Scanner locked. how do I unlock it?
SOURCE: How to install scanner of brother dcp 7010?
The move the software completely. Shut down the computer. Unplug the device. Get offline and disable the A/V program. Now reinstall and do exactly what the prompts say- no short cuts.
SOURCE: Scanner locked
okay, im assuming the brother all in one in the picture is what you're on about...right?!? anywayz :) basically i think it is because you have got "faxes saved in the memory" it sounds weird but the scanner locked is coming up because the scanner is not going back to its home position. if there are faxes in its memory, it means that the memory has not been cleared. to check press menu/set 9,0,1 - if the screen says "No data" means that the memory has been cleared and i don't know what to do!! if it says "Enter fax.no" means that there are faxes in the memory, in this case, the fax must be cleared of memory, (if you need the faxes, you must save them before proceeding) turning it off clears memory apparently but im assuming you've tried that countless times.Turn off the machine's power switch and then on again. If the error message continues, leave the machine for several minutes and try it again. the MFC-7820 can store memory for up to 4 days, so watch out if you have a 7820. apparently this will resolve the issue and the message should go away, hence the scanner returning to its home position!! hope this helps
user guide : http://www.topedge.ro/info/USER-GUIDE/BROTHER/MFC-7820N.pdf
11-3 is the scanner locked section
11-5 is the fax removal section
SOURCE: install Brother MFC 3100C 5in1 printer,fax,scanner,copier,pc fax to my computer.
http://welcome.solutions.brother.com/bsc/public/us/ca/en/dlf/download_top.html?reg=us&c=ca&lang=en&prod=mfc3100c_us
Follow this link and step 1 select driver...
step 2 select your OS....
step 3 select the language....and click search.
On the next page you'll see, in FULL DRIVER & SOFTWARE, more information, click on this and download the driver.
SOURCE: I have a Brother 7020
Your email server may have a limit on it for the number of emails sent.
Does it work with single sheets?
SOURCE: how to shut off the fax answer on brother 4100
Describe your problem in detail. I should be able to help you out if I understand exactly what you are needing to know.
