Question about Refrigerators
The freezer coils in my side by side freezer are condensating and filling up the botom of the freezer.
  • 89 Answers
Check the drain it is located just under the back cover you should be able to see it by taking the bottom drawer or basket out
Posted on Jul 12, 2009
Freezer side not freezing
Check for ice / frosting inside the freezer .... If present you probably have a defrost problem.... This causes the freezer coil to ice up and block the air flow ... the causes could be a bad defrost heater , defrost timer, defrost sensors, or control board. Also make sure that the condenser coil is clean. remove ALL dust with a vacuum and a coil brush .the coil is located either on the bottom or on the back side of the unit... You didn't give the Make and model #
Apr 04, 2014 | Freezers
Freezer runs and sides are hot
Good Morning bigred140, thank you for allowing me to assist you!
From what you have described, it seems like you may be referring to the perimeter hot tube. It is normal to be warm to the touch; however, since it may feel hot to you, I would suggest verifying that you have the proper clearances around your refrigerator. You can refer to your owner's guide for those specifications. If you do not have an owner's guide, you can typically locate one on the manufacturer site.
If the clearance is fine, you may need to clean the condenser coils. As part of routine maintenance, you can remove the toe grille (located at the foot of your freezer) by unsnapping the sides and lifting outward towards you. Now, using an extended vacuum attachment and condenser cleaning brush, remove dust buildup from condenser coils on left side underneath freezer. Cleaning condenser coils typically resolves this issue.
But, if clearance is fine and the condenser coils are free from dust and you are still feeling too much exterior heat, you may need to check with a local service tech to determine what else could be causing this issue.
Best regards, Chris.
Dec 22, 2013 | Frigidaire FKFH21F7HW Freezer
Overheating of Partition in a side-by-side
pull off the bottom front kick panel and check the condenser coil to see if it's filled with dust,also pull out the machine and remove the back bottom panel and make sure the condenser fan motor is running and clean out any dust back there,if the coil is clogged with dust or the condenser fan motor isn't working is what could make that strip hot.
Aug 30, 2012 | Whirlpool Refrigerators
Condensate drain inside of freezer compartment keeps filling up and freezing and then overflows to bottom of freezer compartment and freezes. Have made sure drain line is clear. Problem occurs about every...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 22, 2011 | Kenmore Side by Side Refrigerator
Freezer has warm spots. All around freezer is hot to the touch. Compressor is hot, coils are clean, condensor fan is running.
Thats normal.
The condenser coils are located just inside of your exterior cabinet walls on the sides and top.
So the freezer gets cold inside and heat has to be released from the condenser coils.
If this is something new, you may have a problem with the defrost timer
Sep 11, 2011 | Kenmore Side by Side Refrigerator
2002 side by side. Circuit board relaced. Freezer and fridge set on "4". Freezer at steady 10 degrees and fridge at 40 degrees. Fan in the freezer seems to run 24/7. Repairman says that's just...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Kenmore Side by Side Refrigerator
Water puddling in botom of freezer and runs in floor periodically (maytag side by side)
I had a problem like yours, the auto defrost doesn't always turn off. On mine I replaced the sensor. it was a round sensor clipped to the top of the freezer condenser, kind of hard to get to to replace. inside the freezer at the top it has two wires. I ordered mine from sears parts. I don't know if thats your problem, but sounds like what happened to me.
Mar 13, 2011 | Maytag Refrigerators
My fridge and wont stay cold anf the freezer will only freez items at botom ice not working also
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 09, 2010 | Samsung Refrigerators
Ge side by side not cooling
heatman101
gfhjsf
Jun 15, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Kenmore upright freezer
you have a defrost system problem. Could be the defrost timer or defrost heater or defrost thermostat. Bottom filled with ice could be from a plugged drain system. Where you termed "condenser coil" is in reality the "evaporator coil".
May 24, 2008 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
