Question about Dryers
Vent Kenmore HE2 dryer from the Side, not the back
Model #110.8756
Problem: I need to vent my kenmore dryer from the side instead of the back to save ~3 inches of space. The service company wants ~$100.00 to do difficult is it to do it yourself?
  • 1 more comment
  • JDinSeattle Jan 15, 2008
    Yes, I did. You remove the back panel, punch out the side vent hole (on either side one is available), attach a 90 degree elbow and another piece of 3 inch venting pipe (available at the hardware store). You tape these together with special tape also available at the hardware store. Use the same piece that is currently in the back of the unit to attach the venting pipe that eventually goes to the outside of the house. To do it myself cost about 10 bucks. You will also need to remove an access panel in the front of the unit, below the door, to help see what you're doing and give you enough access to get your hands in there. good luck.
  • susan d Sep 10, 2008
    Can this be done if there is no punch out on the side of the dryer?
  • Anonymous Mar 13, 2014
    converted to propane and now will not turn on
I'm in the same boat as you. Just had my dryer delivered today. Did you find a solution?
Posted on Jan 11, 2008
How do i vent my kenmore elite dryer out the bottum
I don't beleive that you can vent it through the bottom only the back or either side
Oct 09, 2014 | Kenmore Dryers
How do I change the dryer vent from rear to side
there is usually a pc that can be removed on the side a round plate with light soder
Jul 02, 2014 | Kenmore Dryers
Have a Kenmore elite electric dryer model 11062952100 that heats but stops midcycle on both timed and auto. It does start right back up. Does seem to take a little longer to dry clothes. Have checked the...
Check behind the dryer to make sure the tube running to the exit vent isn't clogged or blocked. Then go out side where the vent runs to and make sure it isn't clogged.
Aug 29, 2011 | Kenmore Elite Oasis 6808 Electric Dryer
How do you side vent the Kenmore 800 dryer? I cannot rear vent the dryer due to space limitations. I MUST side vent.
You will need to take the dryer apart, pull the drum out. Then at the bottom you will see the main discharge, take it off and insert a 45 degree elbow, you will need to then install hard venting to reach the knock out on the side. Be sure to use metal duct tape when sealing the venting to avaoid fire haz.
Nov 09, 2010 | Kenmore 800 7982 Dryer
Our Kenmore HE2 dryer seems to be taking a very long time to dry clothes (120 minutes on Medium High to dry towels/jeans) . It is producing heat, but it also seems to be producing water/steam. The filter...
you need to clean out the vent line and the dryer.unplug the dryer,pull out the filter,remove the bottom panel and then remove the duct that the lint filter slides into and clean it out,vac out the inside of the dryer,if you have a shop vac you can blow all the lint from the back and then vac it up,make sure you blow off the motor,alot of lint gets built up around and inside it,pull out the dryer and pull off the vent line,if it's a long run i use a leaf blower to blow out the vent line,first go outside and make sure the vent is clear so when you blow out the vent line nothing is blocking the lint from coming out.this will take care of your problem,do this once a year and your dryer will last longer,you'll need less parts changed out over the years because the dryer won't over heat,you'll save on electricity,your clothes willl dry on time and most of all you won't have any fires
Sep 26, 2010 | Kenmore Dryers
Moved dryer to a new home. Dryer vent comes out of the middle of the dryer. New home vent is next to the outside wall so i have a bend off the dryer vent and then a bent to the out side vent, Can you...
Some Kenmore dryers have a knockout at the back, lower corner that can be "knocked out". If you have one of these it can be vented out through the side. If the knockout is there, a kit is available for the venting. Just go to and under the parts direct tab enter your model number aka 000.00000, and search out the kit.
Aug 29, 2010 | Kenmore Dryers
Need to change vent from rear to left side
why don't you just go to home depot and buy a longer flex hose?mike
Feb 19, 2010 | Kenmore 64942 Electric Dryer
Kenmore dryer model 41780042990
sounde like you have a clogged vent line be shure the vent hose is not cinked in any waty that would restrict the air flow. Next turn the dryer on and make sure you and a good flow of air out side the house if the air is not blowing out the vent out side you will need to clean this out or have it cleaned.
Jan 20, 2009 | Frigidaire FEQ332E Electric Dryer
How do you change the dryer vent on a Kenmore 800 series
yes and here is the part kit that you need..part # 279818..onthejob..everthing you need is in this all comes together..
Jan 12, 2009 | Kenmore 63942 Dryer
Kenmore model 110.64672400
Yes if it taking long to dry the vent is still resticted. Thats all it can be! Nothings wrong with your dryer! focus on the vent and you will fix it!
Dec 01, 2007 | Kenmore 63942 Dryer
Dryers Logo
1,297 people viewed this question
Top Dryers Experts
