Question about Cole Battery Disconnect Switch
Have 2 way switch. Want to disconnect one switch
Have 2 way switch. Want to disconnect one switch completely b/c it is covered by furniture. When this is done - the other switch doesn't work at all! How do I fix?
    Champion:
  • 225 Answers
The switch you want to remove is the power source for the switch you want to keep,you have to run power source to the switch you want to keep.
Posted on Jul 13, 2009
What is a duvet cover?
Normally you can say that duvet cover is a cover to protect duvet from using it. As we know that duvet is expensive is it is very difficult to clean it. But with duvet, we can protect our duvet cover from different types of dust.
If you want to buy it then you should buy egyptian cotton duvet cover with which you will get comfort. And it will also increase the look of your bedding as well as your room.
Mar 20, 2018 | Furniture
Model VC248. How do I remove cover to replace power switch?
[PDF]User Manual
www.cirrusvacuum.com/.../CR69A,79,99%20UPRIGHT%20MANUAL....
any openings or moving parts of the vacuum cleaner. I ... Cover 0 o l L I Hose cuff. Furniture lljm- 5 j. Guard _ u _"°-*_-'e"'"__ .' . ..... Cirrus wilt, at its option, repair or replace a defective vacuum or vacuum cleaner part that is covered by this ...
Sep 19, 2015 | Cirrus Vacuums
My windshield wipers on my 2000 Pontiac Montana won't stop as soon as I turn it on they start going I have tried turning it off of course but they just keep going
The switch is bad or the wiper motor cover ,electronics !
  1. Turn the ignition switch to RUN.
  2. Turn the wiper switch to OFF.
  3. Disconnect the wiper/washer switch connector C201.
Do the wipers park? yes or no ?
if yes Replace the wiper/washer switch. Refer to Multifunction, Turn Signal, and Hazard Switch Replacement - On Vehicle .
if no
Measure the voltage from connector C201 (vehicle side), terminal E2, to ground with a DMM.
Does the voltage measure greater than the specified value?
1.0 V yes or no ?
Replace the wiper motor cover. Refer to Wiper Motor Cover Replacement .
Did you complete the replacement?
Go to Step 9
6
  1. Reconnect the wiper/washer switch connector C201.
  2. Disconnect the wiper motor connector.
  3. Measure the voltage from the wiper motor connector, terminal D, to ground with a digital voltmeter.
1.0 V
Go to Step 8
Go to Step 7
7
Go to Step 9
8
Repair the short to voltage in CKT 113. Refer to Wiring Repairs in Wiring Systems.
Did you complete the repair?
Go to Step 9
9
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Go to Wiper/Washer System Check
if yes
Apr 20, 2015 | 2000 Pontiac Montana
My sister manages a funiture salvage store and this power lift recliner came in partly deassembly
When it comes to furniture, there are usually substitute parts you can find online. I would suggest trying to get a discount or partial refund depending on the payment situation. If it didn't come complete, you shouldn't pay the full amount. If worse comes to worse, you can find the same chair but run down and use its parts as substitutes.
Elisa Jed ' http://danielscuderi.com
Jan 18, 2014 | Coaster Furniture Power Lift Recliner...
The "leather" on my loveseat is rubbing off in areas of use.
The best thing you should do to solve this problem is to cover it up with best designer recliner covers.
You can get most attractive covers for recliner in one of the online platform which is Recliners Cover.
They would provide you all types of covers with best high quality fiber and also with water resistant fiber.
The top 3 covers available here are:
a. Sofa Shield - Furniture Protector
b. Furniture Fresh
c. Stretch Sensations
Oct 17, 2012 | Ashley Furniture Slater DuraBlend - Sedona...
How to hook up tool to clean upholstery
Keep your upholstered furniture looking fresh by vacuuming it regularly with the upholstery tool attached to your vacuum's hose. Prevent the fabric from fading (or at least delay this) by keeping your furniture out of direct sunlight -- close blinds, shades or curtains when the sun shines most directly through windows closest to the upholstery. And remove stains by blotting them with a dry cleaning solvent. Before steam cleaning your upholstered furniture, read the piece's cleaning code label to determine whether or not it is safe to do so. Then rent or buy a steam cleaner (also called an extractor) and follow the directions below.
  1. Rent a steam cleaner or purchase one; buy steam cleaner solution.
  2. Step 2 Vacuum the upholstery on the furniture you wish to steam clean; use the upholstery attachment to most effectively **** up loose debris.
  3. Step 3 Test the steam-cleaner solution on the upholstery in an inconspicuous place to ensure the color won't be steamed out or drastically altered.
  4. Step 4 Attempt to remove any stains with a stain removal or dry cleaning solution. Follow the directions that come with the product you choose for the best results, and allow the stain remover to dry before you begin steam cleaning.
  5. Step 5 Remove cushions and, if necessary, arm covers.
  6. Step 6 Gently apply the steaming water and cleaning solution in straight lines across the upholstery one section at a time.
  7. Step 7 Use the cleaning extension on the steam cleaner to **** up as much water as possible. The dirt will come out with the water.
  8. Step 8 Clean one side each cushion (then allow it to dry) before cleaning the other side. If the cushions are permanently attached to the furniture, clean them last.
  9. Step 9 Allow the furniture to dry completely before repeating the steam-cleaning process or replacing the cushions.
Jun 19, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
When i place my cup into the ice dispenser it won't shut off. just keeps spitting out ice for minutes.
Sounds like the actuator switch has moisture in it .
1 ) remove the top hinge cover from the freezer door and disconnect the plug there . This removes power to the door .
2 ) Use a small screwdriver under the dispensor control panel , and
pry outward , to remove the panel .
3) Disconnect the 3 plugs to the panel .
4) Remove the 4 screws holding the white dispensor cover on , and
remove the cover .
5) Push in on the cover arm , and you will see the switch which is
activated by the arm . Replace this switch .
6) With this cover off , look in the dispensor area , and make sure the
door flap snaps closed completely . If not , then this is where the
moisture is comming from , and the solenoid at the top right , is
probably rusted , and needs to be replaced .
re-installation is in reverse .
Sep 24, 2009 | Hotpoint HSS25GFP Side by Side...
AM I GOING TO GET ANY ASSISTANCE WITH MY PROBLEM? MY PRINTER IS NOT DOING ANYTHING. IT SAYS THE COVER IS OPEN BUT THE COVER IS CLOSED! CAN I GET SOME HELP OR NOT!
Hi There ,
don't worry .
Its pretty simple .
Resolution :
Switch off your printer .
Switch off your computer .
Disconnect the Printer cable from the printer and from the computer aswell.
Disconnect the Power cable from the printer .
Shutdown the computer completely .
And Restart teh computer .
If this doesnot work Uninstall /Reinstall the printer /
All the Best ...
Sep 23, 2008 | Lexmark Office Equipment & Supplies
Cole Battery Disconnect Switch Logo
298 people viewed this question
Top Cole Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Cole Electrical Supply Expert? Answer questions, earn points and help others
