An AC system blowing hot air is usually due to a low freon charge or a non operational AC compressor. If the fuse blows, disconnect the compressor electrical plug and turn on the AC. If the fuse doesn't blow, suspect a compressor problem. If the fuse continues to blow with the compressor disconnected, there is a direct short between the ON/OFF switch and the compressor which can take hours to diagnose
SOURCE: 2001 pt cruiser no heat
did you check the fluid level by removing the rad. cap? Radiator should be full to top. If Chryslers are low on coolant, the heater will not blow warm air.
SOURCE: Change the thermostat on 2002 Chrysler PT Cruiser
Hi, i have put together a step by step guide that will help you with this replacement job. Make sure the vehicle is in a cool state before starting this job.
* Drain some coolant into a clean container until the coolant level is below the thermostat housing.
* Remove the upper radiator hose connection from the thermostat housing.
* Loosen the housing bolts and remove the housing.
* Remove the gasket and scrape it carefully from the surface of the housing and the mounting surface on the engine. If the gasket remains on either of the surfaces, there will probably bea coolant leak after reassembly. Some engines use a rubber O-ring to seal a thermostat housing.
* Compare the size of the thermostat to the old one. They are of different sizes, types, and temperature ratings.
* The temperature rating is stamped on the sensing bulb on the bottom of the thermostat. The temperature bulb faces the block.
* When replacing a thermostat, be sure that the thermostat fits into the groove in the block or outlet housing. If the thermostat is installed upside down, the engine will overheat.
* Install the gasket.
* Reinstall the thermostat housing. Refill the system and run the engine or pressure test to check for leaks.
* When the engine has reached operating temperature make sure the thermostat opens.
* You should be able to see coolant circulating within the radiator.
* Another way of checking thermostat operation is to feel the top of the radiator hose or use a thermometer or multimeter with a temperature probe to confirm that the coolant is warming up.
* If the engine is overheating, but the top hose is still cool to the touch, the thermostat is stuck closed and must be replaced.
NOTE
When a paper gasket is used and the recess is in the thermostat housing, it is a good practice to position the thermostat into the recess and glue the gasket to hold it in place. If it falls out of its groove during installation, the outlet housing can be cracked or a coolant leak will result. Before tightening the water outlet housing, try to rock it back and forth to be sure it is flush. Housings are often cracked during this step.
SOURCE: my 2002 pt cruiser lost power steering suddenly
check to see if the serpantine belt is still there. It sounds like like it broke. this belt runs all of the accesories on the vehicle including the water pump. So if this happened it probably starting running hot too
SOURCE: DIAGNOSTIC code P01A4 for pt cruiser
I have the same problem. Pt - 2002, 2.2 diesel. Same mistake number appeared. Noone knows what is it.
SOURCE: AC blows hot air but AC compressor works
if the compressor works and your freon is charged it may be the blower flapper door....disconnect battery for 10 minutes and then re-connect to reset the electronics that control the flapper
If you touched any of the A/C controls within 45 seconds of starting your Suburban (after the battery change), you messed up the 'calibration mode' of the HVAC.
Pull the HVAC fuse (10amp) under the hood, and pull the two adjacent fuses (30 and 10amp) under the dash listed as 'climate control' in the manual.
Push the fuses back in, restart your car, but DONT TOUCH ANY of the A/C controls for 90 seconds.
I bet the A/C starts working again normally.
