I have vacuumed underneath and from back with flat tool. Cleaned interior and cleaned out water catch in front of freezer. Added about 1 oz of bleach down water drain which did drip back out into refrig section clear. Nothing comes on except the light. I bought this refrig about 3 yrs ago from Home Depot.
SOURCE: MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If you don’t know what these are then unplug the machine and let the ice
melt in the freezer overnight with the door open. Then try it the next day, if
is cooling fine then you need to have a service person replace one of the above
items.
SOURCE: I have a 6-7 year old Magic chef top freezer,
The defrost drain is located just under the cooling coils in the back of
the freezer. You will need to unload the food and remove the shelves
from the freezer. Take the back panel off from inside the freezer and
you will see a hole just below the coils. Flush it with hot water using a
turkey baster or small hose. See the link below for more details.
Defrost Drain
