Question about Garmin GPSMAP 2006C GPS Receiver
Connecting a uniden 625c dsc vhf to a garmin 182c gps
Which wires go together
  • 3,037 Answers
Do you have a manual for the garmin? If not, you can find one at the following website link.
http://www8.garmin.com/manuals/GPSMAP182_182C_OwnersManual.pdf
On page 98, there is a diagram on how to wire the Garmin to the boat.
Your uniden would be wired like the GSD 20 beacon receiver shown on the bottom right of the diagram. I believe the diagram is pretty much self explanatory and is very good (Garmin always does a great job) but if you have any other questions, let me know
Benjamin
Posted on Jul 12, 2009
How to wire Uniden UM380 to Garmin 2010c for gps reading on radio
Garmins have USB or Data connectors - or both
obviously radio needs one of those inputs.
radio must be setable for Garmin format. If NMEA only verify Garmin is set to output NMEA - some do not have that option.
Aug 25, 2014 | Uniden UM380 Fixed Mount VHF Radio, White
Verify uniden solara dsc is receiving gps signal from lowrance elite 5
If the radio is receiving data from the Elite 5, (Owners manual, link below) Page 6 the GPS icon (#11) on that page will indicate it.
Hope this helps.
-Steve
http://www.uniden.com/pdf/SOLARA%20DSC-BKom.pdf
Jan 19, 2014 | Uniden Solara DSC VHF Marine Radio
Where can we go to get a wiring diagram for the wires that exit the radio. The green and yellow are together and orange and brown are together. Then two black
I realize this question has been here forever, but I've included the link to the Owner's Manual in case anyone requires it. Page 5 shows which wires go to/from external equipment. Orange (+) and the small black (-) are for your external speaker. Green is + for gps data in while the brown is GPS ground. Yellow is not used.
-Steve
Jan 27, 2012 | Uniden Solara dsc Vhf 2 way Marine Radio...
Hello, Can you tell me what make of GPS will work with the Icom m-504. I tried using the Garmin 76csx with the NEMA in/Nema out function set, but it will not communicate to the Icom. I would appreciate...
Hi!
We had the same problem with our Uniden Oceanus failing to communicate with our GPS. What the problem was, was that our VHF didn't recognize the NMEA sentences transmitted from our "ancient" GPS. We ended up buying a Standard Horizon cp180 chartplotter. PRESTO! Our DSC capability materialized.
Your 76CSx is newer than our Magellan was, so before you take on the task of a $400 chartplotter purchase, just make sure your BAUD rate is set to 4800. This adjustment alone could make your GPS work with your ICOM.
Hope this is helpful.
Jan 23, 2011 | Icom IC M504 Black Submersible PLUS Marine...
Connecting Garmin GPS 152 to VHF Radio Silva S15
Hi!
From the S15 owners manual (Page 46):
http://www.bluemoment.com/manuals/silva_s15.pdf
The RED wire is GPS data,
The green wire is GPS ground.
Hope this helps and good luck!
May 08, 2010 | GPS
I'm after the wiring diagram to connect a Garmin GPS17N to a Uniden Oceanus. Any ideas?
You wanted to charge me to provide a solution but now that I've found that solution, will you pay me to give it to you?
Feb 07, 2010 | Uniden Oceanus VHF DSC Radio White
Chartplotter (Garmin 450s) won't talk to VHF DSC radio (Icom IC M
As advised, reset to factory settings. Then re-entered custom settings as required. Seems OK now. Many thanks.
David Godfrey
Jun 16, 2009 | Garmin GPS
How to hook up an external speaker to uniden solara dsc vhf
the reddish-orange one and the brown one. The green and yellow ones are for data coming in.
Apr 08, 2009 | Uniden Solara Vhf Dsc Fixed Mount Radio
I have a Simrad CP32 mk2 chartplotter ,when VHF radio is switched to channel 10 no communication is possible due to heavy interference. Even a hand held radio independent of all electrical connections has...
I have a Garmin 182C and I get interfernce on VHF channels 21,22 and 83 the moment I turn on the Garmin. I have tried changing radios, antennas, placed separate poer and aground lines and nothing helps. Garmin gives me the run around.
Feb 23, 2009 | Boating
Garmin GPSMAP 2006C GPS Receiver Logo
138 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
