Question about Watts Onan Portable Generator - 4000 , Model# 5500
What is the oil filter for onan4000 generator
Yes--- where is the oil filter on a onan 4000 in toy hauler?
Posted on Aug 02, 2009
Why woun't my 6500 ransond generator start its a diesel
See id it is actually pumping fuel and if so see if the glow plugs are getting hot.
Oct 07, 2014 | Cars & Trucks
Need to change oil but can't locate oil filter
you have to take the front cover off the outside of the unit and you should see it down towards the side or a little lower.
Aug 16, 2014 | Generac Guardian Generator Adapter Oil...
The generator shuts off after 30 minutes with an oil level alert but oil level if full
Your oil level sensor is bad. It needs to be replaced. If you unplug the wire leads to the sensor you may get the generator to run, but you'll have no low oil level/pressure protection. The oil level sensor is on the engine crankcase usually near the oil level dipstick. You'll likely see a small sensor with a couple of wires attached to it. To replace it, you'll need to drain your engine crankcase before removing the sensor.
Apr 06, 2014 | Kipor RV Generator Sinemaster IG3000
I tiped my generator and oil came out of the air filter
if the filter got oil soaked replace it remove the spark plug and crank it over til no oil sprays out install spark plug start it up it will smoke for a while but let it run without a load til it clears up
Sep 02, 2012 | Electrical Supplies
Honda 5000 generator with remote starter running rough.. tis like ******* or something.. oil was almost empty so i stopped generator and added oil and restarted.. can u give some advice as to how to remedy...
Those generators are set up with a low oil saftey but your gonna want to check compression anyways just to verify it is where it needs to be. Im gonna guess its to be between 120-160 psi, check your manual for the service limits. after that check your air filter, valve lash, fuel filter etc etc.
Mar 29, 2012 | Honda Mmd 5000 Watt Electric Start...
Can some one tell me what oil and air filter to buy for a Kohler 12res LPG generator?
Lowes sells air filters for Kohler engines . As far as the oil a SEA 30 or 10w 30 would be fine.
Dec 01, 2010 | Kohler 12 kW Emergency Power System -...
Generator is burning oil and choking out
You have/had too much oil in it. After it is brought down to proper level, it may have to burn the oil that is in areas that it should not be in. Another thing that may cause this, is a dirty air filter, can cause enough suction to pull oil around valves, and other places a clean filter will not. It may have oil in the filter too.
Dec 19, 2008 | Briggs & Stratton Power Products 5,550...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
588 people viewed this question
Top Watts Electrical Supplies Experts
Sheldon Dedek
Norman Worley
Joseph Hoffmann
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
