Question about Dishwashers
I have an Kitchen Aid Imperial 21 Model KUD121DS2. Water, drain, and electrical is hooked up, but unit will not turn on. any ideas?
  • Anonymous Mar 31, 2014
    kitchen aid imperial 21 dishwasher
    water leaking from bottom of dishwasher, kitchen aid imperial 21 model
  • 224 Answers
Make sure the incoming water temp is 120 degress or above and be sure that you restored flow at the angle stop. If you turned off power at the breaker box, make sure it's restored as well. If it's hooking up to a garbage disposal that did not orginally have a dishwasher, you need to knock out the plastic cap at the bypass pipe.
Posted on Jul 12, 2009
My Kitchen Aid Refrigerator model KFCS22EVMS8 is leaking water . I was told that I should clean the drain pipe. How can I clean it and stop the leak? Thanks
The drain is plugged up from ice and debris that comes off the food in the normal process of working. You may have to remove the back panel in the freezer and pour hot water in the drain area at the rear bottom if the freezer under the coils. After thawing the ice it would be a good idea to run a short piece of 1/4 inch plastic hose, maybe about 18" or so, down the drain to push any debris through the hose. Flush it out well with hot water and this should be good for several years.
Sep 13, 2014 | Refrigerators
Kitchenaid dishwasher imperial 21
Take the kick panel off under the door and see if the technical spec sheet is there. That lists all the diagnostics that you can run
Nov 20, 2013 | Dishwashers
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Kitchen Aid Imperial 21 has loud motor noise duing wash cycle
loud motor noises during the wash cycle usually come from a water pump. Either the water pump will stop working soon, or it will keep working for a while longer, and the unit will stop cleaning. Sometimes the pump will stop making the noise for a while before it stops.
Jan 29, 2012 | KitchenAid Dishwashers
Detergent is left undisolved in bottom of washer when cycle is completed. Water pressure is correct. No cloged pipe. What is happening? No excess detergent. Kitchen Aid dishwasher. Imperial 21 series
I have the kitchenaid KUDK03CTSS3 dishwasher with the same problem, it doesn't take the detergent. Have you been successful in finding a solution?
Jul 07, 2010 | KitchenAid Dishwashers
Kitchen aid single electric oven
soundsl ike youve blown a thermostat on the back wall of the unit(fairly common with the K/A appliance, unit wikk have ot be pulled out to check continuity on the thermosts( loactated behind back wall just between the broil element hook ups.
Apr 02, 2008 | KitchenAid KESC307 Electric Kitchen Range
Dishwashers Logo
546 people viewed this question
Top Dishwashers Experts
