Question about RIM BlackBerry 7290
Firewall enabled on 7290?
I bought this older Blackberry (7290)from someone who had TMobile and I'm AT&T.
I had the phone unlocked however the person who unlocked it said bad news, there is a firewall enabled and he couldn't disable it.
Yes, I get the Invalid Sim message but all the other functionality works.
Using the options menu I keep trying to change the Firewall and/or network but it doesn't allow me to.
Am I out of luck or can something be done?
Thank You
Jerry
Phoenix, AZ
sharkpro@yahoo.com
How can I unlock my RIM Blackberry 7290 Black ? what is the code to use?
Blackberry can be unlock eaisly with remote unlocking codes. you can get this Blackberry imei unlock code from your network provider or get from third party,
both are safe way to Unlock your Blackberry 7290.when you go to online you can find so many sites of Blackberry imei Unlock Code. they will charge little amount for your Blackberry Unlocking Codes. i hope this will help you:)
Best of Luck.
Oct 15, 2010 | RIM BlackBerry 7290
Unlock code for Blackberry 7290 ..
hi
i too use the same phone Blackberry 7290 but i can give my unlock code just like that
because its unique ....... to every phone so visit the official site and get unlock code at some cost
click here
May 26, 2010 | RIM BlackBerry 7290
Want to use a blackberry 7290 in st vincent but the phone wants to unlockhow can i do that
Hello
You have to unlock that BB first
This unlock code provider generate full LEGAL unlock code direct from Blackberry server which wont void your warranty, & generate code based on your IMEI, means individual code for every blackberry set.
After unlocking from this provider's code your blackberry not only work with single network, you can use your Blackberry in any part of world with any network including your browser & MMS picture messaging to work, yes with just one time entering code from your keypad.
They unlock from network who locked your blackberry
This site will help you a lot & good email & 24/7 phone support
May 08, 2010 | RIM BlackBerry 7290
I need to unlock a blackberry rim phone from at&t to tmobile
Hello.
You can get MEP Code for your Blackberry pearl 8100 byBlackberry unlock code provider.I hope this provider helps you a lotto solve your problme.
Click Here
Thanks
Oct 17, 2009 | RIM BlackBerry 7290
No service on new blackberry 7290 phone
Hello
http://blackberryimeiunlockcodes.com
Aug 27, 2009 | RIM BlackBerry 7290
I bought an unlocked blackberry 7290 RIM, can't get service
I am actually unsure what could have caused this. It might not be unlocked correctly or could have been damaged when the software was modified. But T-Mobile carried the BB7290 so if you can get ahold of the person who unlocked it for you I would ask for a branded T-Mobile phone.
Feb 02, 2009 | RIM BlackBerry 7290
Network inactive
It could be that roaming is disabled either on your phone or on your account.
You should contact t-mobile at 1-877-453-1304 and see if roaming is enabled on the phone.
Dec 25, 2008 | RIM BlackBerry 7290
Blackberry 7290
you can do it via imei unlock code here: http://www.gsmunlocklabs.com/unlock-blackberry-c-56.html
or here: http://easygsmunlock.com/unlock-blackberry/
Aug 02, 2008 | RIM BlackBerry 7290
Unlock BlackBerry 7290
Unfortunately, the unlock code for a BB 7290 is unique to each phone. The unlock code is based on the IMEI of your BB. After getting an unlock code then the steps to unlock are:
1. go to options
2 scroll to SIM CARD then press jog dial in once to select it
3. Type MEPD (not case sensitive) ( you will not see text appear on screen while typing )
4. Does it say Network active? if so your phone is locked
5. Press and hold the alt key (half moon looking key on the lower left side)
6. as you are holding the alt key type in MEPE (not case sensitive) ( you will not see text appear on screen while typing )
7. type in the unlock code when prompted
8. After entering the code press the jog dial in
9. Your phone is now unlocked!
Feb 27, 2008 | RIM BlackBerry 7290
Unlock my blackberry 7290
Like you being with T-mobile, I bought a cingular phone off ebay that wasn't unlock. My sims didn't work either. My network just said call Cingular which is now AT&T and they gave me the MEP code to unlock it. Beware, you need to confirm all of your information from your network before they will help you.
Feb 20, 2008 | RIM BlackBerry 7290
RIM BlackBerry 7290 Logo
165 people viewed this question
Top RIM Computers & Internet Experts
Otman Lahlou
Otman Lahlou
ismael castillo
asber
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
