Question about Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger
I have to manually pull out the string on weed eater. it won't feed when I tap it on the ground
  • 76 Answers
SOURCE: How to string the weed eater
Hi check the link
the idea is the same for all trimmers
http://www.youtube.com/watch?v=WFu66Q6J62Q
good luck
Posted on Jul 16, 2009
  • 3600 Answers
SOURCE: WEED EATER STRING
you have the string in backwards, or the gear is not ingauged.
Posted on Aug 13, 2009
  • 420 Answers
SOURCE: how do i install the blades on my weed eater so i
There are many options out there but pretty much all of them require you to completly remove the line trimming head and screw on an aftermarket device. I use the bruch hog, the line trimmer and one with three nylon blades that are replacable (from Menards) and all work well but you do have to replace the blade too so it will not be the end all. If you are going through a lot of line may I suggest you run the trimmer at about 1/4 speed or just enough to do the job, it really saves a lot of line and frustration.
Posted on Jun 04, 2010
SOURCE: i have a weed eater twist & edge rte115 cant
how to string a weedeater/rtc115c
Posted on Jun 06, 2010
bbap
  • 71 Answers
SOURCE: manual
Typically 32:1 to 40:1 for all these models. Use 35:1 and modern 2 cycle oil and you will be fine. :)
Posted on Sep 25, 2010
Black & decker LST201 direction loading the string weed eater
when you are holding the spool on which you wind the string wind the string on in a anticlockwise direction
if it uses 2 strings ( one out of each side of the spool
wind in both strings together in the anticlockwise direction
that way , when you put the spool in the head and go to use it , the string is wound the right way to feed out and not get tangled
Sep 10, 2016 | Sewing Machines
Morrison weedeater
never saw your brand weed eater . but most weed eaters ,the string cap either unscrews or has plastic tabs that have to be pushed sideways with a flat blade screwdriver.If you have the plastic tabs ,be careful not to crack them off when pushing them sideways with a screwdriver--- so that the nub can clear the slot and get the cap off.
for better info call morrison customer service and ask.
phone # on weed eater and in owners manual. also , owners manual should have instructions under how to change string.
a pdf manual can be downloaded from morrison weed eater.
you will need to know your model number before morrison can help you.
Oct 06, 2013 | Garden
My weed eater (toro), won't let me pull the cord at all. This weed eater doesn't take oil I don't think.
All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
Mar 25, 2012 | Toro& Electric String Trimmer
I need a twist n Edge weedeater manual to find out how to put more string on the spindle
You can find the Poulan and Weed Eater instructions and manuals at InstructionSheets.com.
Here is a link to the page where you can download the Weed Eater RTE 115 Trimmer Manual.
Jun 26, 2010 | Poulan Weed Eater Rte115 4.5 Amp Electric...
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
WEED EATER STRING
Aug 13, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Poulan Weed Eater Trim Line Constantly Jams
Sounds as if the line is wound on the spool the wrong way, causing it to want to always feed string.
Jim
Jun 13, 2009 | Poulan Garden
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Poulan/Weed Eater No. Te475 952711797 17" Le Gas Trimmer/Edger Logo
177 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
