Question about Jacuzzi 8730-829 Bath Rotary Drain Kit, Bright Brass
What purpose does a jacuzzi rotary drain serve? They only describe it as needed "for a smooth line." Seems expensive if it's just for appearance. Is it also a pump or grinder?
  • 123 Answers
The rotary drain kit is just a drain kit that allows the user to open and close the drain via the rotary handle at the overflow..........it is mostly for aesthetics
Posted on Jul 31, 2009
Water dripping from a/c in altima
clean out the drain hose properly including the section that it is hooked to as the gunk builds up inside and over flows. The drain is in the lower half of one section so sealing the unit serves no purpose.
Nov 30, 2013 | 2006 Nissan Altima
The rotary knob that open and closes the drain is broken .Need the broken part. My jacuzzi whirlpool is model:OPALIA . Color :white. The part is brass
you would find that broken piece at your local jacuzzi whirlpool showroom. they will be the authorized dealership that will offer that part to you for sale.
the part you are looking for is part of the drain and overflow assembly.
Aug 18, 2011 | Jacuzzi Home
Frigidaire dishwasher has standing water that did not drain
Frigidaire dishwashers have two pumps. one for wash and one for drain. But if your
dishwasher is connected to a garbage disposal and the disposal is not working then the
dishwasher will not drain. Otherwise the drain pump on the dishwasher has failed
OR the line itself is plugged (sometimes the port on the disposal gets gunked up and
will not allow draining). If you have replaced the disposal recently
the "knockout" may still be in the garbage disposal port.
One last thought, if you have
a small tomato paste can sized item next to the faucet that seems to serve no
purpose, this is called an "air gap". They can also get gunked up as well and prevent
draining of the dishwasher. They are inexpensive to replace or can be cleaned.
Hope this is helpful.
Apr 12, 2011 | Dishwashers
How do you get hair out of a drain that is in a Jacuzzi. Can I unscrew the drain stopper or can I remove the chrome plate further up the tub?
unscrew what ever is covering the hole where the water drains out,.... use a pair of needle nose pliers or an old coat hanger with a little hook pre-bent in it (don't get it stuck in there) and pull out the hair,....it's that easy! good luck, cracklin joe
Jan 04, 2010 | Jacuzzi Rotary PVC Drain Kit DA34-815
Jacuzzi rotary drain
I don't understand the bend down rhing. The drain stopper, as you call it, has a rod that goes through the end of it to enable opening and closing with the vertical control.If I'm on the same page, under the sink on the backsie there is nut that holds the stopper control.. It has a nut you need to remove and line up the short end with the stopper slot, then put the nut back on to secure the ball. Don't overtighten. Now the log end of that same rod is secured with a spring clip to the un and down control rod . It can be adjusted by moving the spring clip up or down on the control rod. noyhing isbroken, just pulled apart or out of adjustment.
Nov 06, 2009 | Jacuzzi Rotary PVC Drain Kit DA34-815
I have to move the kitchen drain pipe over 2
You need to measure the outside diameter of the pipe then go to your hardware store and buy a flexible coupling of that size.
Oct 15, 2009 | Jacuzzi Rotary PVC Drain Kit DA34-815
Which valve do I use on the Jacuzzi Magnum 1500 to drain lines
There two plugs on your pump, one one the side of the pot at the bottom and one dead center of the pump housing on the front. this will only drain your pump if you live in cold country and are winterizing you will need to drain all your equiptment filter, heater and any thing else. then you need to drain your pipes and seal them at poolside to keep the water out.
Sep 26, 2009 | Jacuzzi MAGNUM FORCE POOL PUMP - TWO SPEED...
Jets are draining my jaccuzzi tub
Check to see if there is an open valve where the water exits the tub. If there is a valve, shut it and your problem should be solved. good luck
Jan 15, 2009 | Jacuzzi 8730-829 Bath Rotary Drain Kit,...
Jacuzzi 8730-829 Bath Rotary Drain Kit, Bright Brass Logo
445 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
