Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Power on tv and I get black screen with sound.
For a month now every once in awhile when powering on, I will get sound and black screen. I have to turn it off, unpug everything and reset it. Now I turn it on and and all I get is snow, both sound and picture. Can anyone give me a step by step pocedure to fix this. I have no idea what imput it was running on before this happened.
  • 64 Answers
You have lost the input signal...you will have to go to Setup/Net Command and set your input to the one with signal (either a TV input or a Component input). If it is reset...the input likely switched to a non-usable input
Posted on Aug 01, 2009
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
TAKES 45 MINUTES TO COME ON
Evidently there is an internal power supply problem.
Nov 12, 2013 | Televison & Video
Will power up but black screen with no sound
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 20, 2012 | Sharp LC-C4662U 46 in. TV
Hey i just bought a new sony bravia hd lcd internet tv. and ever since like a month ago the screen would go blank and the volume would go out. the screen would only go out for a few seconds but its enough...
Tv it is having a problems,it is developing a power surges to their eclectronic boards.If this tv have this problems like 2 or 3 times black out in a couple hours of tv watching?Yes.This is a brand new tv?Yes,it should be return to the place where it was bought right away to exchange it for another tv,because this problems,will develope in to a bigger problems.The tv Tuner signal board,will evenually will dies completey.After tv life in usage for awhile more.Ur tv evenually get power only, indication LED power light up only,but no tv incomming broadcasting picture to tv at all.
Apr 17, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
TV red "on" light not coming on. Cannot get power to TV
The power supply board is dead.That the board where the power a/c plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power suply board for the replacement.
Jun 10, 2010 | Element Electronics 26 in. LCD TV
Black screen
Not good. Make sure you have not blocked cooling to TV. It need s air flow. sounds like overheating
Mar 25, 2010 | SNK Magnavox 42MF438B/27 42 in. LCD TV
Screen Problem
hi....Your tv picture is managed by several boards, the two specific ones are the ysus and the xsus. The Y controlls the horizontal pixelation and the X the verticle, if you are having horizontal problems then its the Ysus thats faulty, on this particular set, the Ysus board has two accompaning buffers that are particularly troublesome. I've had more than one of these sets in the shop recently with the same ailment.Sounds like your buffers are starting to go out. The screen is split horizontally by the two long skinny buffers attatched to the Y main, if the bottom one has one leg in the grave you'll be getting a partially black screen or no picture at all. The colored lines running through the screen are more typical of a failing buffer. Are you interested in taking this set apart and putting a couple hundred into fixing it?  When buffers go they usually take the Y main too. Worse case scenario you're gonna be out about $350 dollars to fix it yourself. Best case, a ribbon is loose on the bottom buffer and with a dismantle you'll be able to connect it again..
thank u rate me!!
Feb 12, 2009 | Philips 42PF9630A 42 in. Plasma Television
Akai LCT2721AD - Power on - Sound on - Black screen (No Picture)
Ive reviewed and assisted anoter person who had a similar problem that caused the tv to malfunctioin simialr to yours. After doing some short research and the other person who had the problem, came to find out that 4 resistors failed on the main board causing this to happen. It also could be the backlight of your Plasma screen tv, or your Plasma screen itself is shot.
I would recomened that if you have no active warenty to give a visual inspection of the Tv, via removing the rear black plastic pannel to see if any of the corisponding chips have any burn marks or excessive heat stress. these items seem to be failing about the 12 month mark
Good luck
May 12, 2008 | Akai LCT2721AD 27 in. LCD Television
Samsung 40" 1080P power flux
Try to replace the Power Supply board first.
Feb 01, 2008 | Samsung LN-S4051D 40 in. LCD Television
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
131 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
