Question about Hayward Viper Pool Cleaner
The viper is going in circles and will only clean the area around the drain. The reverse valve appears to be partially stuck in the open position.
  • 3 Answers
My Viper was stuck in partial reverse. After reading twbrenna's post, I searched for an exploded view diagram of the viper. This is what I did:
1. Remove the hose connection from the back of the viper by pressing in and rotating counter clockwise.2. Turn the viper upside down and remove the five screws holding the top shell to the bottom. Turn it right-side-up and gently remove the top from the bottom (be careful of the small, thin uprights above the wheels). Remove the wheels.3. Remove the internal cleaning tube that lead to the debris bag.4. Remove the retaining screw holding the internal part of the hose connection.5. Lift the Reverse timer up and out with a gentle wiggle, then lift the entire manifold up and out with a gentle wiggle.6. Inside the manifold (in the clear part) is a double plunger (grey with o-rings). Disassemble the manifold (take careful note of parts positions and the path of the hose to the reverse timer). Ensure the blue slide that connects to the plunger are stays on the manifold in the correct orientation. 7. Remove the white hose connection from the bell at the end of the grey plunger.8. Remove the plunger by pushing it out of the bell by the plunger arm.9. Clean the plunger and the bell with a soft-scrub sponge. Apply silicone grease (important) lightly to the inside of the bell and to both o-rings. Re-insert the plunger. 10. Between the clear upper part of and the opaque lower part of the manifold (where the blue slide is) is an o-ring. Apply silicone grease here too. Re-assemble, making sure that the slot on the plunger arm fits into the blue slide correctly.11. Snap the manifold back into position. Return the timer to the correct position. Replace the retaining screw on the internal part of the hose connection. 12. Grease and replace the wheels, ensuring the correct orientation of the front wheel with bearing (Hayward stamp down).13. Gently replace the top housing shell and screw down.
Fixed! Its about an hour project. If it doesn't work, a new manifold can be purchased on the internet for $90-140.
Posted on May 09, 2012
  • maciejka2
    maciejka2 Jul 17, 2012
    Perfect, thanks! I followed your directions and the cleaner is working. It still has few problems but at least it is not stuck in permanent reverse. Two years ago I had the same problem and of course the store said I had to replace the manifold and some other part (over $200). This time I was smarter....
I had a similiar problem. I took the sweep motor apart and used a scotch brite pad and smooted the inside of the piston that operates the spinout. I also lubed the o-ring seals with some vaseline before putting it back together. I also used the scotch brite pad on the little plastic part and its mating surface the piston operates.
Posted on Sep 14, 2009
Fills with water, won't start wash cycle, won't drain on CANCEL. What's wrong?
I had a flap reversed in the drain line when I bought mine new. It was only allowing partial drainage. Had a service guy take it apart and switch it around. Seems to work ever since. It was under warranty at this time.
Nov 21, 2015 | KitchenAid KUDM24SE Built-in Dishwasher
Econ Quad Viper 70 4 stroke won't stay running unless choke is one quarter or more closed. Occasionally pops through carb and bogs down if accelerated.
there's still debree hanging around,there's some more cleaning to do at the pilot.after doing so look if you can see true.after reassembling readjust the adjuster for the pilot two full circles and a half circle.have fun
Dec 21, 2014 | Viper Motorcycles
Check float valve
pull out your bottom rack, in one of the bottom corners of your dishwasher there will be a circular plastic piece. it is probably stuck in the up position . Wiggle it around, it should sit loosely in place. It's a float, so when water fills in your washer, the float should raise up, when the water is draining, the float should lower with the water. That's why the float should be sitting loose in position.
Dec 29, 2013 | Maytag Dishwashers
My rear wiper on my 2003 chevy suburban 1500 stoped working and my battery is being drained
Hello the wiper motor axel is stucked by rust and the hole viper motor must be changed or renewed with a used/better one.
To prevent the battery from draining remove the multiplug connector from the rear viper engine.
(Remember to remove the negative cable from the battery)
When the viper motor is stucked the power circuit can`t close in position and this is why your battery is being drained for power.
Hope this will help you
Dec 17, 2012 | 2003 Chevrolet Suburban 1500
My Bissell proheat 2x will not stop spaying when the trigger is depressed, This happens only after the power is turned on and continues until the tank is drained or the power is cut.
I assume you mean that once the trigger is depressed it won't go back to it's original position. Like it's stuck on. I would look in that area for a broken or missing spring. I would also trace the control from the trigger to the valve that it opens and see that there isn't any build up keeping the valve open.
Nov 12, 2012 | Vacuums
Water coming out of washing machine
your drain valve is STUCK OPEN!
if you know how to open the valave at the rear panel, you just open it and clean the debris that stuck the diaphragm to OPN position!
Nov 06, 2010 | Washing Machines
My dishwasher turns on and all the lights work. It sounds like it's filling up with water, but it never actually runs through any of the cycles. If I leave it running for a while it will continue to...
It's worth repairing.
Check water level switch inside the machine.
Check the inlet solenoid for proper operation. It might have got stuck and remain
in open condition always. You can reach this area by opening the back door of the machine. give a gentle tap with a wooden piece on the valve , it may return to the closed position.
Clean all the inlet and drain areas of the machine.
Sep 21, 2010 | Bosch SHU9915UC Dishwasher
Shooting gas out of the muffler
your float valve control "in the sediment bowl" is stuck open and not shutting off the gas supply when full
Apr 10, 2010 | Mtd Arnold Oem - 190 - 607 Fastattach...
My Washing Machine fills and drains at the same time, what can i do?
Check drain valve area. May be drain valve stuck in open condition. Too much lint collection etc. or try this. If you can reach the area clean it or give gentle tap on the valve! It may close.
Apr 03, 2010 | Tecnik TKL9260 Front Load Washer
Water drains out the bottom of cleaner as soon as tank is attached.
You don't say where the water is leaking from i.e. the back or the front. It likely is coming from the back. There is a connection to the "seat" that the tank sits in. There is a small hose that delivers the solution from the tank to the pump in the machine and I have seen them break off at the valve under the handle. If this is the case, the valve will have to be replaced.
Feb 10, 2008 | Hoover F6212-900 / F6215-900 SteamVac...
Open Questions:
Hayward Viper Pool Cleaner Logo
695 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
