have a e320 2003 model, the same has happened to me. I wondered if it could be the fuse but couldn't find a fuse that managed the boot.....
This problem is identical to the other post "boot wont open electronicaly by the boot release latch above the number plate, the boot release button inside the car or the key fob! I have to use the manual key to mechanically open it now."
Jan 26, 2009 | 1996 Mercedes-Benz C-Class
I have a porsche boxter 986 year 2000 and can not open the bonet
you need to pull the C3 fuse and insert a wire and then put the fuse back in.
connect the neg ground to the metal steering column and the positive to the wire. close the car door and turn the door key on and off three times. open the door and now the hood latch will work.
Jan 18, 2009 | 2001 Porsche Boxster
S class
you can jump directly to the battery. the procedure for doing this is as follows connect the positive cable to the dead vehicle(yours) then connect the ground cable either to the battery or to the engine block. then conect the positve cable to the jump vehicle then connect the ground. start the jump vehicle and rev engine to 1500-2000 rpm for 2 minutes. let vehicle idle for 5 minutes. then try and start dead vehicle. sometimes the whole thing takes 10 to 15 minutes to be successfull. please rate the solution.........thanks
Sep 24, 2008 | 2000 Mercedes-Benz S-Class
Unlocking Boot lid
I am assuming your problem is similar to mine; the key fob isn't dead, but for some reason the boot won't release.  This happens rarely, but can be very frustrating (and embarrassing)!
When neither the key fob nor the release on the boot work, lock and unlock the car, and insert the key into the ignition.  Turn the key to the second stage, i.e. the accessories are powered, and then remove the key.  This ought to allow you to use the fob again.
Aug 18, 2008 | 2002 Jaguar X-Type
Car Audio & Video Logo
75 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
