Question about Onkyo TX-DS595 Receiver
Onkyo TX-DS595 with no display?
The receiver powers up and verything works but there is no display.
Any suggestions? It has been sent off and fixed once before. Don't know what they did but this time they suggested in buying a new one.
  • blacina Dec 21, 2008
    Me too... 8 year old receiver, display just quit working, appears to still function, but it is hard to be sure without a display... Submitted to Onkyo TS, will advise if they offer a solution.
  • naga
    naga Oct 04, 2014
    I just had the problem on my 10 years old DS595... but i see a black spot on the front sde of the display, i am affraid it is the display itself that died.
Ran my 595 blind for 2 years and finally spent the time to diagnose it this year. Turns out that one of the resistors that is on the power supply went bad. Similar problems have happened with later models so i thought the same may be true for the DS595.
My Receiver has always run fine.. just no display anymore.
Here's the fix. Replace R9501. its on the larger board that is part of the Power Supply. You will have to take the 4 large screws out of the base of the big heavy power supply block to find the resistor. I believe the old resistors is a 1/4 Watt. I replaced it with a 1 Watt so that it can handle the heat of being turned on and off better.
The resistor you will need to buy is 2.0 Ohm. I wouldn't go anything less than a 1/2 Watt and preferably 1 Watt.
My receiver works line new now!
Posted on Jan 11, 2010
  • Santhagyozo
    Santhagyozo Jan 05, 2015
    Thank You! That resistor was the problem. I disassemble it from the power supply and measure that and it was tear. Thank You again. Onkyo Powa ! ;)
  • Chris Kalina
    Chris Kalina Dec 05, 2016
    Can you explain exactly how you replaced this?
Onkyo tx ds595 how can connect to the sub woofer
Hello, the TX-DS595 supports a powered sub-woofer, The connection is on the bottom left on the back of the receiver. Thank you, Onkyo USA
Apr 18, 2017 | Onkyo Audio Players & Recorders
Onkyo tx ds595 how to connect directly to the subwoofer ?
Hello, the TX=DS595 supports a powered sub-woofer. The connection is on the bottom left on the rear of the receiver. Thank you, Onkyo USA
Hello my name is Ivan.I vant to know is there for this model remote Onkyo TX-DS565.My courier was iv_an_76@abv.bg
I'm not aware of Onkyo having made a receiver model TX-DS565. Perhaps there's a typo in your message? Did you instead mean Onkyo model TX-DS595? Google search and Remotes.com has listings for the remote for TX-DS595.
Dec 25, 2014 | Onkyo Audio Players & Recorders
Display doesn't light up on Onkyo TX-DS595 reciever
try to connect the receiver to a tv via the monitor out from the receiver to the tv. you may be able to see the OSD (on screen display of your settings) change the function on that to turn on the front display. alternatively look on your remote to see if you can turn up the light of the front display.
if these don't work possible that the light of the display has blown
Dec 04, 2010 | Onkyo TX-DS595 Receiver
The Onyko TX-DS595 receveiver won't respond to remote.
When unit is on hold down vcr button and press standy power button. display will read 'CLEAR". turn back on and see if remote works. note that this will erase any of your settings. Point the remote at any camera and look at the camera display. If you see a white light when you press buttos remote is working. Remove the top cover, remove front cover and resolder connections on remote receiver. If you intend to do this let me know and I can give you more details.
Mar 22, 2010 | Onkyo TX-DS595 Receiver
Garbled / feedback sounds from powered subwoofer
The surround processing portion of the unit has a problem. In either stereo or direct mode, the digital procesing is bypassed. This could be just the surround processing IC, but that IC may not be available as a separate part. I would suggest that you bring this unit to an authorized Onkyo service center for an estimate.
Dan
Mar 18, 2009 | Onkyo TX-DS595 Receiver
Display on receiver no longer visible
from display power by ac voltage 5.6vac pins 1and2 and 65and66 should be from power transformer there is no fuse for this display light
Nov 10, 2008 | Onkyo TX-DS595 Receiver
Onkyo tx ds595
Yes, the speakerconns can have bananas, you have to remove the little plasticcovers in the middle of the conns...also you can use thick wire with this connectors...
MfG
Feb 24, 2008 | Onkyo TX-DS595 Receiver
Receiver doesn't respond on remote signals
Low batteries can cause a symptom like this. Have you tried to replace them yet?...accordianman
Oct 04, 2007 | Onkyo TX-DS595 Receiver
Onkyo TX-DS595 Receiver Logo
1,409 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
