Question about Microsoft Windows Vista Home Premium with Service Pack 1: Windows
Lost of Hibernation
Problem: KERNEL_DATA_INPAGE_ERROR
Technical information:
***STOP: 0x0000007A (0xC0403638, 0xC0000056, 0x4277F860, 0x806C7913)
***acpi.sys - Address 806C7913 base at 80692000, DateStamp 49c01a37
  • 39 Answers
His Stop message indicates that the requested page of kernel data from the paging file could not be read into memory. This Stop message is usually caused by a bad block (sector) in a paging file, a virus, a disk controller error, or failing RAM. In rare cases, it is caused when nonpaged pool resources run out. It is also caused by defective hardware.
User Action:
If the I/O status is C0000185 and the paging file is on a SCSI disk, the disk cabling and SCSI termination should be checked for problems. Check your computer for viruses, using any up-to-date, commercial virus scanning software that examines the Master Boot Record of the hard disk. An I/O status code of 0xC000009C or 0xC000016A normally indicates the data cannot be read from the disk due to a bad block (sector). If you can restart the system after the error, Autochk runs automatically and attempts to map out the bad sector. If Autochk does not scan the hard disk for errors, manually launch the disk scanner. Run Chkdsk /f /r on the system partition. Restart the system before the disk scan begins. If you cannot start the system due to the error, use the Recovery Console and run Chkdsk /r . Caution: If your system partition is formatted with the FAT file system, the long file names used by Windows 2000 can be damaged if Scandisk or another MS-DOSbased hard disk tool is used to verify the integrity of your hard disk from an MS-DOS prompt. (An MS-DOS prompt is typically derived from an MS-DOS startup disk or from starting MS-DOS on a multiboot system.) Always use the Windows 2000 version of Chkdsk on Windows 2000 disks. Another common cause of this Stop message is failing RAM. Run hardware diagnostics supplied by the system manufacturer, especially the memory scanner. For details on these procedures, see the owners manual for your computer. Check that all network adapters in the computer are properly seated. Use an ink eraser or an electrical contact treatment, available at electronics supply stores, to ensure network adapter contacts are clean. Check the System Log in Event Viewer for additional error messages that might help pinpoint the device causing the error. Disabling memory caching of the BIOS might also resolve it. Finally, if all the above steps fail to resolve the error, take the system motherboard to a repair facility for diagnostic testing. A crack, a scratched trace, or a defective component on the motherboard can also cause this error. For more troubleshooting information about this Stop message, refer to the Microsoft Knowledge Base at http://support.microsoft.com/support.
Posted on Jul 12, 2009
Computer clicks then shows the kernel data inpage error screen
I'm sorry to say but that sounds like a hard disk failure. Classic symptoms.
Run a diagnostics test using Seatools:
SeaTools Seagate
Mar 21, 2014 | ASUS Silver 15.6" Vivobook V550CA-DB71T...
My desktop is getting stuck so many times. It shows bluescreen and physical memory dump even when i tried to install new copy of windows. the error is technical error stop : 0X0000007A(0XCO7B9FB8,...
It can be a few things but usually the atapi.sys file is corrupt. If you can boot into your desktop, open the "run" box and type in "cmd". In that box type: sfc /scannow and press enter. There is a space between sfc and /scannow. You will be asked to put your Windows CD in the CD drive.
When did this problem begin? Have you installed a new harddrive recently? Have you installed new memory recently? Remove and re-insert the hardrive cables. Remove and re-insert the memory. Be careful about electro-static discharge. Sometimes just doing that will fix a bad connection.
Sometimes this error is caused by bad memory. You can download Memtest86 here: http://www.memtest.org/ Grab the prebuilt ISO.zip After downloading the file right click it and select "extract all" Use Img Burn http://www.imgburn.com/index.php?act=download to write the ISO to a CD. Keep the CD in the drive and reboot.
Also, there could be a problem with the hardrive. if you know the harddrive manufacturer you can usually go to their website and download their hardrive diagnostic software.
Sometimes erasing the hardrive (absolute last resort) will solve these kind of errors. Just be aware that you will lose ALL of your data and it mat not solve the problem. Darik's Boot and Nuke works good for that: http://www.dban.org/
Feb 09, 2012 | Computers & Internet
This message appeared " driver_irql_not_less_or_equal" TECHNICAL
Hello !
This system-halt message occurs when a process (in kernel-mode and not user mode) or driver tried to access a memory address to which it did not have permission. The most common cause is an incorrect or corrupted pointer that references an incorrect address in the memory.
When this occurs in a user-mode application, it generates an access violation. When it occurs in kernel mode, it generates a STOP 0x0000000A message. If you encounter this error while upgrading to a newer version of Windows, it might be caused by a device driver, a system service, a virus scanner, or a backup tool that is incompatible with the new version.
This error usually occurs after the installation of a buggy device driver, system service, or BIOS. To resolve it quickly, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. Choose the "Last Known Good Configuration" option. This option is most effective when only one driver or service is added at a time.
Usually, from my experience this rarely happens, but it is a buggy DRIVER installed by you.
Get back with more details please if it still happens. (Tip : Try to re-install all drivers using the manufacturer's website).
Aug 02, 2011 | Microsoft Windows XP Professional
Problem: KERNEL_DATA_INPAGE_ERROR Technical information: ***STOP: 0x0000007A (0xC0403638, 0xC0000056, 0x4277F860, 0x806C7913) ***acpi.sys ? Address 806C7913 base at 80692000, DateStamp 49c01a37
The KERNEL_DATA_INPAGE_ERROR bug check has a value of 0x0000007A. This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
Parameters The four parameters that are listed in the message can have three possible meanings. If the first parameter is 1 or 2, or 3 and the third parameter is 0, the parameters have the following definitions.
