Question about Bosch Washing Machines
WFK 2401 CLOTHES WASHER. Washer will not agitate or spin. Local Bosch service man quoted $130-$150/ board (with copper wound motor on one board), that are located just under top of washer cover. He later called with quote of over $500 for both boards. I'd like to check on buying and replacing myself. Help! Tom
  • Tom Shupper Jul 12, 2009
    Here is number found inside door: WFK2401UC /01 FD 8005 34109. Are all of these required to identify the model? Our manual just says WFK 2401. I tried using WFK2401UC but was unable to get anywhere.
  • Tom Shupper Jul 13, 2009
    Yes. I apppreciate the solution from blueextc 3221.
    Not crazy about the price, but it's a Bosch.
    Thx.
  • 15,935 Answers
CLICK HERE for the boards associated with your washer.
They are plug and play once you get to them.
Not difficult to replace.
Thanks!!
Please accept this answer to remove it from the work Queue.
Posted on Jul 13, 2009
    President:
  • 1,865 Answers
Go to www.apwagner.com You will need your model number. This site shows the parts and how they are assembled
Posted on Jul 12, 2009
Bosch WFK 2401 impeller blockage
The pump uses an impeller to move the water into the drain pipe. Take the lower front off and you will see the impeller cover, behind the filter.
Jun 22, 2017 | Bosch WFK 2401
Hi, we have a Bosch washer model WFK 2401, in which we just replaced the door latch assembly and drain pump, and now it seems the electrical panel is going out. Since yesterday, when we push the...
Check with the repair man but I bet he didnt plug the panel back in all the way when he repaired it,maybe wanting another call. check it out
Feb 15, 2011 | Bosch WFK 2401
Bosch WFK 2401 - Washer fails to spin.
Check the carbon brushes on the motor.
Apr 20, 2010 | Bosch WFK 2401
I have a Bosch washer, model number WFK 2401 that washes and rinses, but suddenly won't spin. It just sits and counts down until the end of the spin cycle and then signals the end of the wash cycle as...
I just had the same problem last week Aug 1 2009
on our WFK 2401 purchased in 2001
If you hear no motor spinning when it should then it's something
with the motor. If you hear motor spinning, esp spin cycle, but
the drum doesn't spin, then probably broken belt ($30 part).
Since I work on cars (this is very much like an alternator+belt) and wanted to avoid a $100 service call (just to come to house) and
at least try for a quick fix before buying a new washer, I opened the back, confirmed belt looked ok, so tried
replacing the brushes in the motor, and it worked.
For a good description on how to do this see
http://dossy.org/2007/05/lots-of-miles-on-our-bosch-wfk2401uc-washer-motor/
I took some pics, and time permitting will post more details
to this dossy site to help fellow owners.
I purchased the brushes at partstap.com for $50 (incl tax+ship)
Aug 01, 2009 | Bosch Axxis+ WFR 2460 Front Load Washer
Installing carbon brushes on Bosch WFK 2401
Remove rear panel of washer.
Remove drive belt.
Unscrew the 2 bolts that hold motor to tub back.
Remove motor plug
Lever notor back with a screwdriver or similar, keeping a firm hold on motor.and remove motor
At the rear end of motor away from pulley you will see the brushes and the armature.
Remove brushes, and if there is less than 4 or 5mm of carbon left, then replace them.
Lightly clean the armature with emery cloth.
Refit in reverse order. Test.
Plz rate my solution.
Thanks.
Jan 12, 2009 | Bosch WFK 2401
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Bosch WFK 2401 problem, please help
this could be a block in the pump or motor brushes would go for the pump
Jun 22, 2008 | Bosch Classixx WFL 2462 Front Load Washer
Washer won't agitate
this sounds like it is a relay on the module (main pcb) if the carbon brushes have been fitted correctly then there is a fault on the module, these items are replaced as a unit, i would also look to see if the machine has a capacitor fitted, this also could have the same effect and would be a much cheaper repair to start with, a capacitor is normally situated at the top where the mains wire enters the machine, its normally about 2 inches long and 1 inch round with 2 wires from it, work with safety unplug before doing anything
Sep 09, 2007 | Bosch WFK 2401
Washing Machines Logo
42 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
