Question about Camping, Backpacking & Hiking
We can't get the motion on our flood lights to work, what are we doing wrong?our flood lights will go on with the light switch; however, they remain on all the time and will only go off when turned off.
    Scholar:
  • 113 Answers
There are different selections on a flood light that you have to adjust. It is possible the you have it in test mode right now and when you flip the switch you are sending powering to the flood and it will stay on because it is in test mode. If it is not in test mode and you have it in the normal operation mode you may have the sensitivity set to high. If there are bushes near, running water, or anything that is moving quite a bit all the time it's going to stay on. Also, depending upon how old the flood is. It may simply need replacing. I would check the first two items and go from there. If you become completely stumped, a good electrician should be able to problem solve this very quickly. I have been on a few service calls where simply the flood was bad and needed to be replaced. I hope this helps.
Posted on Jul 31, 2009
Wiring a brinks motion sensor light, wired red wire to black wires but light doesn't work as it should, what's wrong.
Black from power supply goes to black from sensor. Red from sensor goes to both blacks from lights, all remaining whites go together.
Aug 19, 2014 | Electrical Supplies
I have motion sensor flood lights that are not turning on. I put it on test & it does turn on. But when switched over to 1, 5 or ten minutes it won't turn on. The red light on the sensor does turn
April, you didn't mention whether you did the test at night. In addition to motion sensing, the flood light also detects darkness before allowing the bulbs to light up. If it is night, check also that some other light source is not illuminating the sensor. If so, that could fool the sensor into thinking it is daytime.
Mar 03, 2014 | Electrical Supplies
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
Motion sensor outdoor light won't go off
How long has this been going on? Has this light fixture been updated recently? Has the lite switch been changed that operates this fixture?
Feb 23, 2013 | Cooper Lighting regent light BRZ Motion...
Motion sensor light not tripping off
If new, then it could be faulty. If old, then may have water damage.
POSSIBLE CAUSE
1. Light switch is turned off.
2. Flood lamp is loose or burned out.
3. Fuse is blown or circuit breaker is turned off.
4. Daylight turn-off is in effect.
5. Incorrect circuit wiring, if this is a new installation.
6. Light control aimed in wrong direction.
SOLUTION
1. Turn light switch on.
2. Check flood lamp and replace if burned out.
3. Replace fuse or turn circuit breaker on.
4. Recheck after dark.
5. Verify wiring is correct.
6. Re-aim light control to cover desired area.
Sep 04, 2011 | Heath Zenith Secure Home Motion Activated...
HOW DO I SET THE TIMER FOR MOTION SENSOR LIGHT SWITCH
Straight from the manual: (As you are facing the switch, the light level adjustment is on the upper left. The time selection is on the lower left.
1. With power restored and wallplate removed, use your finger or a small screwdriver to adjust the light sensitivity and time settings on the device as follows:
Light Level Adjustment:• Turn the control towards the "+" sign. Lights will turn ON in lighter conditions.• Turn the control towards the "-" sign. Lights will turn ON in less lighting conditions.
Time Selection:• Adjust the time selector to the desired length of time the lights are to remain ON. Lights will remain ON from15 seconds to 15 minutes after the room is vacated.
• Turn the control towards the "+" sign. Lights will remain ON up to 15 minutes.
• Turn the control towards the "-" sign. Lights will remain ON up to 15 seconds.
2. Test that the light level and time selection are as desired. If not, repeat adjustments until satisfied.
The manual is here:
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=8018§ion=17219&minisite=10022
Feb 24, 2011 | Leviton R01-PR180-1LI Decora 180 Degree...
Have Cooper lighting outdoor motion detected flood
Sounds like the relay in motion sensor. Change the bulb. Rechargeable batteries are no good after 3-4 years also.
Jul 18, 2009 | Desa International 240 Deg. White Twin 150...
Flood light has faint glow at all time
Sounds like you have the Dual Brite on, the dual brite is low level accent lighting. Check to see if you have this switched on, if so turn it off.
Mar 12, 2009 | Heath Zenith SL-6136-WH Basic Solutions...
Flood lights take a very long time to come on
Insure you are using a standard flood light on motion sensor lights and not a florescent energy efficient flood light as they take longer to reach full brightness as the bulb filiment warms up. They are better suited for constant lighting rather than intermittent purposes such as sensor lights.
Good Luck
Nov 21, 2008 | Heath Zenith Electrical Supplies
Camping, Backpacking & Hiking Logo
80 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
