Question about Garden
Smoke coming from motor, slows down
    Scholar:
  • 103 Answers
ASSUMING ITS A TWO STROKE. MIXTURE HAS TOO MUCH OIL IN IT. TRY DIFFERENT MIXTURE,IT'S BOGGING DOWN BECAUSE NOT IGNITING WITH A HIGH CONTENT OF OIL IN IT ON WIDE OPEN THROTTLE. MAY ALSO NEED CARB ADJUSTED. DO NOT MAKE MIXTURE TOO THIN ON OIT,YOU WILL SEIZE UP ENGINE
Posted on Jul 12, 2009
Phips food processor hr2833 motor availiabilety and cost since it is slow running and smoke coming up and no speed
Brushes may be bad. Heating the windings and glue, causing the smoke. It is a fire hazzard if contunues. Is it worth it to have the motor rebuilt? That is, if the heat damage isn't severe.
Sep 24, 2012 | Food Processors
Car quits when i slow down to come to a stop
Check for a vaccum leak. The easiest way to do this is by using a smoke machine. If you don't have one, you can buy a pack of cigs and blow alot of smoke into the intake boot where the air filter is until you see the smoke coming out of somewhere. If you've recently replaced anything, double check to make sure that you have all of the hoses and connectors in place, and all of the clamps tight.
Aug 15, 2012 | 2007 Ford Mustang GT
Motor may be burned out
Any time an electrical motor burned out, a smoke clound come out and a very unpleasant smell come out. If you did not anticipate the above then look for problem elsewhere.
Dec 23, 2010 | Toastmaster Food Mixers
My 2006 Ford Focus is acting up and I need to know what it is. When I speed up, like to pass someone or to get onto the interstate, it will start to speed up, then start slowing down. While it is slowing...
ok do a spark plug change also have the spark plugs check to see if you have loose spark plug.sometimes the white smoke means you have to much oil in the motor and or your piston rings are going out.use a bottle of see foe in the gas tank and in the motor but make sure you get the oil change ok .that should fix the problem
Sep 01, 2010 | 2006 Ford Focus
Kitchenaid 325 start then slow down then stop and white smoke start coming from machine
This could be simply tha thte motor brushes have worn down. Undo the black plastic caps and compare the length to the image here
Sep 29, 2009 | KitchenAid KSM150PS Artisan Series Stand...
2001 Hyundai Accent 167,000 miles
At 167,000 miles there will be wear on the piston bores and rings this means you will be burning off oil even during normal running
Standing test is to make sure that the car is in park and get someone to really rev the engine for a few seconds let it die down and do it again repeat this 6 or so times and I bet you will see a thin blue smoke coming from the muffler
Jul 01, 2009 | 2001 Hyundai Accent
Table saw starts slow and the stops
Sounds like the run capacitor has given up. Or, maybe the worst is it overheated and burned the motor winding. You'll probably have to take it apart. If there is a smoked capacitor, that's probably the one you should replace. If the winding is scorched, might as well get a new motor. If both are the case, then replace the capacitor before you give up on the winding.
Apr 21, 2009 | Saws
Blue smoke from 7.3
probably the oil rings on the pistons but might be one of the heads , not good either way
Oct 09, 2008 | 2001 Ford F350 Super Duty SuperCab
Garden Logo
180 people viewed this question
Top Garden Experts
roeb
john h
Marvin
Marvin
