Question about Sharp R-308KK / R-308KW 1100 Watts Microwave Oven
R-308KW unit emits a high pitched whining sound when started on cook mode. Does not seem to cook.
    President:
  • Sharp Master
  • 1,922 Answers
Sounds as if the magnetron is dying,the only other thing it could be is the large main power transformer,but they usually have a low growl when mag is drawing current,also it could be a loose mechanical joint setting up a mechanical harmonic,but i'll bet its the mag...good luck
Posted on Jul 27, 2009
Noisy microwave on first Start... Not noisy on subsequent Starts
Does it sound like a fan blade rubbing?
Can you make a short video and upload it or share with me directly?
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Feb 18, 2017 | GE Microwave Ovens
I HAVE WHINING NOISE FROM UNDER MY HOOD 2006 FORD 500
Well I don't think it's your microwave. Check all idler pulley bearings, alternator bearings, a/c compressor bearings and tensioner pulley bearings by placing long screwdriver on unit, then place ear to screwdriver handle. Careful not to get it caught in the pulleys. You will hear the high pitched whine in the bad unit or pulley.
May 10, 2014 | Microwave Ovens
I have a Kitchenaid YKHMS147HW microwave that started turning on by itself, and will not shut off unless I unplug the unit. If I put food in to cook, the food starts cooking as soon as I plug the unit in,...
Sounds like stuck relay contacts. Magnetrons need a high voltage source which is controlled by a micro to relay and then from relay to voltage source. Even the turntable works via a relay.
Oct 14, 2013 | Microwave Ovens
Vibrating noise when cooking
In order to try to set your mind at ease I will have to explain the Basics on how a Microwave Oven Functions.
When a Microwave Oven is set to COOK ...START. It cooks at 100%. There is no lowering of the heat as with a Range ( Cook Top) Control. So in order to do the other things such as DEFROST, WARM, or anything other than 100% COOK. A COOK ON- COOK OFF system was utilized. To DEFROST, the Microve COOKS at 100% for 30% of the TIME, then IDLES for 70% of the TIME. COOK ON 30% of the TIME, COOK OFF 70% of the TIME = DEFROST This is why you can hear the CYCLE. More power is required during the ON CYCLE, thus the lower vibration. The Vibration occurs when the High Voltage Transformer is turned ON ( COOK ON).
The VIBRATION seems to have got louder with age. This is somewhat normal as there is a vibration from the High Voltage Transformer present every time the Microwave is used. screws and other metal parts seem to get loose with this vibration. There is no solution, unless you can tighten EVERY screw, nut, and bolt in the unit.
Sorry!
Dec 07, 2007 | Kenmore 62642 / 62644 / 62649 Microwave...
Kenmore 721.63662300, 1200W
The magnatron is shorting and overloading the high voltage transformer which is complaining with a load noise. Worth fixing if you do it your self. Magnatrons cast about $40 wholesale. There are just a few varieties of them that fit almos all brands. Try www.partstap.com
Dec 07, 2007 | Kenmore 62622 Microwave Oven
Jvm1440bd Microwave
I thought I had answered this, but maybe the reply didn't post... Vent cap? Could you be more specific about what you tried and what the noise is like - where it seems to be coming from? It looks like on some of these models, the high-voltage section emits some interference which some people are blocking with a foil or metal shield. If they do that, they should definitely insulate it to prevent shorts. Another cause of vibration on these models is a fault in the stirrer located above the cover on the ceiling inside the cooking cavity. Feel free to post back so we can help further.
Jan 08, 2007 | GE JVM1410 Microwave Oven
Constant Humm / Buzz but Works OK
I was going to suggest the low voltage transformer, but when you said it sounded like it was coming from the left side, that seemed odd. I have a stock transformer here I keep for test that is loud, but it works. Odd, eh?
Dec 21, 2006 | KitchenAid KHMS155LSS 1000 Watts Microwave...
High pitched hum/buzz
By high-pitched, you mean it is not that same frequency as when it's cooking? Is the tone near or the same as the beep you hear when you press a key? Please post a little more information so we can help better.
Nov 27, 2006 | Kenmore 66469 / 66462 / 66464 Microwave...
Sharp R-308KK / R-308KW 1100 Watts Microwave Oven Logo
170 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
