Question about Refrigerators
ED5LHAXMQ00 SP3242185 THE ICE MAKER WILL NOT SHUT OFF WHEN FULL
  • 4,066 Answers
The water inlet valve may be staying open. You can swap the wires on the dual water inlet valve and disconnect the water line at the valve which goes to the ice maker. When you try the water dispenser the water will come out there. When you stop the water dispenser, if the water at the valve doesn't stop, the valve isn't closing so you'll need to replace it. If it does stop after trying it several times then the problem is with the ice maker.
Posted on Jul 12, 2009
I have a GE refrigerator, model TPX24BPDA, that has an ice maker that won't stop making ice! Whatever mechanism that senses when the hopper is full isn't working. I can't locate any sensor either.
Ice Maker Doesn't Turn Off If your ice maker keeps making ice, even when it is full:
1Lift the bail wireto shut off the ice maker, and remove the ice bin. Then, using a screwdriver if necessary, remove the ice maker, clean it thoroughly, and then reinstall it.
2If the problem persists,consider removing and replace the entire ice maker and valve. With this type of problem, you can have it repaired, but it's often wiser and less expensive in the long run to replace the unit entirely.
Oct 05, 2016 | GE Refrigerators
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
Kenmore Elite Model # 795.7205 Ice dispenser pad does not always shut off when released
Feb 28, 2015 | Kenmore Refrigerators
Why won't the ice maker shut off even when I shut off the switch? The ice maker does not use a shut off arm or lever
Sep 05, 2014 | Kenmore Refrigerators
Ice maker won't shut off
Jan 26, 2014 | General Electric GSH25JFX Side by Side...
Ice maker shut off
Raise the arm on the ice maker to off position.
Jun 04, 2010 | Samsung RF265AA Bottom Freezer French Door...
The ice maker will not shut off on the LG refrigerator.
the internal switch that is supposed to shut the ice maker production off when the bucket is full has failed. Replace your ice maker
May 07, 2010 | LG 22.4 Cu. Ft. Bottom-Mount Refrigerator...
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker will not shut off
lift up on the shut off arm.it's the long wire on the side of the ice maker
Jul 07, 2009 | Kenmore 55693 Side by Side Refrigerator
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
