Question about Sewing Machines
My Pfaff Tiptronic 6270 does not sew.
My machine was working fine till yesterday. Today when I switched on, the LEDs and display have not switching on. However machine bulb is on.
  • Sewing Machines Master
  • 12,730 Answers
Try unplugging the power cord from the machine, let it set for a few minutes and try plugging in again. Sometimes this will reset the machine.
Here are other postings on Fixya that sound similar to your problem:
Pfaff Tiptronic 6270 just stopped working
The memory board went out on my 2000 tiptronic 6270 couple years ago now...
Posted on Sep 06, 2015
Testimonial: "Thank you. I have tried again to turn on the machine, but it failed. May be the fuse is blown. In that case, I need instructions to replace the fuse."
SOURCE:
2001 Touch Tronic. Worked fine yesterday. Today, why can't I wind a bobbin?
If you haven't cleaned and oiled your machine recently, you might start there. Consult your owner's manual, use ONLY fresh, good quality sewing machine oil, and apply 1-2 drops of oil each spot specified in the manual.
If the machine bobbin winder is still not working, does it still sew? If so, you probably have two choices:
1) Take it in for service
2) Buy a standalone bobbin winder (~$30) from JoAnn's, Hancocks, or Amazon.com
If the machine does not sew, take it for service.
Dec 28, 2015 | Singer Sewing Machines
I have a singer simple sewing machine 3210 and I tried to use it for the first time today. I threaded everything fine and started to sew and after 15-20 seconds it popped and sort of exploded. The...
Hi... well that is certainly not normal. However, does the machine still sew? If so, I would replace the broken bulb... if the bulb blows again... then you have a short-circuit on the power line to the bulb... look for abraded cable... or then take to a machine repairer.
May 17, 2014 | Sewing Machines
2040 tiptronic board replaced
I would take the machine to someone else and see what they say.
Mar 16, 2014 | PfaFF Tiptronic 2030
A few months ago, the bulb wouldn't come on, so I
When you say 'bulb' ... I assume you mean the sewing light ? The Artista 180 does not have a conventional 'bulb' for the sewing light, but a fluorescent tube that's a 'C' shap and surrounds the bottom of the head unit by the needle. This is driven by a high-voltage converter that runs off a supply on the main processor board. If the machine is working normally but there's some intermittent on/off of the fluorescent light, it could be simply that the tube's had-it, in which case its off to the service man for a new one - it comes as a complete tube and converter replacement. But before you do that. TURN THE MACHINE OFF. unscrew the hex socket that holds the head cover on and remove the head cover (the cover over the needle end). If you look at the head mechanism, looking towards the foot pressure control (i.e. the 'end' of the sewing arm) you should see a small cirucit-board just above the fluorescent tube with a fairly large 2-pin connector on the top - this slides on to the circuit board. Try giving that a careful wiggle to re-seat the connections, but PLEASE BE AWARE THAT THIS IS A HIGH-VOLTAGE PART AND THEREFORE DANGEROUS, so you MUST NOT touch it with the machine switched-on. Hope that helps.
Sep 07, 2011 | Bernina Artista 180
I was just gifted a Pfaff Tiptronic 6270 for my charity quilting.I have no manual,and cant figure it out.How do I use it? How do I thread it? I just want to sew a basic chain stitch,nothing fancy..help!...
there a bunch of sites selling this manual but i'd suggest you try the manufacturer first
ContactSVP Worldwide
C/O Husqvarna Viking
P.O. Box 7017
LaVergne, TN 37086-7017
Toll free assistance - 1-800-446-2333
Monday-Friday 8:00 am - 4:00 pm CST
Email:
info@pfaff.com
(Please allow 72 hours for response
Mar 24, 2011 | PfaFF Sewing Machines
The memory board went out on my 2000 tiptronic 6270 a couple years ago. now the machine won't sew at all. the sewing light comes on, but not the lighted digital readout area. so , no sew. how do i...
There is a fuse in the the base plate
that has probably blown. It is soldered in and needs to be fixed by a Pfaff dealer on someone with access to the fuse. If you have the work done, make sure they replace a certain reisitor on the base plate at the same time to prevent this from happening again (per Paff). Sorry for the inconvenience, hope you are back to enjoying your Pfaff machine real soon.
Aug 01, 2010 | PfaFF Tiptronic 2030
Bernina 1230. Works fine except the two bulbs will not light. Replaced both bulbs with correct type. Still won't light.
I have had this happen and found the switch was broken and not making contact inside the machine. We prepped the plastic and use a two-part glue for plastic.
I don't know how long the repair lasted as I sold the machine.
Mar 11, 2010 | Sewing Machines
Sewing Machines Logo
157 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
