Question about Dryers
The movers damaged the buttons on my he4t dryer.
We are looking to buy a HE4t dryer.we are told the movers damaged the buttons and now they are stuck. we haven't looked at it yet. what may i have to do to fix it? what would be the worse case senario ( control panel, maybe?) and cost estimate? where can i find the cost and parts for this dryer?
Thanks
  • 89 Answers
Go to www.searspartsdirect.com enter your model number and you will see a parts list with prices
Posted on Jul 12, 2009
Remove front panel
It was a broken dryer belt. Called Sears. No help ay all. No parts in the sears store.. Called Winklers Appliance 3705 Transport St., Ventura, Ca. 805.642.5103. Brought them the dryer belt. $ 18,95 . They told us what to do. Sold us a belt and we were fixed in 30 minutes at home, by our selves.
Mar 19, 2013 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore Elite HE4T standing water
I also have standing water after a wash cycle, but not immediately after. Given the history of very expensive repairs to this Kenmore HE4T washing machine, I suggest you do what I do, if the machine is still cleaning the clothes. Whatever cycle you use, try to be around when the machine finishes, so that you can turn off the water supply and remove the damp clothes to the dryer or clothes line. Turn on the water supply only when you want to use the machine. This works for me because I don't do many loads per week and my laundry area is right next to my kitchen. If it was in my basement, I'd have replaced it already with a top loading machine with mechanical not electronic controls.
Aug 21, 2012 | Kenmore HE4t 3.8 Cu. Ft. King Size...
How do you reverse the front door on a Kenmore HE4t washer?
The Kenmore HE4T washer does not have a reversible door. The matching dryer would have a reversible door.
Some newer washers do have a reversible door but it is still a very small number of washer that allow you to reverse the door.
You can not reverse the door on an HE4T washer.
Aug 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Kenmore HE4t gas dryer will not heat. One load
The Sensor for heating element cut-off is bad. It wrongly detects the unit is overheated so it signals to inhibit the gas valve not to open. Since it is not opened, gas is not burnt through the manifold hence not heat why the machine is tumbling. Good luck.
Apr 18, 2010 | Dryers
Kenmore HE4T Gas Dryer not heating
It can be tested using a mulitmeter or ohmmeter. Check for continuity. If it has no continuity, then it is defective. Hope this helped and best wishes.
Aug 29, 2009 | Kenmore HE4t 3.8 Cu. Ft. King Size...
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore he4t front loading dryer stopped working
did you clean the lint?
is the way the airflow goes not blocked with residue??
Mar 19, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
HE4t King Size Washer Balance Problem
remove the lower acess panel ( 3 screws across bottom) check for broen suspension/shock absorbers
Mar 02, 2008 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Kenmore HE4t Washer stuck in "controls locked" mode
you need a new cpu you can unlock door by removing bottom panel reaching up to the door lock and pulling a little ring on the bottom will manualy unlock the door
Nov 08, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Dryers Logo
Top Dryers Experts
