Question about Poulan Ght225 25cc Gas Hedge Trimmer
Once i get my troy built 25te started, it won't stay running. why?
My Troy Built leaf blower starts, but won't stay running. I bought it two years ago and it's rarely used.
Once you determine there is no holes in the gas line or that the gas filter is not bad I suspect the carb. will need to be rebuilt. It is not a bad job. Just remove the carb. note the number on the carb. and go to most lawn mower shop and they can provide you with a rebuild kit. You tube has videos on what and how to do the rebuild. Hope this helps.
Sep 29, 2016 | Troy Garden
I have a troy built chipper vac that starts but won't stay running it has gas and new spark plug
How old is the fuel in the tank and also look into the tank for water from condensation. If the gas is older than 2 months drain the tank and the carb bowel.
Nov 06, 2015 | Troy Heavy Machinery
I bought a Troy built tiller. used once two years ago. then it has been sitting in a shed. It had old gas in it. I drained gas tank. I am getting a spark. when I pour gas in air breather, it starts, but...
I have had good luck using an engine starting fuel, sprayed into the air cleaner/intake. Any auto repair store will carry this product. CAUTION, HIGHLE FLAMMABLE!!!!!!! Many mechanics frown on using starting fluids, but I have a bad shoulder & that is what I do on the 3rd pull.
Louie Almond
Mar 27, 2011 | Troy-Bilt Pro-Line 160cc FRT Tiller
My troy built lawn mower dies after it starts runs for a few seconds dies if i put my thumb in the carb it will stay running.
Your high speed needle jet is most likely the cause. Remove the jet and clean it out. Keep in mind that there may be least one or two very small holes drilled in to the sides of the high spped jet, if so, be sure they are cleaned and not clooged.
Jan 17, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy-built TB320BV will not stay running
get a can of carbeurator cleaning spray. get a helper and as one of you runs the thing, the other will give it short bursts of carb cleaning spray right into the air intake, leave the filter off while you do this.
Aug 22, 2009 | Troy Bilt Tb320bv Spring Assist Blower/Vac
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Poulan Ght225 25cc Gas Hedge Trimmer Logo
37 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
