Question about Asko T721 Electric Dryer
I see where there is a condensation drawer but I cannot get the drawer open
    Problem Solver:
  • 17 Answers
After you have opened the drop down hatch, the condensor should pull straight out.
Posted on Mar 02, 2010
What is causing ice buildup under deli drawer?
condensation due to either clogged plugged evaporator drain hole line. or a bad door seal or seals allowing moister and air to condensate? then freeze as u may also want to check ur damper air flow to see if its to far open as per the freezing? even ur cold control thermostat may be set to high
Mar 21, 2015 | Refrigerators
My ice drawer will not come out it is stuck
Hello;
My name is Peter. I am a retired field service refrigeration technician.
I see this problem all of the time. That is why I recommend either a top freezer or side x side.
1.) You have guide rails on drawer type freezers. These become iced up to the point you can not open the door. If you try to force the door you may damage it.
2.) If the door is dot tightly sealed, condensate will get in the freezer. Hot goes to cold like a magnet. Hot air and cold air equals condensate.
3.) How do you fix the problem? Unfortunately, you can not get to the door guide rails to clean the ice of from them. You are going to have to unplug your unit to let the rails defrost to the point where you can pull the drawer. This can take up to 24 hours depending how badly the guide rails are iced up.
Feb 15, 2015 | GE Adora (DSF25KGTBG) Side by Side...
My sub zero has condensation forming inside the refrigerator
Hi - Did you take the vegetable drawers out to see if there is ice in back? If so, you might have a problem with the refrigerator seal. Defrost the ice and then check the seal of the fridge! If you don't have ice behind the drawers, still check to see if the seal is good. When you close the fridge door, it should be very hard to open if you try to re-open it quickly.
Jun 28, 2014 | Sub-Zero 650 / O Bottom Freezer...
My freezer drawers are very warm All food defrosted smells horrible even after cleaning. Should I clean condensor, temp is not cooling?
It is likely the condenser fan is not functioning, or the condenser is dirty. You may need to open the compressor access panel to check. If you can hear the compressor running, and the condenser feels warm, the fan should be running. If it isn't, it probably needs to be replaced. Another symptom is the area around the doors feels warm.
Jan 01, 2013 | Sub-Zero 700 Refrigerator Freezer...
My fridge-freezer (FFM90) has ice forming in the bottom of the freezer section under the last drawer. Why is that and what can I do?
This is due to excessive condensation and in bottom freezers due to proximity of the compressor.There is some residual water falling on to the drawers which forms the ice and this must be prevented. make sure that the frozen foods that was stocked did not loose water into the bottom till we can suspect the freezer. Also frequent opening of the freezer will allow for condensation whicj must be wiped out at intervals.
This can prevent some ice formation and also check if there is leak from the evaporator trays to the freezer during defrosting.
Sep 29, 2010 | Hotpoint FFM90 Bottom Freezer Refrigerator
About once a month my subzero refrigerator drawer (700 series) gets a significant amount of condensation on the underside of the bottom drawer. its enough water that it is puddling on the floor below and...
the condensation is caused by fresh vegetables and uncovered food,and of course opening the door,now you cant do anything about opening the door but.....(i put a kitchen tissue under the drawer for this very reason and change it every 5 days.)
Sep 11, 2010 | Refrigerators
Model 363.9668513 water collects under the fruit
this is because the plastic is shiny and attracts condensation,only "cure "is a piece of kitchen towel under drawer to mop up as/when.(when you open door all the cold air drops to the floor and is replaced with warm moist air from the kitchen.hence condensation.
Apr 13, 2010 | Refrigerators
My problem is that the two vegetable drawers are
if theres condensation on the walls too, check the door seal,it could be letting in warm air from outside,also if there are slide vents on these drawers open them so you get air flow
Feb 15, 2010 | Fisher and Paykel Fisher Paykel 21768 -...
Maytag Model MZD2768GE
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Oct 06, 2009 | Refrigerators
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Asko T721 Electric Dryer Logo
87 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
