Question about Peg Perego Vespa Scooter
Fuel Starvation Problem
I have a 2006 GT 200L Vespa, it was riding fine until one day it would just stall after a few seconds, now it won't even start. I checked the spark plug and changed it just in case, I cleaned the carb, the air filter, etc., with no luck. Tried starting it with the evap line unattached, no luck either!!
For some odd reason, the fuel would not go trough the lines or filters, so I drained the fuel tank (did not take out the tank and cleaned but just changed with new fuel), took out both filters and cleaned them, and **** won't start either.
I need help!!
  • 32 Answers
Try taking off the fuel line from the tank to the carb and blowing through it
Posted on Aug 03, 2009
Vespa Primavera 50 stalls when throttle applied
Hi, Leland and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Modern Vespa More Primavera stall problems
Scoot idles but dies when opening throttle
http://vespaservice.hu/wp-content/uploads/2016/03/Vespa-Primavera-50-4T-4V-2016.pdf
https://www.oemmotorparts.com/oem2.asp?M=vespa
http://mybikemanuals.com/vespa
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Sep 24, 2017 | 2016 Vespa Primavera 50 4V
Vespa et4 125 fuel starvation? Cuts out on me... Help?
Check the main jet is set up correctly. Make sure there is plenty of fuel in the float chamber, if not check the fuel line again. There should be a good amount of petrol flowing from the carb feed pipe with the fuel tap on. It should fill a pint container fairly quickly.
Apr 24, 2017 | Vespa Motorcycles
How to clean the carborator om my 2007 vespa 200l
might be a problem with the electric choke sitting on the carburetor.
-or you should adjust the air/fuel ratio & idle speed settings on the carb (by a Vespa-shop) clean-carborator-om-2007-vespa-200l-btrmhpso54mmu3efswgwknhc-3-0.jpg clean-carborator-om-2007-vespa-200l-btrmhpso54mmu3efswgwknhc-3-2.jpg
May 17, 2014 | 2006 Vespa Granturismo 200 L
Vespa P150X Piaggio won't start
i think it is the CDI-box (at the top end of engine) not working.
check the connectors (pull the rubber cover)
- or better get a new onevespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-0.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-2.jpg vespa-p150x-piaggio-won-39-t-start-gfszydzqc2hzsk2kh2zz143u-1-5.jpg
Jan 03, 2013 | Peg Perego Vespa Scooter
Trouble starting my vespa
check your takn and clean your fuel and air filter and check the fuel line from the tank to the carb and blow it out, 1 of these should help.
Jul 12, 2009 | Peg Perego Vespa Scooter
2305 tractor keeps stalling out
Hello eireannachcr:
>>Check All the Fuel Connections and Make Sure they are Tight.
>>From Your Description it Sounds like a Loose Fitting or a Bad Compression Washer.
>>A Bad Compression Washer or Loose Fitting will Allow the Fuel to Drain Backwards (sometimes it takes setting for a few days for the Fuel to Bleed Back) when the Engine is Not Running. Once the Engine is Started, it Runs Correctly Until the Air Pocket in the Fuel Gets to the Injector Pump and then the Engine Stalls. The Fuel Behind the Pocket Keeps the Pump and Lines Primed so the Engine will Restart without Bleeding Any Air from the Fuel System.
>>You can View a Breakdown/IPL of the Engine and Mower at this Site Addy, http://jdpc.deere.com/jdpc/servlet/com.deere.u90490.partscatalog.view.servlets.HomePageServlet_Alt and Enter the Model Numbers and Click Find. Then Select your Model from the Search Results Area. Then Select the Sectional File. Then Select the Section of the Mower you Wish to View Online. *You can Drag the View Windows for Better Viewing.*
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Apr 10, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Fuel Starvation on 2006 200cc Vespa. Toward end
It's quite easy to get the tank out.
Remove the 4 bolts (2 front and 3 back) on top of the tank under the seat. You can lift the tank out.
replacing the fuel tap is a bit harder as you need to loosen a nut inside the tank, then pull the tap out.
Mar 16, 2009 | Peg Perego Vespa Scooter
Peg Perego Vespa Scooter Logo
524 people viewed this question
Top Peg Perego Toys Experts
Marvin
Marvin
Lawrence Oravetz
john h
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
