Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Hdmi hi i own a sony bravia 50 inch rear proj tv. i get a pink ghosting effect when i connect a sony playstation3 american ver to the bravia via a hdmi cable.i have noticed when selecting the diff channels that only the hdmi chanell has this problem even when no playstation is connected.
Re: hdmi
Bring up the "service" menu, put the TV in standby mode, then press in sequence :
Onscreen Display ( the little screen with the i+ in it )
5 ( channel number 5 )
Volume Up ( upper end of volume button )
Analogue ( middle top button )
The TV should switch on and when it's warmed up, you should see a screen with lots of big green lettering on it.
Press the "menu" button ( middle bottom )
Use the direction dial to move down to "LCD Drivers" and press right on the dial to enter this menu.
Move down to "S H Pos Reg R". It should be "10", change it to "11". ( Left/Right to adjust )
Move down to "S H Pos Reg G". It should be "10", change it to "11".
Move down to "S H Pos Reg B". It should be "10", change it to "11".
Press the menu bottom to drop out of the menus, and the standby button to drop to standby. Switch back on, and hopefully your ghosting will be gone.
Posted on Mar 30, 2009
Re: hdmi
The symptom you describe for the HDMI connection is usually one where the timing of the transmitter (PS3) and Receiver (Bravia) is "off". This can happen when the two chips negotiate with each other to initially set up communications.
There is only one relatively easy fix ... if it works, then you are lucky. Swapping the cable that interconnects for a shorter or higher quality cable sometimes fixes this problem.
It is possible, depending on vintage of both the TV and the PS3, that they will never talk directly together. The PS3 must be new but if the TV has an older HDMI solution, it may be difficult to solve. (it is possible, if everything in your chain is new and high quality, that you have a defective HDMI chip in one or the other).
If the cable doesn't work, a high quality (and probably expensive) HDMI repeater box might be happy listening to your PS3 and retransmitting to your TV. These kind of boxes are often sold at home theater supply dealers... sometimes as "amplifiers" and sometimes as "splitters". You might find one of these with two inputs and one output as "Switchers" and of course much more complicated solutions.
Unfortunately, HDMI is a "standard" that is changing. there have been three revisions so far and some early chips really don;t like to talk to some later chips.
good luck. dc
Posted on Nov 15, 2007
0 characters
3 Points
Where can i get a transformer for a sony progection tv model no kf-50sx300u
I have one on E Bay now title is Sony Bravia KDF-E50A12U 50" Proj TV 1-419-965-11 H.T. Choke Coil Unit Only GWO
May 02, 2012 | Projection Televisions
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv no cost! If I chose a 46" or 55" there would be a charge between $325
Dec 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Ghosting on hdmi channel on my sony bravia
With HDMI there should be no ghosting. And being a Sony Bravia it should be no ghosting. My 52" Sony is great.
You've got connection issues.
Nov 25, 2009 | Sony Projection Televisions
57 hitachi ultravsion rear proj hdtv :ps3 hdmi issues
May 15, 2009 | Hitachi 53FDX01B 53" Rear Projection...
I have a sony bravia 50 inch rear projection tv. model KDFE50A12U .It has been working fine with no hints of a problem,yesterday when i switched it on the power light started to flash and the fan,bulb and...
i have a sony bravia 50 inch rear projection tv kdf 50e2000 the problem is it fail to switch on when it did it swicth on had black line cross the screen
Apr 01, 2009 | Sony Projection Televisions
Screen goes dull at times
The dulling picture really sounds like a lamp failing. You would need the sony lamp xl-2100u
The ghost image may be easier to fix, sometimes as lcds age you will get a slight shift in a color. deep in the sony menu there is a parameter (menu-setup-imageshift) that will give you 3 levels of correction, this may solve this issue.
Dec 04, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Hello have a sony KDF 50E 2010 LCD PROJECTION TV. When I plug in my ps3 via hdmi get a ghosting picture also if i plug in my wii via scart ghosting on screen also happens. is this normal and can i rectify...
hi. i had the same problem with the hdmi lead. luckily it was still under guarentee, when the bloke came out to mend it. it was the settings that was wrong he changed some numbers on the remote and it works fine now. with the sound of it most of these tvs are set wrong for hdmi ..
Aug 04, 2008 | Sony Projection Televisions
this problem is caused by the pal 50 - 60 meg problem, the sony runs at 50 megs, if you have a 60 input from an hdmi lead you will get ghosting
Mar 05, 2008 | Sony KP-43T90 43" Rear Projection...
HDMI to DVI Cable
I had a similar issue, try adjusting the advanced settings on the DVD player.....I can't recall which settings it should be on, but when I adjusted them on my upconverting DVD player everything worked fine after.
Dec 07, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
50" Bravia KDF-E50A12U
read about this last night see
seems there is an easy fix
Nov 12, 2007 | Sony KDS-R50XBR1 50" HDTV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
307 people viewed this question
Top Sony Projection Televisions Experts
Steve Sweetleaf
Steve Sweetleaf
Jason Harris
Jason Harris
Are you a Sony Projection Television Expert? Answer questions, earn points and help others
