Question about Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966
Trot Bilt 4 cycle weed eater catches, but wont run.
Pulled apart the carb, cleaned it, did it again, found a gasket/screen with junk in it, cleaned it. Now it will catch for just a second,but wont run. I cleaned every port I can find. Acts like a fuel problem, because when I prime the bulb, it will run for just a second. Some background: cleaned off the contacts on the spark plug, new air filter, good gas. This weed eater has seperate gas and oil. 4 cycle. I was running and weed eating when it just slowed down and quit. I found some sediment in the gas that I traced to the washers on the fuel filter, and have been working from there.
  • 130 Answers
Rebuild carb to fix problem.let me know if this help you.ok
Posted on Jul 25, 2009
Craftsman 29cc 4 cycle weed eater. Cranks but will only idle. Seems to bog out. Will only run in full choke at idle. Have changed gas and checked lines for leaks or stoppages. None found. Can not...
remove the sediment bowl on the bottom of the carb,but dont lose the gasket and watch out when the float drops so the needle and spring in the bore dont fall and you lose them,then clean out any dirt in the bowl and in the needle seat andget some carb cleaner and throughly clean out all openings in the carb,its a california carb thats why there are no adjustments
Mar 13, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Weed eater runs slower
Your air filter may be plugged, your pug may be fouled, or your carb may be gummed up.
Sep 10, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy Bilt 4 cycle weed eater - trimmer head doesn't spin
rotate attatchment head slightly while inserting driveshaft
Jul 30, 2009 | Garden
Want stay running
try ajusting carb did get better.if no rebuild carb and ajust carb again should fix your problem low needle 1 turn out and high needle 1 1/2 turns out this will get it runing and you might ajust again run full throttle to ajust high needle.let me know if this help you.ok
Jul 14, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
25cc weed eater, will only idle
double check your carb as it should have a screw for the fuel mixture. some carbs have a plastic piece over them that only lets you move the screws so far if you need more extreme adjustment they pull out about a 1/8th of a inch then you can turn in then push it back in, same principals as making a flame on a bic lighter bigger, if you cant find it take some pics of your carb and email them to me @ prerunnerrngr@yahoo.com and i will point them out
Jul 13, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Weed eater won't run
Sounds like you may just have a dirty carburetor.
Youwill need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to seedaylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jul 01, 2009 | Troy Bilt Tb70ss Gas Trimmer
My gas Craftsman Ez Fire 25cc 17 inch weed eater wont start!
The carb must be cleaned. take the carb off put it on a work bench and pull it apart layer by layer... be careful as there is a spring that will jump out. pull all of the gaskets off and clean behind them. make sure all of the passages are clean. Use brake cleaner from the auto parts store! do not use carb and choke cleaner as the gaskets will instantly expand and be useless. there is also a brass cylinder in the carb you need to remove it and clean it well. There should be a very small hole in the center. put it back together and you should be good to go
Jun 13, 2009 | Craftsman 25cc Gas Line Trimmer
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
No Gas to Primer Bulb
It sounds like the carburetor needs cleaned. Take the carb. apart and clean it with carb. cleaner. Use a Den Tech Brush, (used for cleaning teeth), they are perfect for cleaning the small ports in carb. If that still doesn't work, you may need to buy a carb. kit for your weed eater. If so, replace the gaskets and valve needle, and also make sure to replace the small screen. this should all come in the new carb. kit.
May 21, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Weed eater does not start
I had a similar problem with my troy-bilt weedeater. I tried replacing the sparkplug, replaced the fuel filter and etc. It still would not start. I looked at the troubleshooting guide in the owner's manual and it listed a possible cause as a clogged spark arrestor. I cleaned out the spark arrestor by taking it off and cleaning it with a wire brush. Now it runs like brand new again. I hope this helps.
Apr 08, 2009 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt 4-Cycle Curve Shaft Gas String Trimmer #41ADT41C966 Logo
1,080 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Wade Mobley
Wade Mobley
Mike Squire
Are you a Troy Garden Expert? Answer questions, earn points and help others