Parameter Description 1 The lock type that was held (1, 2, or 3) 2 The error status (usually an I/O status code) 3 If Lock Type is 1: the current process
If Lock Type is 2 or 3: 0
4 The virtual address that could not be paged into memory
If the first parameter is 3 (and the third parameter is nonzero) or 4, the parameters have the following definitions.
Parameter Description 1 The lock type that was held (3 or 4) 2 The error status (typically an I/O status code) 3 The address of the InPageSupport structure 4 The faulting address
Otherwise, the parameters have the following definitions.
Parameter Description 1 The address of the page table entry (PTE) 2 The error status (usually an I/O status code) 3 The PTE contents 4 The faulting address
Cause Frequently, you can determine the cause of the KERNEL_DATA_INPAGE_ERROR bug check from the error status (Parameter 2). Some common status codes include the following:
  • 0xC000009A, or STATUS_INSUFFICIENT_RESOURCES, indicates a lack of nonpaged pool resources.
  • 0xC000009C, or STATUS_DEVICE_DATA_ERROR, typically indicates bad blocks (sectors) on the hard disk.
  • 0xC000009D, or STATUS_DEVICE_NOT_CONNECTED, indicates defective or loose cabling, termination, or that the controller does not see the hard disk.
  • 0xC000016A, or STATUS_DISK_OPERATION_FAILED, indicates bad blocks (sectors) on the hard disk.
  • 0xC0000185, or STATUS_IO_DEVICE_ERROR, indicates improper termination or defective cabling on SCSI devices or that two devices are trying to use the same IRQ.
These status codes are the most common ones that have specific causes. For more information about other possible status codes that can be returned, see the Ntstatus.h file in the Microsoft Windows Driver Kit (WDK).
Another common cause of this error message is defective hardware or failing RAM.
A virus infection can also cause this bug check.
Resolving the Problem Resolving a bad block problem: An I/O status code of 0xC000009C or 0xC000016A typically indicates that the data could not be read from the disk because of a bad block (sector). If you can restart the computer after the error, Autochk runs automatically and attempts to map the bad sector to prevent it from being used anymore.
If Autochk does not scan the hard disk for errors, you can manually start the disk scanner. Run Chkdsk /f /r on the system partition. You must restart the computer before the disk scan begins. If you cannot start the computer because of the error, use the Recovery Console and run Chkdsk /r.
Warning If your system partition is formatted with the FAT file system, the long file names that the Windows operating system uses might be damaged if you use Scandisk or another MS-DOS-based hard disk tool to verify the integrity of your hard disk from MS-DOS. Always use the version of Chkdsk that matches your version of Windows.
Resolving a defective hardware problem: If the I/O status is C0000185 and the paging file is on an SCSI disk, check the disk cabling and SCSI termination for problems.
Resolving a failing RAM problem: Run the hardware diagnostics that the system manufacturer supplies, especially the memory scanner. For more information about these procedures, see the owner's manual for your computer.
Check that all the adapter cards in the computer are properly seated. Use an ink eraser or an electrical contact treatment, available at electronics supply stores, to ensure adapter card contacts are clean.
Check the System Log in Event Viewer for additional error messages that might help identify the device that is causing the error. You can also disable memory caching of the BIOS to try to resolve this error.
Make sure that the latest Windows Service Pack is installed.
If the preceding steps do not resolve the error, take the system motherboard to a repair facility for diagnostic testing. A crack, a scratched trace, or a defective component on the motherboard can cause this error.
Resolving a virus infection: Check your computer for viruses by using any up-to-date, commercial virus scanning software that examines the Master Boot Record of the hard disk. All Windows file systems can be infected by viruses.
Jul 12, 2009 | Microsoft Windows Vista Home Premium with...
Beginning dump of physical memory
This could be pretty complex. The ATAPI.SYS file controls the Hard Drive and CD-Rom Drive. I would recommend reading this MS TechNet article:
http://support.microsoft.com/kb/822051/ The article says that it's not uncommon for the problem to be caused by faulty memory or by problems in the mass storage controller subsystem, which makes sense since atapi.sys (a mass storage controller system file) is noted.
If you have multiple memory cards in the machine, it might not be a bad idea to take one out and try again. If the fails, keep swapping out memory cards until we either solve the problem, or elimite that as a cause.
Apr 21, 2009 | Computers & Internet
Bsod during windows installation
Try doing this as suugested, you might not need reformatting.
http://www.pcreview.co.uk/forums/thread-94921.php
Oct 22, 2008 | Gateway M350 Notebook
Blue Screen of Death
Click on the link below to go to this specific error on the Microsoft Support website:
http://support.microsoft.com/kb/314063/en-us
Oct 15, 2008 | Evga nForce 680i SLI (122CKNF68)...
Kernel stack inpage error
i have recently experienced my computer is shutting down with a message kernel stack inpage error when i play a high graphics games or playing video files
is this fixable
Feb 23, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Kernel data inpage error
It is best practice with a used computer to completely format and
clean-install Windows. In your case, this is what you definitely need to
do after performing some hardware diagnostics. Here are links that will
show you how to do a clean install and what you will need on hand:
http://michaelstevenstech.com/cleanxpinstall.html
http://www.elephantboycomputers.com/...alling_Windows
Jan 02, 2008 | Toshiba Tecra M1 PC Laptops
Microsoft Windows Vista Home Premium with Service Pack 1: Windows Logo
315 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
