Question about Seagate (ST3250824AS) 250 GB Hard Drive
Cant load xp onto sata HDD
Hi, i'm trying to load xp onto my computer but it won't recognise the sata hard drive although the bios does recognise it. any help will be much appreciated
  • 2158 Jul 12, 2009
    thanks guru, for a baby your pretty intelligent
    President:
  • 1,179 Answers
To use XP with a SATA drive you'd need to use the HDD disc software first as XP didn't come with preloaded SATA drivers. This is what is preventing you from installing XP on the drive. Once the driver is loaded you should have no problem. If your new hdd didn't come with a disc then you can download it from the hdd manufacturers website under the support link. Hope this helps.
Posted on Jul 12, 2009
A8VE-SE won't recognize SATA HDD
If you are trying to install Windows XP then -
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Jan 08, 2013 | VIA Asus A8v-e Se Socket 939 Pci-e K8t890...
Compaq Mini 700EL hdd not recognised
If you are installing Windows XP then -
Oct 08, 2012 | Computers & Internet
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
Old hard drive died so now have a western digital wd5000aakx. have pins 5&6 jumpered but cannot instal windows xp as no drive is recognised even after loading the sata drivers that camw with the...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Jun 09, 2011 | Computers & Internet
Cant detect hard drives during the process of loading xp
Just pres F2 key on startup. Go into bios. In bios find HDD and press enter next to mode. Select IDE mode and press f10 to save changes and exit. You can install XP now. Alternatively you can use USB floppy drive to load SATA drivers.
Let me know if you need assistance on that
May 26, 2009 | Fujitsu Siemens AMILO Pro V2000 Notebook
Installation of windows XP
preachw996 has it... you must enable the SATA drive you want to install XP onto as your 1st IDE DRIVE/DEVICE (ie. you are telling BIOS to dummy a SATA drive in to the 1st IDE position).
Only then will you be able to recognise the drive as a boot device.
This is done in BIOS.
Mar 27, 2009 | Microsoft Windows XP Media Center Edition...
Unrecognized HDD-- need help!
You could also try setting the jumper on the hard drive to "limit to 1.5gb/s".
Oct 04, 2008 | ASUS K8V-MX Motherboard
Problems installing a SATA hard drive
Hi Tony. As you are using a SATA hard disk then I would firstly check a few settings, this involves loading the computer BIOS. When you see the computer first turn on, you should be prompted to press "F2" to enter the BIOS screen.
From here select "Enter BIOS SETUP UTILITY" then "Advanced screen" and finally "IDE Configuration"
Verify that 1) Onboard IDE Controller is set to "Enabled"
 and          2) “SATA Operation Mode” is set to "[non-RAID]"
Once you have done this, you should see the HDD listed beside SATA 1 or SATA 2 (depending on which port you plugged the hd in to) then press F10 to save and exit. The computer will now start up as normal.
If you have more trouble after checking these settings, please write us again.
Hope this helps
Apr 09, 2008 | Maxtor Hard Drive
Hp dv6000
There is option in BIOS called something about automated SATA recognition or similar - disable it. It is under System configuration. And if you are putting new drive in then run full test from BIOS (Hard drive selftest - takes about 79min.)
I tried to reinstall Windows Media center on my HP dv6000 because my previous hdd crashed - When I put in installation cd - it said that it can't find hdd. I spent week to figuring that out. The thing is - as far as you haven't disabled that SATA thing in BIOS - PC doesn't recognize hdd. But only with Windows media center edition. With all other windows xp - there is no such problems. Strange.
Feb 11, 2008 | Computers & Internet
SATA Drivers for Hitachi HDD
Is there a BIOS setting to temporarily put the SATA controller into legacy mode? XP would then think it's an IDE drive. Then, after installing XP, install the drivers from the motherboard CD, then go back into the BIOS and turn off legacy mode.
Jan 13, 2008 | Computers & Internet
Seagate (ST3250824AS) 250 GB Hard Drive Logo
170 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
