Question about LG CHOCOLATE VX8500 Cellular Phone
The display on my phone is not working. It shows a blank white screen. How can I fix this?
  • 6,784 Answers
HI, this may be a broken solder joint that connects to the main board. you can confirm this damage by, pulling the battery and sim card for 3 minutes. let the phone sit without the sim and battery for this time. after the 3 minutes have passed, simply reinstall the battery and sim card and, power up. if the unit dose not initialize the core program, this will confirm a major issue that concerns the main board. this will require a service tech in this case. the main board will need to be replaced.
Posted on Jul 12, 2009
Blank white screen on my nokia e63
1.try change screen
2.try full flashing software
3.check lcd ic
Aug 29, 2012 | Nokia E63 Cell Phone
Is there a simple reason why the screen on my samsung mobile has gone blank.the phone can still turn on and off and keys still make sound when you press them as they normally do but nothing on the screen...
The problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Nov 15, 2010 | Samsung Lands Phones
Blank and white screen solution
Hi,there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
And also flex can make screen go blank and or white.(if it is a flip phone)The flex is a connector that connects the screen to the phone board of the phone.That can also be the cause, when the flex is damaged,it can cause blank and white screen display .
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 | Cell Phones
The display stopped working, Just a white blank screen. The phone still works but the screen does not. Can't see who is calling and can't retrieve pictures.
Hi,blank screen is usually caused by bad screen or flex depending on the type of phone you are using at the moment.
If the phone is a flex phone that means you will need to check both the screen and the flex.(flex makes the screen to display).
When you replace the screen,the phone display will be working again.
Have a nice day.
Sep 01, 2010 | Cell Phones
Motokrzr k1 display shows white blank how do i got
Hi there
The problem with your phone is the flex,
The flex is a cord that connects the screen to the phone panel,it is found in all flip and slide phonesthe flex of your phone has either shifted position or is too weak..
Try opening up your phone,you will see a cord that connects the screen to the panel of the phone. try removing it(be very careful) and fix it back in place.
Assemble the phone and put it on to see if works,if it doesnt work then the flex has to be changed for your screen to come up again.
Please if you can do this yourself you should get a person with experience to do it for you
GOODLUCK!
Jul 08, 2010 | Motorola Mobility MOTOKRZR K1 Cellular...
Diplay is blank (just white lighted screen) does
hello,its a flex problem or could either be that your screen is faulty,i would advice you take it to a mobile phone engineer to fix it up for you.its can be fixed.thanks and you are welcomed.
Mar 09, 2010 | Motorola Mobility W385 Cellular Phone
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
Oct 08, 2009 | Nokia N70 Cellular Phone
LCD Screen is will only display a white screen.
The inner screen cable contact would have got loose. You can carefully open the casing to reconnect the cable, or you can take it to a service center to get it fixed.
Aug 06, 2009 | Samsung Katalyst SGH-T739 Cellular Phone
It turns on but a blank white screen only shows
i had the same issue when my phone got slightly wet. try taking everything apart (sim card, battery, back). let them dry out for a little bit then after like a day or two put the phone back together. turn it on it will be a white screen for a little bit but give it like 2 or 3 mins and if should come back. I did this for my phone cuz i really needed the pictures off it and it worked! hopefully if will work for you too. GOOD LUCK!
Jul 16, 2008 | Nokia 6133 Cellular Phone
Blank white display on Nokia 3230
This is a major fault, screen gets blank white because of some problem in its display panel which is right behind the LCD screen. Rush to the nearest Nokia care centre and explain the problem to them.After the repair if you experience this problem again and your phone is within the warranty period you can demand a brand new box piece!
Sep 03, 2007 | Nokia 3230
LG CHOCOLATE VX8500 Cellular Phone Logo
20 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
