Question about Huffy 26in Ladies Sante Fe Cruiser Bike - Blue
Iw ould like to raise the handle bars on my wifes bike-how do I adjust
  • 34 Answers
Most likely you have a threaded headset on your wifes bikes. Many times you will have to replace some of the cables and housing because they will be too short once the handlesbars are raised.
If you have a treadless headset than raising your handlebars is very simple. First check to see what type of headset you have. A threadless system with have a allen head on the very top of the stem and one or two more allen head bolts on the side of the stem. The threaded system will usually have only one bolt on the very top of the stem. It is sometimes covered by some type of cap. Also on threaded headsets, there will be a large nut under the stem, which is what most people mistakenly loosen to adjust the stem. Do not touch this nut, it will adjust the headset. Same goes for the allen head on the treadless headset, it will also adjust the headset so don't touch it.
So if you have a threaded stem, simply loosen the allen head or nut on the top of the stem and raise the stem up. Make sure you do not go above the max line and that you are still able to turn the handlebars freely.
Hope this helps!
Posted on Jul 22, 2009
We are having difficulty adjusting handle bars. We loosened stem binder bolt, raised the stem post, however unable to retighten the bolt. The threads do not reach once we raise the bars.
indications are that the taper lock nut at the bottom of the handle bars has been wound off and fallen into the fork area
remove the bars and tip the bike up side down to get that nut to fall out
put the nut back on the bolt at the bottom of the bar , refit and do the bolt up
Aug 05, 2018 | Cycling
How can you raise the handlebar height?
Robert, Below I have posted links showing how to adjust handle bar height for most, some bikes bars are not adjustable and are welded. If the links do not help I suggest you do a google search. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Raise Bicycle Handlebars
How to Adjust Your Bike Handlebar Height
How to Adjust Handlebars
Tech Talk How to Raise your Handlebars
Aug 20, 2016 | Cycling
How do you raise the handlebars on a next bike
Loosen the center post bolt and wiggle the handlebar back and forth while pulling up. There isn't much height adjustment. You can get a longer center post from a bike shop if you can't get a comfortable adjustment.
Sep 24, 2014 | Cycling
Raise handlebars on mountain bicycle
This will depend on what sort of stem you have. Most mountain bikes these days use a clamping style stem that simply grips the steerer tube on the fork. Some will have limited adjustment in that they may have a stack of 2 or 3 spacers that you can place either over the stem or below the stem. This does not give much adjustment. On my wife's bike the stem is actually adjustable similair to this: MEC 110mm Adjustable Stem Mountain Equipment Co op
and might be a good option for this bike.
Sep 18, 2014 | Huffy Granite 26 Women's Mountain Bike
How do you raise the handle bars on the bike?
If it is an older bike, you loosen the bolt at the top of the handle bar shaft until it is about 1/2 inch raised. Take a hammer and give it a swift bump and it should drop into the shaft. Hold the front tire between your legs and the handle bar should raise up. Re tighten once every thing is lined up. If the bike has front hand breakes these may need to be adjusted.
Aug 05, 2014 | Generic 16" Raskullz T-Rad Rex Boys Bike
Need to raise the handle bar on my 2007 Marin Argenta road bike.
The stem for the marin is fixed so you'd have to replace it with one that is higher if you wanted to raise the elevation of your handle bars. You can pivot the handle bars for your preferred angle of comfort though. Loosen the 4 screws on the top of the stem and then you can adjust the handle bars to the correct angle that is best for you.
Jan 09, 2010 | Cycling
Handle bars adjustment - want to raise the handle bars
You will have to go to a bicycle repair shop and ask for a handle bar stem extender. They come in various lengths.
Nov 29, 2009 | Jeep Wrangler X Mountain Bike
Hello, I am looking for technical information about a Yamaha Warrior 350 model 2001. Valve clearance Cyl. head tightening torque
It sounds like it might be flooding or the timing might be out of wack. iw ould start by letting it sit for 30 minutes and try restarting the bike,.If it starts and then dies again have the throttle leaned a bit. If that is not the issue have the timing adjusted
Jun 16, 2009 | Yamaha XS 500 Motorcycles
Huffy 26in Ladies Sante Fe Cruiser Bike - Blue Logo
449 people viewed this question
Top Huffy Cycling Experts
Arturs Kalnins
Arturs Kalnins
TireSideDown
Level 1 Expert
Are you a Huffy Cycling Expert? Answer questions, earn points and help others
