Question about Radio Shack Pro-94 Scanner
162.550 NOAA weather frequency
Hi There, For some reason my Pro-94 1000 Channel Scanner has a problem receiving the above mentioned frequency. It will lock on the frequency, talk about 3-4 seconds and then just quit talking.
I have had the Pro-94 for several years and never had a problem before this started about 2 weeks ago.
Any ideals would be greatly appreciated.
The other frequencys work ok, its just the weather ones that I am having trouble with. I have tried new batteries, and I have the adapter to use with electric, but neither helped the problem.
  • Anonymous Sep 04, 2008
    My 6-year old nephew "reprogramed" my unit and now we can't get the weather on NOAA --- it won't program in, any ideas?
You may also have pressed the ALT button, which will put the scanner in ALERT mode, esentially turning it into a weather alert radio. The weather frequencies will remain silent until the NOAA station you are listening to issues some kind of watch/warning or weekly test.
Posted on Jul 10, 2008
I had this problem also. It appears that in my case the problem was that I had accidentally pressed the trunk button while accessing the weather frequencies using the SVC function (E button). Pressing it again while scanning weather frequencies when using the SVC function will clear the problem - if that is the cause.
Posted on May 23, 2008
  • 204 Answers
If your still having the problem, it could be that the transmitter for that freq lost some of it's power, so your scanner cannot pick up a clear signal. If everything else is working ok, that's my guess. Hope this helps,,, Mechanic
Posted on Jan 24, 2008
Can't seem to get any activity even after programming some frequencies in to it(BC72XLT)
Are you sure that the frequencies you programmed are active in your area? Try a weather band search (press Func and Svc) to verify that the scanner is working properly. If you receive one or more NOAA weather broadcast channels then you need to visit and check their database for active freqs in your area. If you cannot receive weather then you have an antenna or receiver problem.
Bill B.
Listening in since the 60's
Oct 14, 2010 | Uniden BC72XLT Handheld Scanner
My pro 2018 scanner wont pick anything up where i live could there be something wrong with the scanner or do i need a better antenna i live in holmes county ohio
First try picking up the NOAA Weather broadcasts. They're transmitted on seven frequencies (162.400, 162.425, 162.450, 162.475, 162.500, 162.525, 162.550) and at least one should be active in your area. To check reception, just press the WX key on your scanner. If you can pick up one or more of the frequencies, you'll know that the scanner is functioning properly. If not, your scanner is likely in need of repairs - a questionable move due to its age.
If the scanner is functioning (receiving the weather band), try a quick RESET. use a paperclip or pen point to press the recessed RESET button on the back of the scanner.
Make sure that you have programmed local active frequencies into the scanner. For a comprehensive database, and a lot of other useful scanning information, visit:
After all of the above, if you are receiving weather but no local transmissions, I recommend that you try an external antenna.
If you need the manual for your scanner, you can download and print it, at no cost, here:
Bill B
Sep 28, 2010 | Radio Shack Pro-2018 Scanner
I need to program a weather scanner for a pro 2018 weather scanner from rdio shack
Weather frequencies are factory programmed into the PRO-2018. Just press the weather button to start scanning them. You can also program one or more manually if you wish. For a list of NOAA weather broadcast frequencies, follow this link:
Need the manual for your scanner? You can download/print it here:
Bill B
Sep 05, 2010 | Radio Shack Pro-2018 Scanner
The NOAA weather frequencies have constant broadcasts, so your scanner "locks" onto them. The only ways to prevent this are to either delete the weather frequency or lock it out. To delete, just program the frequency "0.0" (zero point zero) into the channel. To lock it out, press the L/O key while on the weather freq.
Bill B
Aug 06, 2010 | Radio Shack Pro-84 Handheld Scanner
Scanner not picking up local police-Fire freq
Do you still receive NOAA weather frequencies? Sounds like your local agencies have switched from simplex/standard frequency operation to trunking. I suggest you visit to view the latest on active frequencies and systems in your area.
Bill B
May 17, 2010 | Radio Shack Pro-94 Scanner
I have a bc350c 800 mhz and cant get nothing but static how to i get the police channels to work
Try tuning known frequencies, such as the NOAA weather channels, to verify the working condition of your scanner. If it picks them up, you don't have your local police system/frequencies programmed properly. If there's no reception, even on NOAA, you have an antenna or receiver problem that may need professional attention.
In case you need it, you can download/print the manual for your scanner here:
For a comprehensive database of active frequencies in your area, visit:
Bill B
Apr 27, 2010 | Uniden BC796D Base Scanner
Scanner scans but will not pick up traffic
You didn't mention the scanner model, your location, or any specifics that could could help focus in on the problem, but here are some general guidelines for scanning:
1. Make sure that the scanner powers on from either AC power or batteries and that you have a proper antenna connected..
2. Check basic operation by turning the volume about halfway up and then rotating the SQUELCH control in both directions. You should hear a loud hissing noise. If you cannot hear anything while doing this the scanner is in need of professional repair.
3. Check scanner reception by programming a NOAA Weather frequency. 162.550MHz is the primary in most areas, but 162.400, 162.475, 162.425, 162.450, and 162.500 are other possibles). If you receive weather broadcasts on one of these frequencies, the scanner is working. If not, it probably needs professional repair.
4. If it passes the above tests, you need to make sure that you've programmed the right frequencies into the scanner. These will vary by location, and for a comprehensive database of active frequencies in your area, visit:
I hope that this information helps. If not, please get back to us with specifics and we will do our best to get the scanner working for you.
Dec 13, 2009 | Uniden Radio Communications
Hi and welcome to FixYa,
I am not aware of any computer receiver ported for USB connection capable of 162.550 MHz; almost all are regular FM band. There are however amateur/ham radio equipment that could be interfaced with the PC that covers 136 to 174 Mhz.
If your requirement is to be able to monitor NOAA weather broadcasts, it might be simpler to use Internet Radio/audio streaming. NOAA addresses this particular issue here and here among others.
Good luck and thank you for using FixYa.
Jan 30, 2009 | Radio Shack Pro-94 Scanner
Pro-94 will not recieve
I would make sure you have
the new frequency # put in scanner
GOOGLE free new scanner frequency #
put in your town and city.
Jan 29, 2009 | Radio Shack Pro-94 Scanner
Need to unlock our radioshack pro 2018 200 channel desktop scanner
Easy to use right out of the box!
Explore preset frequencies used for non-trunked police/fire, aircraft, marine, NOAA weather and more. Just attach the antenna, switch it on and touch one of five buttons. With just two keystrokes, you can store a frequency you find in the 200-channel memory for later scanning or monitoring. You can also search for activity in frequency ranges you specify or program known "action" frequencies on the keyboard.
  • 1-touch search lets you find police/fire, HAM radio, marine and 7 NOAA WX frequencies fast
  • Built-in weather receiver sounds an alarm when your NOAA weather station sends an alert
  • 50-frequency search skip locks out undesired frequencies
  • Programmable by computer (requires Scanner PC Programming Kit #20-048)
Aug 06, 2008 | Computers & Internet
Radio Shack Pro-94 Scanner Logo
423 people viewed this question
Top Radio Shack Radio Communications Experts
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
