Refrigerators Logo
Thea Schmidt Posted on Sep 05, 2015
Accidentally broke a cooling coil in refridgerator, stove, sink combo unit, now it doesnt seam to work?
Defrosting the freezer & broke through the ice and hit where freon gas runs through to keep unit cold. Sealed the hole, bu now it wont get cold. How do I recharge it or fix?
2answers
Hi, I have a LG fridge LX72LBEG. 1PH-220-240v PUJC 2520050040575. Fridge &freezer combo does not cool on both sides.checked the fan is working, compressor (R134a) just gets hot
Hello
Since you did not make a complete thaw in the freezer?
Do this and then cleanly, let it dry inside, then turn it on, cause it can be an ice plug in the freezer coils
Electrolux american fridge freezer cooling problem
There is a defrost timer on the unit. It is supposed to come on and melt the ice that forms on the coils in the evaporator. IF you get a lot of ice built up or something is wrong with the timer, it wont melt the ice or it wont come back on to cool the unit.
Freezer keeps freezing up. But the fridge doesn't stay cool.
the reason the fridge doesnt stay cool is because the freezer keeps icing up, try defrosting the freezer and try cleaning the condensor coils and this may help.
2helpful
Refridgerator not cooling but freezer seems find
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Refridgerator stopped cooling two days ago, and now the freezer is defrosting
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Whrilpool refridgerator not cooling in freezer or fridge model ET22PM
Hello and Welcome to FixYa!
The Poor cooling that you are facing is caused due to the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing/opening the panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer that is exactly the thing you quoted. Such a frost build-up usually shows a problem in the self-defrosting system or damaged door gaskets. The refrigerator is supposed/designed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited. Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system: The defrost timer The defrost thermostat (usually a bi-metallic switch) The defrost heater Also you need to clean the dust, lint from the condenser unit by using a condenser brush or a vacuum cleaner to remove all the dust from the unit (it is usually located at the back of the refrigerator). If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. If the problem still persists and the above quoted techniques/tips didn't work,You may need a qualified appliance repair technician to further diagnose the problem.
Best of Luck,
Please do Rate the solution, if you feel that this helps you,
Concerned.
1helpful
I have a top freezer/refrigerator and notice that ice is accumulating in the freezer and underneath the freezer in the fridge. What are my settings supposed to be set at? What should I do?
It sounds as if your refrigerator has stopped automatic defrosting of the evaporator coil or has a plugged defrost drain.. Below is some information provided by: www.repairclinic.com, to help you understand what may be wrong with your unit. If it is not cooling properly, you may be able to get it cooling again, temporarily by removing all perishable items, unplugging the unit, and allowing it to stand idle wth the doors open. This will allow the ice to melt, which will allow air flow to resume normally through the unit. Allow several hours for the ice to thaw completely, then close the doors and return it to an operational status. Put water in both compartments and when satisfied with the results of temperature, i.e. frozen in freezer and cold in fresh food compartment, you can put perishables back in. This will allow normal operation for only about a week until the defective part gets replaced, then it will start warming up again.
If the drain is plugged then the diagrams should show the routing so you can clean it out.
Today, all but the smaller, apartment-sized refrigerators are self-defrosting. Self-defrosting means what it implies--though frost continues to accumulate inside the refrigerator, it melts automatically. The self-defrosting system has three functional components:
Defrost timer
Defrost heater
Defrost thermostat.
Defrost timer The timer is like a clock. It continually advances, 24 hours a day. Every 6 to 8 hours, the timer turns off the cooling system of the refrigerator and turns on the defrost heater.
Defrost heater The defrost heater is similar to the burners on an electric stove. It's located just beneath the cooling coils, which are concealed behind a panel in the freezer compartment. The heater gets hot. And, because it's close to the cooling coils, any ice or frost build-up melts.
As the frost and ice melt, the resulting water drips into a trough. The trough is connected to a tube that drains the water into a shallow pan at the bottom of the refrigerator. The water is then evaporated by a fan that blows warm air from the compressor motor over the pan and out the front of the refrigerator.
Defrost thermostat The process ends after either the amount of time specified on the timer or when the defrost thermostat near the cooling coils senses that the heat near the coils has reached a specific temperature.
Detailed parts diagram:
http://www.repairclinic.com/Refrigerator-Freezer-On-Top-Appliance-Diagram
1helpful
FREEZER ICED OVER, LOWER COMPARTMENT NOT COOLING
Well, if the service person said the defroster is not the problem, there must be a good reason. But, I would go with a faulty defrosting system. Most likely suspects are the defrost timer and the defrost heating element.
2helpful
is it side by side or freezer on top/bottom...check to see if the fan inside the freezer is running when the compressor is running..also check to see if ice is covering the evaporator coils.. the freezing should be even with a thin layer of ice/ not partically melted..sometimes the ice forms in the vents and stops the air flow...to review...check and see if fan is working in freezer
check to see if vents are clogged......good luck!!
Maytag refridgerator model MSD2651HEW refridge not cooling properly
my water dispencer has a low flow after an initial regular flow. why?
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
