Not entirely true. Most watches in a range will be assembled with a standard-sized time mechanism. So the manufacturer can "Bulk-out" the mechanism with a plastic housing to get it to sit into the bigger watch enclosures. I have several Tissot's, so I change the batteries myself. A few have plastic frames to bed-in the mechanism. You'd need to move to high end ($5k-10k+) watches to avoid plastic. A PSC200 retails for around $1000? There are a few basic checks you can do to re-assure yourself that its legit. (1) Did it come in the standard Tissot box, complete with history booklet, warranty booklet and stamped retailers warranty card? (2) Is there an engraved/embossed Tissot detail on the back cover, with model number, , sometimes a collection serial number, waterproof details etc. (3) Is the face scratch-proof crystal or does it sound thin and cheap when you tap it? (4) Are the second / minute markers and fractional-second markers clearly defined, or are they a cheap and blurry paint job? (5) Are the minute and second hands precision cut, with crisp sharp edges, or are the pressed tin with 'soft' rounded edges? (6) Does it have tiny but clearly legible "Swiss Made" text around the 6 O'Clock position? If you're concerned, bring it to another Tissot retailer and ask them to check it out. They would be more familiar with the Tissot range and manufacturing techniques.
SOURCE: My Tissot Rock Watch is running slow despite new battery
Hi, Try this service center:
Barbara Williams
Old Father Time, LLC
http://www.oldfathertime.com/
(800) 383-4992 within the US
I know for a fact that they repair Rock Watches.
SOURCE: tissot prs 200 lost instructions
download your manual here:
http://support.tissot.ch/?mod_flashPDF/id_143
SOURCE: Shortening stainless band for 1st generation Tissot Le Locle
Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws.
If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx.
size of pin end diameter using any sharpening stone or sandpaper. Get
an old towel and fold it to make a soft base for work (like small
cusion). As you don't have a special bracelet holder you will need a
pair of helping hands to hold the bracelet steady upright. You will
need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make
sure that the grooved pin ends are facing towel, not the needle and
hammer!!!
Now place the watch on the folded towel, take that needle and smallest
hammer you have and start driving the pin out using light blows. Do Not
hit hard, as you will brake the needle, scratch your watch or even
injure yourself. Watchmakers are using 45 gram hammer, so, calculate
your strength of blows.
After a few blows check if the split end is coming out and when you see
that the end is long enough to grab it with pliers, pull the pin out
with pliers. When pulling, do NOT turn pliers, as pins tend to brake
when twisted. Use firm grip and your strength to pull the pin without
twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY
the same way as they came out- the blunt end first in the hole and the
split (grooved) end last. Before doing that check remaining pins in
bracelet to make sure that you put them back from the right side of
bracelet.
It is recommended to use plastic hammer to drive pins back in or you
will scratch or damage bracelet. If plastic hammer is not available use
an old toothbrush handle (or some plastic item) as an absorber. Simply
put pin into the hole as deep as you can with your fingers, put the
toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Don't forget to rate, please.
SOURCE: Tissot PRS 200 hour and mnute hands not advancing.
I may not be clear on the problem here but it sounds like you may only need a battery change. If the battery is not the problem you can ask that your watch by placed on a cyclonic to force the gear train and free up small particle(s) that might be holding it up. This will be the fastest and least expensive. There is the chance this may require a more complicated repair but this till give you a starting point.
I suggest going to a watchmaker/technician who is familiar with working on this brand and be able to seal the watch back to its water resistant rating. This will take having a pressure chamber on site.
SOURCE: tissot wristwatch model PR 516 GL
I guess you never overhauled your watch.Every mechanism has it's limits - so does the watch movements. Your watch has ETA Swiss made mechanical movement which is very good and reliable, but you have to take care of it from time to time. Mechanical movements are designed to last almost forever if they are looked after and yours isn't an exception. Bring it down to the local watchmaker and ask to overhaul it. It will run as new again and will not let you down. It is recommended to overhaul mechanical watches every 4-6 years. If this will be done, your watch will happily tick-tock on your grand-grand-grand-grand-grand-grand children's wrist and they will remember you with a few good words and respect.
Please dont forget to vote this answer was helpful.
Many thanks
