Question about HP OmniBook XE3 Notebook
Black screen and 3 loud beeps when starting up and recharge light off when charger is connected.
    Sergeant:
  • 361 Answers
1/long beep followedby 3 sequential short beep- graphic card problem2/shortbeep followed by three sequential long beep- system memory problem thanks
Posted on Jul 12, 2009
K850i red light turn on when charger or usb cable plug in & the phone does't start
I just bought a T303 Sony Ericsson I pluged it in to recharge it and a red light come on but no light come on the screen when Iunplug it from the charger.
Aug 22, 2013 | Sony Ericsson T303 Mobile Phone (Shadow...
Inspiron mini 1018 blank screen with light behind, loud beeps, strange smell
I have green screen solution where now it changed to whole black screen with some red line and produce a sound like TV Signal..I don't know everthings about repair my netbook..What should i do?
May 29, 2012 | Dell Inspiron 1018 Notebook
I m not able to connect my BH 208 headset to nokia E71 set
Make sure that the headset is properly charged before following the instructions below.Please follow the detailed instructions in the correct manner to successfully pair your Nokia E71 with the BH-208 Headset.
Charge the battery
The headset has an internal, non removable, rechargeable battery.Do not attempt to remove the battery from the device, as you may damage the device.
1. Connect the charger to a wall outlet.
2. Connect the charger cable to the charger connector. The red indicator light is on while charging.
It may take a while before charging
Switch the headset on or off
To switch on, press and hold the power key until the headset beeps and the green indicator light is displayed. To switch off, press and hold the power key until the headset beeps and the red indicator light is displayed briefly.
Pairing the headset
1. Ensure that your phone is switched on and the headset is switched off.
2. Press and hold the power key until the green indicator light starts to flash quickly.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone. In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the headset beeps and appears in the phone menu where you can view the currently paired Bluetooth devices.The headset is now ready for use.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex.
Jun 14, 2011 | Nokia BH-208 Wireless Headset
My noteboock wont start only 4 beeps and black screen all leds ok
The last time my HP did that, I just plugged the AC charger back in and recharged my drained battery.
Feb 19, 2011 | HP Pavilion dv1000 Notebook
Nokia phone not recharging
Technically, It would be an old battery issue, or the charger itself, try using another charger, if the problem still occurs, maybe it's the battery or your's phone's charger jack had a hardware issue.
Feb 10, 2010 | Nokia Lands Phones
Charging Black and Decker Simple Start
First plug the charge adapter into an outlet, then plug into the unit. Push the power button to turn the unit on. Now, push the button for the light. The light should come on. At this point you hit the charge button and the green light should start blinking and there will no beeping. Then turn off the light. The green light should continue to blink and the unit will charge. This worked for me, hope it helps!
Jan 19, 2009 | Black & Decker Simple Start Car to Car...
Keeps beeping when recharging
It sounds like you need a new battery (this is what the beeping is) even though its only a year old the battery needs replaced!
Please rate my answer and help keep this site FREE!
Thank You!
Dec 28, 2008 | Black & Decker Simple Start Car to Car...
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
PHONE KEEPS BEEPING WHILE RECHARGING
make sure your plug in is all the way inserted into your phone. If it is not completely in your plug-in, then it will make a beeping noise as it connects and disconnects from your phone. ALSO just common sense here, make sure its not just messages coming through.
Oct 14, 2007 | Samsung UpStage SPH-m620 Cellular Phone
HP OmniBook XE3 Notebook Logo
413 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
