Question about Canon PIXMA MP190 All-In-One InkJet Printer
One sheet of paper is jammed in my printer canon pixma MP 190. What is your advice?
    Problem Solver:
  • 6 Answers
As with the majority of printers you should be able to open it by lifting the top on hinges or a panel in the back to gain access to the internals. After doing this if you can get a hold of the paper you have to very slowly work it out, use two hands if possible it should work free just be careful not to rip it. Also take a look in you manual it may have a trouble shooting section that can also be useful. Hope this helps.
Posted on Jul 12, 2009
MY CANON MP 190 IS PULLING IN THE PAPER CROOKED FROM THE BACK HELP?
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 27, 2010 | Canon PIXMA MP190 All-In-One InkJet...
I have a brand new canon printer mp 190 ---
It wants you to put in paper and press the resume key. When first turned on it needs to do printer alignment and for that you need a couple sheets of paper.
Jul 30, 2009 | Canon PIXMA MP150 All-In-One InkJet...
MP 190 Error Message E 2 2 after paper can't get it to work again
hello everyone...its just a simple problem....dun worry...1st, u hve to connect ur printer to other computer(not the same pc as u're using now)...then the printer will work fine...after tht..connect ur cable back to the previous computer(1st computer)...then ur printer will be fined!!!!!!!!!!! :) -darkrogue
Jul 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Under one year old pixma mp150 all in one/ changed ink cartridges/error code E2 / saying no paper ????
I have had a MP 150 Cannon Printer with a E3 paper jam code..when NO visable paper jam is present ! Your No paper problem may be as a result of similar issue due to a small piece of paper stuck in the roller assembly out of sight. TRY this, Turn printer off wait (10 seconds) or more then turn printer back ON and listen for roller assembly to turn the ROLLERS and then FORCE FEED
a sheet of paper into rollers until it PULLS paper through and SEE if any scrap of paper comes out with the sheet !! If this works you should see that it clears the code. and resets your printer.
Let me know if this works. Phil at palcando@yahoo.com
GOOD LUCK !
May 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma mp 160
After you remove the paper jam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 28, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon pIXMA mp 150
This is definitely a mechanical problem. You might want to at least partially take the printer appart and inspect it very thoroughly if you haven't done so yet. Did you have any paper jams before? Sometimes when you remove a paper jam the sheet rips and you end up with some shreds of paper lodged in the printer mechanism causing more jams. Another possibility might be cracked or bent paper guides, or simply dirty rollers (these you can clean with alcohol).
Aug 28, 2008 | Canon PIXMA MP150 All-In-One InkJet...
I have a Canon PIXMA MP 600. The paper doesn't feed properly anymore. Everytime I get an error: Auto sheet feeder. There is no paper load paper. I checked everything and there is no paper jammed. Is it...
Greetings,
If your are not loading from the ADF, check the settings and see if it is set to get paper from the Auto-Sheet Feeder.
Sometimes having an equipment repaired costs more than buying a new one.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 20, 2008 | Canon Office Equipment & Supplies
Canon printer
clean the feeder rupper or replace them
Jan 07, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
'paper jam' error on canon pixma ip4300
Hi guys, I eventually found a solution to the problem for my printer. With the top cover open, I pushed a sheet of 120 micron thickness A4 clear plastic binding cover through the exit tray as far as it would go to rest against the bottom row of rollers. I switched the printer off then back on again and as the rollers lifted momentarily, I pushed the sheet of plastic as far up through the machine as I could before the rollers went down again - it went in a fair distance. The printer then ejected the plastic sheet. I then put the plastic sheet into the paper tray and tried to print a blank document page. The plastic fed through cleanly and my printer has been working since without any error messages. I hope this works for you.
Aug 22, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Canon PIXMA MP190 All-In-One InkJet Printer Logo
205 people viewed this question
old marine
old marine
