Question about Mitsubishi WD-73827 73" HDTV DLP TV
My tv turns blue and turns itself off
My 73" mitsubishi had the lamp replaced about 6 month ago, worked good but now it will turn itself off and the screen goes blue after sometimes 10 mintues or 10hrs.??
  • 643 Answers
Optical block assembly going bad. repair is pretty costly. try vacuming out the fans. DO NOT USE CANNED AIR!!!! you will blow all the crud into the optical block.
Posted on Jul 12, 2009
After replacing bulb on WD-82738 still not working
How to replace the lamp in your Mitsubishi TV - YouTube
? 3:13
https://www.youtube.com/watch?v=_ONPuB5L-x4
Nov 1, 2012 - Uploaded by Mitsubishi3D
Your Mitsubishi television is powered in part by a 180 watt lampthat illuminates your TV's vivid colors. ... The first time they delivered my TV it was broken. ... I just barely got myreplacement bulb in today and it still only blinks orange light. .....I was watching my mitsubishi 73 3d model wd-73740 and ...
After replacing bulb on WD-82738 still not working - Fixya
www.fixya.com/.../t26028385-after_replacing_bulb_wd_82738_still_no...
6 mins ago - after replacing bulb on WD-82738 still not working bulb went out and burning smell. Replace the bulb, turned it in - Mitsubishi WD82738 82 ...
Mitsubishi WD-82738 Blinking Green Light - Tom's Guide
www.tomsguide.com/.../id.../mitsubishi-82738-blinking-green-light.html
Jan 12, 2015 - I have a Mitsubishi WD-82738 with the blinking green light of death as I have seen it called. ... Sounds like you replaced the parts, and it still is not working.... It would not work for us if we did it after the blinking. ... overnights. an ive already t akeing out the bat Forum; blinking green light changed bulb help!
Amazon.com: Mitsubishi WD-82738 DLP TV Asse
Dec 29, 2015 | Mitsubishi WD82738 82 1080p 3D DLP Home...
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
Tv turns off by itself with an amber or red flashing light. lamp replaced about 6 months ago.
Should be a high voltage or power circuit problem,like transistor too hot,or any component short circuit.
Oct 29, 2012 | Mitsubishi WD73737
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
The lamp has just been replaced and now the tv will only stay on for 30 minutes and then turn itself off. The lamp indicator light is red. We can turn the tv back on and the light goes off. Six months ago...
Did you press the System Reset button with a ball point pin on the front of the set? You might have a ballast going bad if it has never been replaced. But first, the reset button then you may have a thermal switch which is located just above the lamp housing. I test the thermal switches by unhooking (while set is unplugged) one of the wires and then putting an alligator clip jumper between the two wires to see if it last longer than the 30 minutes you mentioned. Lastly, there must not be any dust in and around the fan which can cause overheating. Sounds like you have an overheating problem initially. The thermal switch cuts the set off if there is overheating. And also if the switch is faulty it will cut off the set. Also look in the menu for a temperature setting if this model has a setting such as this.
May 24, 2011 | Mitsubishi WD73727 73" HDTV
I have a wd-73833 when i turn on the tv the front blue lights come on after a minute the tv turns itself off, there is no picture
I would check your lamp 1st. Do you have a lamp light flashing on the front of your set after TV shuts down? That is a message to let you know what might be wrong.
Apr 05, 2011 | Mitsubishi WD-73833 73" HDTV
I have a mitsubishi wd65737 it will not turn on green light on front just flashes then turns off i called mitsubishi they said the ywould sent me a up date 6 days ago to my email can you help ...
If you get audio, the lamp needs to be replaced. Refer to the manual as to how to replace the lamp to confirm. Contact Mitsubishi for a replacement. Cheapest available and is OEM.
Nov 21, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
LAMP JUST WENT OUT
I have a 57" DLP and have replaced the bulb 3 times in 2&1/2 years. I'm not possitive but I think I have 6-800 hrs on it total. Mitsubishi claims it a part they expect to go out, but the told me they typically last about ten yrs. If you have proof of purchase they will send you a new one for free, otherwise it'll cost you about $150 on ebay.
May 29, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
TV shuts itself off after a couple minutes of being on.
One must be very careful of the quality of the replacement lamp. Many of the cheap 'deals' on the web for replacement lamps are substandard. I always recommend that replacement bulbs be the original manufacturers bulb.
Apr 30, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD-73827 73" HDTV DLP TV Logo
784 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
