Question about Alpine Car Audio & Video
Installing an alpine stereo in a 1999 Dodge 1500, I have power to the stereo but nothing from the speakers There is supposed to be an amp somewhere in line but I'm having no success at finding anything and any diagrams say that there is not one
    Problem Solver:
  • 15 Answers
If you have an infinity system you more than likely have an amp somewhere, if it isnt located on the passenger side either on side of or beneath the glove box it may be mounted in the rear... behind one of the side rear panels, or beneath the rear seat...
Posted on Jul 12, 2009
On old alpine amp 3523 where there are 2 power pins and 2 ground pins do you need to connect them all up,or just one power and one ground.Mine did not come with any connection plugs thanks
the speaker connections are separate, here is a picture of connections. speaker neg is not the same as power negative or ground. wire according.
c5hjkogv5pnraaaaaelftksuqmccaa==
Jul 30, 2018 | Alpine Car Audio & Video
Color picture of this diagram
Radio Diagram? Confirm us if this help you...
1999 Dodge Ram 1500 Truck Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Behind the glove box.
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 29, 2012 | 1998 Dodge Ram 1500 4WD
Trying to install a Alpine 3552 amp, can't get power, not sure how remote switch works?
make sure you have a good ground. use a continuity tester. local retail or stereo shop sells one for about $10-$20. make sure you have power (fuse should be within 12" of battery). the remote wire off the stereo (usually blue) can be your remote switch. this has to be connected for the amp to work and stereo must be turned on.
Jul 23, 2011 | Alpine Car Audio & Video
I have a stock stereo and two subs with an amp in the trunk. Also two alpine speakers in the rear. Whenever I turn my balance to the left my subs don't play. What's wrong?
Hello.... I am sorry to hear you are having problems. The reason for this is that since you have a stock stereo, the shop (or person) whom installed the amp and subs used a line out converter. What this part does is allows the connection of RCA cables to the factory head unit. Almost all bass signals are always in stereo, so since you were only hooking an amplifier for just subs, you can actually just connect to just one of the rear speakers instead of connecting to the right and left. Just makes the install a little quicker. There is nothing wrong with this as I usually do the same thing in our shop. However, if you are going to be using the balance control, then you will need to go back to the shop and have them hook the converter up in stereo (to both rear speakers). Hope this helps!
20 year car audio/video installer
Bay manager
Mar 15, 2011 | Alpine Car Audio & Video
I need a wiring diagram for a 2008 dodge 1500 radio
Thanks for using FixYa.
2008 Dodge Ram 1500 Car Stereo Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: N/A
Car Radio Ground Wire: Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green/Yellow
Left Front Speaker Negative Wire (-): Dark Green/Light Blue
Right Front Speaker Positive Wire (+): Gray/Yellow
Right Front Speaker Negative Wire (-): Gray/Light Blue
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Gray/Light Green
Left Rear Speaker Negative Wire (-): Gray/Dark Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
Jan 28, 2011 | 2008 Dodge Ram Pickup 1500
I need the wiring diagram to install a Alpine 7516 in a Dodge Colt 1994.Thanks! Alain
1994 Dodge Colt Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/White
Car Stereo Dimmer Wire: Red/Black
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue
Left Front Speaker Negative Wire (-): Blue/White
Right Front Speaker Positive Wire (+): Blue/Red
Right Front Speaker Negative Wire (-): Blue/Yellow
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Blue/White
Left Rear Speaker Negative Wire (-): Blue/Green
Right Rear Speaker Positive Wire (+): Blue/Red
Right Rear Speaker Negative Wire (-): Blue/Green
The manual for the Alpine 7516 can be purchased here:
https://www.samswebsite.com/en/photofact/search/index/model/7516
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 19, 2010 | Alpine Car Audio & Video
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
Alpine stereo car deck installed in place of factory Bose with
What you have been told is correct, these proprietary systems are great for the manufacturer, but when they start to have issues (and they will) they leave you 2 options: pay through the nose to stay original or replace the amps with new ones....the upside of this is aftermarket amps are soooo mugh better than stock that it is lauhgable.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Mar 11, 2009 | Car Audio & Video
Need stereo wiring diagram
1998 Dodge Ram 1500 Truck Car Stereo Radio Wiring Diagram
Dec 30, 2008 | 1998 Dodge Ram 1500 4WD
Alpine cdm 9823 does not make any sound at all everything but it does not sound at all
This may have one or two things going on here:
First, do you have car ampifiers in the vehicle? If so, this is an indication that the problem might be with and amp....check power and connections at the amp.
Second, it may be a radio setting. In the settings menu on the Alpine, there is an option to turn the internal amplifier on/off. Make sure that it is set to on or you'll have power and no sound.
Third, you may have a speaker short or bad speaker somewhere. To protect it's internal amplifier, the radio will turn off the sound output when it sees a speaker is shorted or grounding somewhere in the system. This can happen when a speaker's voice coil goes bad or when a speaker terminal contact is touching metal somewhere in the car.
If none of these ideas points to the solution, I'd recommend visiting a local car stereo shop to have them further troubleshoot. Hope this information was helpful.
Sep 28, 2008 | Alpine Car Audio & Video
Car Audio & Video Logo
82 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Jeffrey Turcotte
Jeffrey Turcotte
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
