Ipod plays for ten minutes then stops until i press power button then another ten minute play
    Sergeant:
  • 449 Answers
Check the power settings in configuration menu. Also try replacing the batteries.
Posted on Jul 12, 2009
I need code for lm1075 universal remote on a Sylvania tv
Press the power button and the button for the device to be programmed, holding them down until the red light comes on. Release the buttons at the same time. Pointing the remote at the device to be programmed (while the device is on), press the PLAY button. The red light will flash 10 times as it Foss through ten codes. If the device turns off, press the REWIND button once every few second until it turns back on. As soon as it turns on, press the STOP button. You May have to go through several sets of the ten codes to get to the right one. Press the play button after each set of ten if you haven't had tor device turn off. After you have the device coded, hit the device button, then power, to make sure you have it programmed. Good luck. I just had to do this myself. I had memorized how to do it, threw away the manual, then forgot. I couldn't find any help online, so I played with it until I figured it out.
May 06, 2015 | Sylvania Televison & Video
How to shutoff ipod a1236
Turn off your iPod by holding down the "Play/Pause" button for two or three seconds. The screen should go blank, and your iPod will remain off until you turn it back on again by holding down the "Play/Pause" button.2 Let your iPod go to sleep. When an iPod isn't used for two or three minutes, it automatically goes into "sleep" mode. The screen will go black until you touch any of the controls. Sleep mode uses considerably less battery power.
  • Oct 11, 2011 | Apple iPod nano
    After power cut need to reset vcr clock on philips vr750 but have lost the manual
    Hi
    To set the clock:
    Manual Clock Setting
    1Press the VCR button, then press the MENU button.
    2 Press the PLAY [UP]or STOP [DOWN] button to select INITIAL
    SET UP, then press the FF /OK button.
    3Press the PLAY [UP] or STOP [DOWN] button to select CLOCK,
    then press the FF
    /OK button
    4Press the PLAY [UP] or STOP {DOWN] button repeatedly to set
    the TIME. Every time you press the PLAY [UP] or STOP [DOWN] button,
    the time changes in one-minute increments. If you press and hold
    the PLAY {UP] or STOP [DOWN]9 button, the time changes in 30-minute
    increments
    5Press the PLAY [UP] or STOP [DOWN] button repeatedly to set
    the DATE (month and day). Every time you press the PLAY
    [UP] or STOP [DOWN] button, the day changes in one-day increments. If
    you press and hold the PLAY [UP] or STOP [DOWN] button, the day
    changes in 15-day increments.
    When the month and day are correct, press the FF /OK
    button
    6Press the PLAY [UP] or STOP [DOWN] button repeatedly to set
    the YEAR. When the year is correct, press the FF /OK
    button. The day of the week will appear automatically
    7Press the FF /OK button once again to skip "AUTO
    CLOCK" and go to "D.S.T." (Daylight Savings Time).
    Press the PLAY [UP] or STOP [DOWN] button to set D.S.T. to ON
    or OFF. If AUTO CLOCK is OFF, you may set D.S.T. to ON or
    OFF only
    8Press the EXIT/STATUS button
    Jul 13, 2011 | Philips Televison & Video
    Memorex travel speaker with ipod dock speaker system black I cannot set the clock on this item
    Hold the "Time Set" button until the time starts flashing, then press the "play/pause" button so that only the hour is flashing. Use the ">>" and "<<" buttons to set the desired hour. Once the hour is set, press the "play/pause" button again so that the minute is flashing. Again, use the ">>" and "<<" buttons to set the desired time.
    To change to military time from am/pm, hold the "Time Set" button until the time starts flashing, then press the ">>" button. In order to revert back to am/pm, hold the "Time Set" button until the time starts flashing (if it is not already flashing) and then press the "<<" button.
    Sep 16, 2010 | Memorex Travel Speaker with iPod Dock...
    How do you set the clock and alarm on the Starlite Next Play Clock Radio with iPod Dock NP105CR
    Setting the clock for the Ipod docking station
    NP105CR
    Press the set button 3 times until all the digits for the main clock are flashing. Press the skip forward and back button for hour and volume up and down for minutes. Press set button once to confirm and exit the setting menu.
    866-387-2027 for manual
    Jun 23, 2010 | Starlite Next Play Clock Radio with iPod...
    Froozen and wont do ANYTHING
    1. Toggle the Hold switch. To do this, slide the switch to Hold (an orange bar appears) and then slide it back (orange bar is hidden).
    2. Reset the iPod by holding down the Menu and Center buttons for 10 seconds.
      • If the Apple logo appears on the display, connect the iPod to a computer and verify that it appears in iTunes and can play music. If the iPod appears in iTunes and can play music, no further troubleshooting is needed.
      • If the Apple logo does not appear or the iPod is not seen in iTunes, connect the iPod to a power source by either plugging it into an Apple iPod USB Power Adapter or directly into a computer's USB port.
    3. Let the iPod charge for at least 20 minutes. Note: If the iPod is connected to a computer, make sure the computer does not sleep, standby, or hibernate during the 20-minute charging period.
    4. After the iPod has charged for at least 20 minutes and while it is still connected to the power source, toggle the Hold switch again as in step 1.
    5. Try resetting the iPod by holding down the Menu and Center buttons for 10 seconds.
      • If the Apple logo does not appear or the iPod is not seen in iTunes, try putting the iPod into disk mode and restoring.
    6. Try putting the iPod into disk mode.
      • While in disk mode, connect the iPod to iTunes and try to restore.
      • If the iPod is still not recognized by iTunes, the iPod should be serviced.
      • utting iPods with a Click Wheel into disk mode
        1. Before placing the iPod into disk mode, you should verify that it is charged.
        2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
        3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
        4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears.ht1363_2.jpg
        5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
        If you are having difficulty putting the iPod model into disk mode, set it on a flat surface. Make sure that the finger pressing the Select button is not touching the Click Wheel. Also make sure that you are pressing the Play/Pause button toward the outside of the Click Wheel and not near the center.
        If you are still unable to put your iPod with a Click Wheel into Disk Mode, use one finger from one hand to press the Select button, and one finger from the other hand to press the Play/Pause button.
    Jun 05, 2010 | Apple iPod nano
    Lost my manual for the NP 105CR Model Next Play IPOD Dock cube. Can't figure out how to turn off a radio alarm which comes on at odd times.
    The Alarm is controlled by the Set button. Press Set once, then press Function to cycle through Alarm 1 functions until the display reads OFF. If needed, press Set again, and press Function until Alarm 2 also reads OFF. Press Set a third time, and you can set the main time with the Vol +/- (minutes) and the Skip (hours) buttons. Press Set a fourth time to return to normal display.
    Dec 21, 2009 | Starlite Next Play Clock Radio with iPod...
    Alarm clock and time w/ clok smooth ipod system
    According to the instructions that we received with our clock. You should be able to get the Instruction manual from prodinfo@gpx.com. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
    However the "Operational Support" insert has the following:
    Setting the clock
    1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
    2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
    3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
    Setting the Alarms
    1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
    NOTE: An alarm icon will begin to flash on the LCD display.
    2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
    3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
    4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
    Nov 28, 2008 | Digital Products International Clok Smooth...
    Ipod first generation 5000 songs
    To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)ipodg1-2.gif ipodg3.gif
    1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
    2. Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
    If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
    If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
    When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
    Nov 12, 2007 | Apple iPod MP3 Player
    Sony NW-E105 doesnt turn on!
    Yes, I also suffered from the some problem. Have any solution
    Oct 09, 2007 | Sony Network Walkman NW-E105
    43 people viewed this question
     Grubhead
    Grubhead
