Question about Quantaray Cameras
My quantaray 70-300 will not work with a canon rebel eos xt 350, why not ?
  • 619 Answers
SOURCE: My new Canon Rebel EOS XT will not work with my external flash. WHY??
Hi , connection from camera to the quantary ps-1 dszflash are compatible the adopter it connect during flash signal.You may return and bring your camera and test what ever compatible.
Posted on Jan 25, 2008
  • 105 Answers
SOURCE: quantaray lenses
That's good info. The trouble is that Quantaray makes lenses for different bodies. Your lens could be made for Minolta, Nikon, Canon or other. You may be able to find a universal adapter but first you need to know what mount that lens was originally made for. I recommend either taking the lens to a camera store or calling Quantaray to see if they can look up the mount using the serial number.
Posted on Mar 29, 2008
smartr10U
  • 1305 Answers
SOURCE: canon rebel xt error messages
error 99 can most times be remedied by taking a standard pencil eraser and carefully cleaning the gold contacts at the back of the lens and the gold maching contacts in the lens opening of the camera... BE CAREFUL not to let eraser crumbs into your camera... keep it clean... reset the battery and give it a whirl.... did it solve the 99 issue?
for the CF it refers to the cf card... here's what I've found on this:
Canon reports that this error code may appear on your digital camera’s LCD (liquid-crystal display) when there is an error reading from or writing to the inserted CF (CompactFlash) card. This error code occurs most often after a user has tried to eject a CF card before the camera has finished writing data to the card.Solution:
Canon suggests that you first try to use a different CF card. If you do not see the error message when you use the new CF card, the first card is probably damaged.
Before you take the next step, drag the files from the CF card to a location on your hard drive to back up the files. Next, you can use Windows’ ScanDisk utility to check the CF card for errors. If you use a Mac, you can use Disk Utility (in Applications\Utilities\) in OS X.
If ScanDisk or Disk Utility fails to resolve the CF card problem, insert the CF card in your camera again. Then format the CF card. On most Canon cameras, you can do this by pressing the Menu button, selecting the Format tab, highlighting Format, selecting Format, and choosing Yes. Make sure you have backed up the data on the card before you do this. Formatting the card will delete the images from the card. After you format the card in your camera, use ScanDisk or Disk Utility to check the CF card again. If you still encounter errors while using ScanDisk or Disk Utility, you should discard the CF card because it is damaged.
If the error still occurs after following the steps above, your camera may need repair. Contact Canon’s technical support for further assistance.
hope this solves your issues....
let me know
K
Posted on May 29, 2009
  • 7 Answers
SOURCE: Canon EOS/Rebel XT won't power up
Joe, this happened to me, just tonight... I got a new CF card and stuck it in, turned it on and one CF card flash. Completely dead from there. I found one of the CF card pins bent over, shorted out the socket and blew the mainboard fuse. I took the camera apart, found the fuse (labelled K) about under the set button area) I bridged the fuse with a bit of solder, straightened out the pin in the socket, put it all back together and it's working fine. The fuse is under the right side shield cover, it's labelled with a letter K. There is another fuse on the power inlet board (below the shutter button) and it's labelled 'P'...
Posted on Aug 22, 2009
  • 11967 Answers
SOURCE: Have a canon digital rebel xt eos, get a
Are you using a lens hood?
Posted on Dec 29, 2009
Will a quantaray 28-105 1:3.8-5.4 Zoom lens Autofocus from a 35mm rebel ti fit on Canon EOS Digital Rebel 6.3 MP 300D?
The 35mm Rebel Ti and the Rebel 300D use the same lens mounting protocol. All Canon cameras designated 'EOS' use the autofocus EF lenses. If your Quantaray lens worked on the Rebel Ti, it will fit and should work on the Rebel 300D.
Mar 19, 2009 | Canon Digital Rebel / EOS-300D Body only...
What digital camara can I ues with a quantaray 100-300 af lens
Canon EOS Digital Rebel XT or XTi are both really really great cameras.
Dec 14, 2008 | Quantaray 100-300mm F4.5-6.7 Zoom Lens for...
Aperture wont adjust on my canon rebel xt
If it's an older lens, for EOS film cameras, Quantaray might upgrade it free - contact your local Ritz Camera store ( it's imported by Ritz ) or find a repair center for Quantaray online.
Nov 18, 2008 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Problems getting Quantaray AF 70-300mm lens to work with Canon xt
you could try cleaning the contacts on the camera and lens with an pencil eraser
Nov 13, 2008 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Lens
Quantaray is a private label lens made for Ritz Camera. They make this lens to fit several different camera brands including Nikon and Canon. The only ones that will fit a Canon camera body are the ones with the Canon EOS mount. If your Quantaray lens doesn't have an EOS mount, then it won't work on your Canon camera. You can take the lens to any Ritz Camera location and they can help determine which mount it has, and which cameras it will fit.
Jul 08, 2008 | Canon EOS Rebel Ti / 300V 35mm SLR Camera
Canon rebel xt
I Want a Lastest firmware for 350 D
Jun 02, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Jan 05, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Cameras Logo
110 people viewed this question
Top Quantaray Cameras Experts
Doberman
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
Are you a Quantaray Camera Expert? Answer questions, earn points and help others
