I CAN NOT SEE MY NETFLEX
There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: Sony Bravia 40" LCD TV generating heat.
First, you will have to define what you mean by "hot to touch" ie.:
can you or can you not hold your hand on it for a few moments.
SOURCE: Sony Bravia TV went Blank
COULD BE LVDS CABLE LOSE OR NOT MAKING A GOOD CONTACT , IF IS NOT THAT UNFORTUNATELY IT WILL BE NECESSARILY TO REPLACE T CON BOARD
YOUR RATING TO MY ANSWER ITS HIGHLY APPRECIATE
THANKS
SOURCE: screw size for attaching stand for Sony Bravia LCD TV model# 46W4500
while the owner manual does not specify the length etc of bolts it does show there are 4 of them---look like find thread machine bolt---may be able to buy a few at the hardware sore or Home Depot---if the threads are inside the base take it with you as a guide.
http://download.sony-asia.com/consumer/IM/4106869131.pdf
pretty stupid as owner manual has everything including dimensions and weight etc but no list of bolts size.
