Question about Amana RanARG7302 Gas Kitchen Range
Oven won't come on
Same problem as the others....gas oven, burners and broiler are fine but when oven is turned on there is no ignition or gas smell?????
  • 89 Answers
Check the ignitor for the oven even it is glowing it may not be pulling enough amps to call for gas this is a very common problem with maytag and amana ranges replace the ignitor and it should work fine
Posted on Jul 12, 2009
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Broiler works. Oven does not
Plugged gas pipe which connects to the burner.
Jul 04, 2013 | Tappan Kitchen Ranges
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Gas Oven will not ignite. Broiler and burners
The ignitor for your oven is worn out and needs to be replaced.
Oct 02, 2009 | Kitchen Ranges
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Dec 09, 2008 | Ovens
Broiler will not light. Oven & top burners work fine
hi thanks for the question check to see if the broiler igniter is broken that could be the problem do you use the broil more than the bake if you do then change the broil igniter thanks the appliance doc
Sep 16, 2008 | GE Spectra JGBP30 Gas Kitchen Range
GE Oven does not light - no gas smell and no electronic ignition clicking sound
Gas oven does not work. Burners and broiler work. When oven kGnob is turned on, there is no glow at ignitor, nor any gas smell.
Jul 21, 2008 | Kitchen Ranges
Oven will not work,burners and broiler all work fine
under the floor of the oven, possibly can be see by removing the bottom drawer. the ignitor is hte most common aprt to go bad in any gas oven, visually it might not even look broken though and some even appear to glow(just not strong enough to open gas valve
Mar 01, 2008 | Kenmore 78570 / 78571 / 78572 / 78574 /...
Amana RanARG7302 Gas Kitchen Range Logo
467 people viewed this question
Top Amana Kitchen Ranges Experts
Sal De
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
