Question about Palm LifeDrive Handheld
When the lifedrive dies duo harddisk, there are
When the lifedrive dies due harddisk failure, there are any kind of solution available?, very thanks
  • 1,606 Answers
You have two options one is of course a replacement drive but the other is replacing the little hard drive with a flash disk. The flash drive is nothing more than a 4gb compact flash memory card that happens to use the same connector as the Hitachi hard drive. Of the two I'd go flash myself.
The flash disk is faster and uses far less power so your battery life can increase by quite a bit. I think it is something like 10% of the power. Next to the display this is the single biggest power item. I've heard of the useful battery life increasing anywhere from 3x to about 6x after doing this. You can get the drive or flash from several places online. These are the same CF cards as used in many cameras. Most also offer the installation service.
Here is a link to one place but do a few searches and compare prices etc. Just search for lifedrive, flash, drive or lifedrive hard drive replacement and you should get quite a few.
http://www.usedpdaparts.com/Lifedrive.html
Posted on Jul 22, 2009
PXE-E61: MEDIA TEST FAILuRE, CHECK CABLE PXE-M0F: EXITING NVIDIA BOOT AGENT. REBOOT AND SELECT PROPER BOOT DEVICE
Hope this helps. I assume cable is good, try to listen by drawing your ear nearer to the disk. The normal sound of the harddisk as the disk spindle comes to work when given power, a uniform thin sound of rotating motor. The abnormal rotations sounds like initializing motor-kicking and died down in cycle or it gives audible clicking sound due to arm-head drive coil initialization failure, it may also give a scratching sound when the tiny head crashed against the disk. By then, this audible signs gives us hint that the harddisk has a fatal error. However you can try another good cable, attaching it to another sata port, power connector and trying it to run on another pc. Hope it gives good signs that your disk is alive.
Mar 08, 2014 | Seagate Technology Barracuda 720012...
My laptop show a disk error orrur how to fix
Harddisk failure. Claim warranty if still available.
No warranty then buy a new harddisk, swap it and re-install OS.
Oct 28, 2013 | eMachines D620 Laptop
Wifi connection issues with Palm One LifeDrive
It sounds like you need to setup the network settings on the palm or the wep or securty key or both.
When it shows the network id tap edit then enter the wep or wpa key if needed, then tap details to get to the screen where you enter the normal network details.
Usually it is just the security key that causes this. Get that code in and you might pop right on.
Dec 09, 2009 | Palm LifeDrive Mobile Manager Handheld
My computer didn't recognize my harddis
Ok, the data may not be lost.
Need info:
- what kind of HD
- what operating system you use; windows?
- what kind of HD, is it a SATA drive?
- When you boot, (windows) do you see the drive (the faulty one) note the drive make and model number
- is this the BOOT drive or you just use it for data?
Apr 09, 2009 | Western Digital Caviar 40 GB Hard Drive
Lose of Master Harddrive
have a check with the BUS cable once try replacing the BUS cable which is connected to the HARDDISK .. there may be some problem in the IDE BUS CABLE...
you can fix that by replacing with the new one ...
this problem is not where related to BIOS ..
because if there is any problem in the IDE BUS CABLE means you will face this problem ..
there is one more case it is not oftenly seen actually ..
ie if there is any problem in harddisk means you will face this problem ..
normally the harddisk will work without any problem for 10+ years ...
in very special cases the harddisk failure occurs which is called as catastrophic failure ie the harddisk makes some hissing noise before when it attempts run , this problem may be due to some manufacture defect or if the harddisk is not being used for a long period of time (may be years) ...
so just have a check with things everything will be alright ..
thank you
bye
any doubts you can reply me
i am always here to assist you
please rate my solution
have a nice day
Sep 02, 2008 | MSI K8MM3-V Motherboard
Palm LifeDrive Upgrade Results
No need to reset.
Usually the update does the opposite of all of that. What has probably happened is now all of your settings have been set to defaults. So you should check the power off times and make sure what you don't use is turned off. For example if you have bluetooth running it is continually trying to connect to each and every bluetooth device it finds. If you are near other people ie a mall in a office then it will be on continuously. Next to the power used by the harddrive any of the radios wifi/bluetooth draw the most power. Turn it off until you need to use it. Same for the infrared port.
As for the speeds that due to the same thing it was reset back to the default slow speed. Go to prefs
under available connections find Cradle/Cable that's the usb cable. Tap edit. On the next screen tap details. Set the speed up as high as it will go with the flow control to automatic. That will speed up your connection by quite a bit. If you plug into a USB 2.0 port you will transfer much faster than that setting.
You may find other settings are changed as you use the LD. It will work better than before but you have to tweak it. Oh and downloading the desktop won't help.
Aug 27, 2008 | Palm LifeDrive Handheld
Palm lifedrive frozen 'secure erase'
You may be experiecing failure of the microdrive. Those are typical of it failing or having failed.
Having said that have your tried the hard reset buy holding the 5 way down while sliding the power switch? This is slightly different than the older secure but you need the update 2 to have it. This will erase and reformat and reload the entire system a bit more thouroughly than the older secure erase.
It might get you out of the cycle which is more important.
Feb 16, 2008 | Palm LifeDrive Handheld
Palm LifeDrive
just press the time in the top left hand corner of the lifedrive and a dropdown menu comes down with the option "delete" but this is only for apps. if you want to delete media files, search for a file manager on freewarepalm.com
Apr 21, 2007 | Palm LifeDrive Handheld
My harddisk doesn't turn on...
We call them in the industry Death Stars! I have had several just die on me! If the drive does not show in the BIOS then you can't do a low level format! All the ones that have died on me have burnt out components on there circuit boards. Way to small for me to solder! So they were thrown away!
Mar 18, 2007 | Hitachi Deskstar 7K250 80GB...
Dead Lifedrive
I im not mistaking this unit has a 1 year warrantee. I would contact the #v below to see how to get this back up and alive. Good luck 847-262-PALM
Apr 15, 2006 | Palm LifeDrive Mobile Manager Handheld
Palm LifeDrive Handheld Logo
297 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
