Question about Panasonic DMR-E85H DVD Recorder
Set 1 every time i push a button on my remote it says set 1, how can i fix it
Press and hold enter and 1,2, or 3
Posted on Feb 13, 2008
Power cycling
Push the "menu" button on your remote
Tab over to the "time" menu
check all the settings in there, turn of the sleep timer etc...
Try a factory reset
Push the "menu" button on your remote and go to settings, scroll down and push reset.
I hope this helps
Feb 10, 2014 | Samsung LN40D550K1FXZA - LN40D550 40 1080p...
Small vibe remote from dollar general doesn't have a set button that I can see. Does anyone know where its located?
i lost the book to vibe remote ...i just went and bought another remote returned remote kept it goes....hold down device tv cd vcr button till light goes on while holding dont let go wait till light goes out then hold down power button while still holding both buttond now wait for light to go out then let go of both buttons then point remote at device and push power button untill device turns off then push stop button to set and there you go all set....note you may need to push power button a bunch of times to find code so hang in there...if in doubt start over
Sep 26, 2012 | Televison & Video
Loigitec Harmony 550 Remote does not respond to buttons pushed
The following steps will reset your remote. If this does not fix it, then it's probable a hjardware related problem.
1- Remove the battery from the Harmony remote, hold the 'Off' button and insert the battery back in. The screen will display 'Safe Mode'.
2- Make sure you have version 7.7.0 of the Harmony software installed on your computer. You can download it at
3- Launch the software and log in to your account.
4- Click on 'Downloads' at the top of the screen.
5- Click 'Firmware' and follow the steps to update the firmware on the remote.
6- Update your remote.
Jul 21, 2010 | Logitech Harmony 550 Remote Control
I have a comcast Motorola HD capable cable box with DVI output - going through a converter cable into an HDMI input. When I change from a hi def channel to a std def channed, the screen gets split, and...
Here sounds like your override setting on cable box needs to be set.
Here is how to fix that-
1. On remote push the button at the top that says CBL or Cable.
2. On remote push power button.
3. On the remote push the menu button.
This should bring up an internal menu called user settings.
4 Use the remote to scroll down to 4:3 OVERRIDE and use the LEFT or RIGHT arrow keys on the remote to change the value to 480i and see if this clears up your problem. If not repeat and change the setting to 480p and one of these settings should fix your problem.
Good Luck and please rate this solution.
Jan 04, 2010 | Panasonic TH-42PX60U Television
Panasonic dvd recorder "set 1"
The best solution is pressing number 1 and ENTER button in the same time. That's the solution.
Jun 05, 2009 | Panasonic DMR-ES10 DVD Recorder
1985.5 PORSCHE 944 digital clock (changing time)
There are three buttons, let's call them 1, 2, and 3, from left to right.
Time setting
A. 12 AM, PM or 24.00 h
With the clock in the time readout mode, keep
button (2) depressed for 4 seconds -12 AM, PM
or 24.00 flashing. After pushing button (1), either
a 12-hour (AM + PM) or a 24-hour setting
program can be selected. If you only want to
change the display mode, push button (3). The
clock then returns to its normal timekeeping
B. Hours
Push button (2) a second time - hour display
flashes. Set hour by pushing button (1). After
pushing button (3)*, the clock returns to the time
readout mode with new hour setting.
C. Minutes
Push button (2) once more - minute display
flashes. Set minute by pushing button (1). Upon
pushing button (3)*, the clock is started -
accurate to within 1 second.
Stop watch function
The stop watch can only be set in motion if the
clock is in its normal timekeeping mode and not
during setting operations.
A. Push button (3) - 00:00 display appears;
B. Push button (1) - stop watch is on;
C. Push button (1) a second time - watch stops.
(Additional times can be added by pushing button
(1) again - stop watch keeps running. Push button
(1) once more to stop timing.)
D. Push button (2) - 00:00 display appears;
E. Push button (3) - normal timekeeping mode.
If button (3) is pushed during operation A and
B, the setting procedure must be restarted
Apr 17, 2009 | 1985 Porsche 944
Any button pushed on my remote control causes ''SET 1'' on display.
Hi, All you need to do is point the remote at your DVD player and hold both the number "1" and "enter" keys down for about 10 seconds. Evidently that re-sets the remote. It worked for me so good luck.
Nov 12, 2008 | Panasonic DMR-ES46VS DVD Recorder/VCR
Dvd recorder remote control
Anytime your unit displays RC1, 2, or 3 - the remote code needs to be reset. Other messages are "chk remote n" or "set n", n being the number 1, 2 or 3. These remote codes are set in case you have multiple products that interact w/ the remote - so when operating one device the other doesn't interfere. Unfortunately, every now and then for completely unknown reasons, they can slip out of the proper code. All you have to do (if your remote is, in fact, functional) is press and hold the number on the remote that corresponds with that which displays on the unit - in your case the number 3, and hold the Enter key at the same time for about 5 to 10 seconds. This should resume operation shortly thereafter. However, you will not see any confirmation on the display as you are performing this reset. It is trial and error.
Jan 28, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Setting it uo
Push the t.v. button on the remote then push and hold the on/off button and the t.v. button down at the same time until the on/off button comes back on and stays on, then you release them both. Then push the CH+ or channel up button on the remote and the on/off button alternatively until the t.v. goes off or comes on, each time you hit the CH+ button on the remote you are advancing the code for you t.v. forward in your remote, after your t.v. comes on or off then hit the stop button on the bottom of the remote and you have stored the code for your t.v. Hope this helps.
Sep 25, 2007 | RCA RCR412C Remote Control
Problem with remote
This fixes the *Set 1* problem. Set 1 means the remote cannot communicate with the Panasonic DVR. If the batteries go out on the remote replace the batteries stand in front of the Panasonic DVR, press and hold the "1" button and the *enter* button at the same time and hold for 10 seconds.
May 21, 2007 | Panasonic DMR-ES35VS
Panasonic DMR-E85H DVD Recorder Logo
44 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
