Question about Mtd Garden
I can't get my deck back on my lawn tractor.
I have a MTD 12H 38'' lawn tractor that I don't know how to put my deck back on, do you have an pictures, or can you help?
  • 41 Answers
If you still have the manual for the mower you can find out how to replace the deck. If not try going to the MTD online manual and find the lay out for the proper deck replacement.
Posted on Jul 12, 2009
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Deck engagement cable installation
If this is for the models with the handle along side the seat ..the cable attaches to the end of the of the the handle and then runs behind the seat under the rear fenders and then snakes back to the deck where it to a spring on the deck or a spring that comes with the kit...the cable plus on the spring to get the tension on the belts...some differ but presets much the same.system ..if the ok'd or broken one is still on use it as an example..good luck
Sep 01, 2014 | Arnold OEM-190-116 38-Inch/42-Inch Mulch...
I have a 38" deck yard machines(MTD) lawn tractor. When I raise the lever to disengage the blades, the blades still keep turning. Does anyone know how to fix this problem?
If they are slow to stop,thats ok if they don't ever stop thats an issue,the brake shoes that drag on the top of the blade spindles are worn out or not adjusted correctly !
May 14, 2014 | Mtd Garden
I need a diagram for deck belt on a 1989 lawn boy lt 12 38 " deck
it's usually on top of the deck clean off the grass and look on top may have to remove it to see
Oct 19, 2012 | Mtd LAWN MOWER PART # 983-04052 DECK...
My MTD 14hp lawn tractor (38", 6 speed) shuts of
You have a short somewhere . A cut or stripped wire that , at the time of lowering your deck, touches the body. It's like turning off your key. Look around under your deck and you will find what I'm talking about. Fix wire and tie up to prevent future problems. GOOD LUCK.
Jun 16, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
I have a yard man 13AH762F752 How do I know what size my deck is I thought it was a 38" and bought v-type belt and it is to shore so how do I find out my deck size?
If you have a single idler pulley you should have a 38" deck. If the deck has two idlers, then you must have a 42"deck. You should be able to approximate by measuring. This is the "cutting" width, not overall width. Two things might have happened. You didn't get the right belt, or you haven't routed it properly. Here is a link to the Yardman web site to download your manual if you don't have it. It appears that the 38" deck requires a longer belt than the 42" deck. http://manuals.mtdproducts.com/mtd/Public.do?langId=-1&BrandCode=10201
Jun 18, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Looking for a partslist for a 1996 Lawnchief its
Hi and welcome to FixYa. I am Kelly.
From what I have found in the books you have a 1996 MTD Lawn Chief. There are 11 different models!
The MTD part number is 745-0433 It does not list width.
However a net search of the part number comes up with 69-9/32" length and found a list price for $33.99 + shipping.
It also states the belt was replaced by this PN:
954-0329A
http://www.mfgsupply.com/m/c/12-6842.html
$25.89 + Shipping
The belt is common to most all 38" side discharge decks.
Thanks for using FixYa.
Kelly
Mar 29, 2010 | Garden
Yard man mtd 20hp 46"cut hydrostatic drive lawn tractor,model"13AU69H401 deck belt need diagram to put it back on?
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Jul 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
I have a mtd 13.5 horse 38 inch cut 6 speed its around a 2007 or a 2008 i need to se how all the belts go on the mower deck and drive
Most mower decks have the diagram on them, if not go to MTD.com and put your model number to see the diagram.
May 02, 2009 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Garden Logo
371 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
lnbn1975
Morne Olivier
Are you a Mtd Garden Expert? Answer questions, earn points and help others
