Question about Kenmore Microwave Ovens
How do i remove kenmore under the cabinet microwave model # 665-60652000?
MicrowaveSvc
  • 9150 Answers
SOURCE: Kenmore Microwave Model #665 6861 1891
F6 appears to be a relay failure on the main board, but it may be a door switch or door switch mount.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. Other times, it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jun 08, 2008
SOURCE: removing under cabinet GE microwave
Remove the face plate above the door. You will see two bolts where you can use a screwdriver to turn them (unlock them). Those bolts go all the way to the back of the microwave. Once you have turned them (you do not need to remove them), you will need to remove the one - three screws that come in from the cabinet above. You may have to jar it loose if it still stuck.
Posted on Aug 31, 2008
SOURCE: kenmore microwave removal
the top vent exhaust grill has two screws facing down-remove these. remove plastic vent. inside you will see a solid wire tringle assy. turn and pull this release.
warning if you have granite counters or tile, place plenty of material under it to stop the impact if oven gets away from you
Posted on Oct 03, 2008
cj2176
  • 520 Answers
SOURCE: i have ge under cabinet microwave model jvm1331
Look in the cabinet above the microwave. You should see a vent if it is vented outside. You will need to remove the vent. Then look in the same area to find two screws that will need to be removed. Disconnect the power cord and have someone hold the bottom of the unit and remove the screws. It will fall at this point so hold it good. With the screws out and vent removed you will be able to let the front of the microwave down a little. This will allow you to now lift the back to release it from the channel hook in rear. Then you will see the mount plate on the wall. It should have screws securing it to the wall on stud locations. remove these screws and remove the wall plate. Hope this helps. Good luck.
Posted on Jul 14, 2009
  • 5 Answers
SOURCE: How do I remove Frigidaire FMV156DCC under cabinet microwave?
Underneath the microwave, on the right & left hand corner sides at the back, there are levers that you pull down & it releases the mounting bracket.
Posted on Sep 12, 2009
I have a used microwave that mounts under a cabinet, Kenmore model 721. It has only two screws to mount through cabinet does it require additional hardware? Seems alot of weight for just two screws.
Kurt,
There is usually a mounting bracket that mounts to the wall and the microwave hooks into that and is held up by the two screws you referred to in your question. Unfortunately, you have not provided enough of the model number for us to look up any info to help you find a new bracket to mount to the wall. Hope this helps!
Feb 22, 2016 | Kenmore Microwave Ovens
How do I attach a microwave model #721.80413 to the wallI
if this is a above stove brand.. you have to open the top cabinet right on front lip of cabinet are three screws going into microwave... support unit and remove the screws that hold unit
May 26, 2012 | Kenmore 63662 / 63664 / 63669 Microwave...
Kenmore elite model #665.61683101, has no power, plug works but microwave has no display, is there a fuse in this model?
There is a line fuse for this oven. Remove the cabinet and the fuse should be close to the line cord. Replacement fuses should be found at your local appliance supply house.
Apr 19, 2011 | Kenmore 62622 Microwave Oven
How to remove the old Tappen microwave oven model 56-2891 under the cabinet?
open the cabinet door above the microwave there should be four screws going thru bottom of the cabinet shelf holding it on to cabinet have a helper hold the microwave as you unscrew it
Dec 12, 2010 | Tappan Microwave Ovens
How do you mount this model
There are two bolts through the bottom of the upper cabinet that attach to the top of the microwave. These support the front of the microwave. There is a wall plate attached to the wall studs that supports the back. If removing the microwave, take care when removing the front support bolts, as the microwave will fall if not supported when these are removed. There are instructions available at www.sears.com under parts direct. Your model number will be a longer number than you have here it will look like this 000.00000.
Mar 10, 2010 | Kenmore 62702 Microwave Oven
Loose handle.
To access the door screws on MOST microwave ovens, you need to remove the inner door panel that goes around the perimeter of the glass. The following link explains:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
This can be peroformed with the door in place, or with the door removed. If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Feb 18, 2010 | Kenmore 62622 Microwave Oven
Unable to locate the mounting bolts to remove my Kenmore under cabinet microwave--pls help
Your micro slides into a housing that is screwed to the wall or cabinets.
Jul 07, 2009 | Microwave Ovens
Kenmore galaxy model 721 microwave hood combination
You put a mounting plate on the wall behind where the unit will be mounted. Then the microwave hooks onto the bottom of the mounting plate and you swing it up to the cabinet above it. Then you must screw 2 mounting screws through the floor of the cabinet above into the bracket on top of the microwave.
Jul 01, 2008 | Microwave Ovens
Microwave installation
I'm a kitchen remodeler, and I've seen this problem with Kenmores (so it probably exists with some other brands too. The ones I have seen have the typical bolts through the top, but there's more. The flat mounting plate on the wall has an protruding piece that fits well into the body of the microwave when the unit is slid into place. It has a threaded hole in the end of the extension, and the sheet metal screw or bolt that goes into this is causing your anguish. To access this, you must remove the top front louvers (maybe some other trim plates as well). You'll eventually find the bolt that unscrews with a horizontal screwdriver. Chris Harrison, Richmond Refacing.
Sep 23, 2007 | Microwave Ovens
Microwave Ovens Logo
114 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Jaime Hernandez
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
