Question about Panasonic Televison & Video
My panasonic viera TH-37PX80BA keeps shutting down and also when this happens the power LED Flashes. why is this?
Kimi
  • 277 Answers
SOURCE: Panasonic Viera 42" TH-42PV30
Check the 2 main interconnection cables (24pin and 26pin) rear of PDP and Tuner box. Make sure they are firmly connected. (Loose connection of 24pin will cause no power on symptom.)
Posted on Oct 21, 2005
SOURCE: Panasonic Viera TH-42PV7HS Plasma keeps shutting down
hi there, have the same kind of problem twice so far after was bought for me as x-mas present (although my viera isnt plasma, its an LCD TX-32LMD70A)..
I Pulled out the mains plug for about 10-20 seconds and then plugged back in (power button at top was pushed in, in the on position, so when the power was on, the tv just goes straight on). It then worked.
i would however like to know why this happens ( i really hope this isnt a hardware problem, as like many others... its only months old!!)
hope this helps
Posted on Apr 27, 2008
Raditronic
  • 196 Answers
SOURCE: Panasonic Viera Plasma TH-42PV7HS- Shutting down
CHANGE P.A BOARD. THIS BOARD IS FOR TUNNER VOLTAGE..IF THIS BOARD IS BAD, THE LED FLASH 10 TIMES IN RED AND THE TV NO TURN ON.
Posted on Dec 20, 2008
SOURCE: red flashing led on my panasonic viera
Replace battery. Battery is defective
Posted on Aug 31, 2009
  • 184 Answers
SOURCE: Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Posted on Aug 01, 2011
PANASONIC Viera TH-37PX80BA with 7 blinking Red LED on switch on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Oct 20, 2014 | Televison & Video
My Viera TV: TH-P42ST30z seems to have shut down. When I turn it on the pilot light initially flashes green then starts a sequence of 7 red flashes, a gap, 7 more red flashes and this continues indefi
Oct 09, 2014 | Panasonic Televison & Video
12 blinks on th-p42x20m
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Apr 13, 2014 | Panasonic Viera TH-50PZ85U Plasma TV
Panasonic viera th-p42g10a plasma tv has flashing red led light
The number of flashes is indicating a specific error. If you let me know how many times the light is blinking I will let you know whats most likliy causeing the issue. Reply to this same post for assistance.
Nov 09, 2012 | Panasonic Viera TH-42PZ80U Plasma TV
Aug 01, 2011 | Panasonic Televison & Video
Panasonic - TH-46PZ85U - Will not power up, either from the remote or from the TV on-off power button. With the TV plugged in, a light on the bottom left corner flashes 10 times, pauses and then the...
Could be a cooling fan failure, there are five fans across the back of this tv ( i think) if even 1 fails the power supply shuts down. If so fan needs replacing,
pete
Nov 11, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Error codes. no picture or sound after turning
When the SUB5V or MAIN9V/SUB9V, short or over-voltage 15V short condition occurs, the TV shuts down and the power LED blinks 10 times.
May 15, 2010 | Panasonic Televison & Video
TH-42PZ80U Panasonic Plasma, red light flashes 10 times
Panasonic said "A" board,
A board SOS Detect (Explanation)
10 Blinks SOS: The voltage regulators IC5400 and IC5401 in the A board generate SUB9V and SUB5V. The 9V and 5V from these ICs are monitored by IC1100. Any abnormality on the SUB9V or SUB5V lines, triggers the shutdown circuit and the MPU shuts down the unit. The power LED blinks 10 times.
But need to measure the connection SC2, if it short, it will be the SC board.
The knowledge obtain from: Real case of repair by myself.
Information from Panasonic training manual.
Apr 27, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Wont power up led flashes 7 times
If this is an LG TV this is down to the power supply within your TV, this needs to be replaced - you should contact your screen manufacturer for more advice.
Sep 13, 2009 | Panasonic Viera TH-58PZ700U TV
Hi to all, My 42" Panasonic plasma have the same problem. It turned itself off and now red light flashes 7 times, than after short pause 7 times again. And so on. Any ideas what is wrong??
Oct 07, 2007 | Televison & Video
Televison & Video Logo
78 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
